Question about Lexmark X4250 All-In-One InkJet Printer
Error 1201 Lexmark x4250
Error 1201 keeps coming up, can't copy or print but can still send out a fax
  • 435 Answers
The definition corresponding to this error message is this: "The print carrier stopped before all of the data was used."
To resolve this issue, please do the following:
  1. Power the printer off.
  2. Remove all cables from the back of the printer.
  3. Reinsert the power cord.
  4. Switch the printer back on.
  5. Check the operator panel to see if the 1201 error message is displayed.
  6. If the error message returns, the printer could be defective. Contact Lexmark Customer Support for further troubleshooting and warranty options.
Thank you
Posted on Feb 14, 2009
U162 error on black ink cannon printer
This error occurs when printer fails detecting ink level or printer assume that no ink in the cartridge. We cannot use print, copy,scan, and fax function before the problem fixed. It's recommended for you to replace ink cartridge. To continue using the printer without replacing the cartridge we must deactivate ink level detection function. Be aware that printing in this condition can damage the printer while sending fax or scan is not problem.
If you need any technical help on printer then you can reach at http://www.vtechsquad.com/
Original source: http://ij-forum.blogspot.com/2008/12/error-message-check-ink-u162u163.html#ixzz2Cpr4Be1K
Nov 20, 2012 | Canon PIXMA MX340 Wireless Office...
Fax will not print: I connected the fax machine and plugged it in. It sends faxes OK. When a fax is sent to it, nothing comes out. The sending fax doesn't receive an error message, seems like all went...
Does the machine print anything? such as a directory or print when making a copy? I rather suspect it does not. When an incoming fax is recvd does the paper get pulled in and come out blank? If so your problem is with printing (or lack of it). Perform head cleaning. Also make sure the black cartridge still does not have its deal stuck on it. Post again if you still have problem.
May 05, 2011 | Brother Multi-Function Center MFC-3360c...
LSU Error keeps showing
LSU stands for Laser Scanner Unit. Depending on the model this should come up only if the services used required scanning such as copy, fax sending, scanning.
nevertheless if this is a continuous message you might need to check the connectors within the scanner which I advise an field call.
Apr 30, 2010 | Xerox WorkCentre M20i All-In-One Laser...
Error 1201
Problem Error 1201; Carrier stall; Printer stopped Solution The definition corresponding to this error message is this: "The print carrier stopped before all of the data was used." To resolve this issue, please do the following:
Nov 11, 2009 | Lexmark X4270 All-In-One InkJet Printer
Lexmark X160 doesnt Copy or print faxes
I have been getting a remote fax error often enough that's it's becoming a nuissance. Any suggestions on how to fix this problem?
Apr 07, 2009 | Lexmark X6170 All-In-One InkJet Printer
Copy report after sending fax
it will be under reports, you can set all faxes to do a report after a fax has been sent, ill keep the terminology easy as
Brother, canon, konica blah blah all uses different terminology for it, but there is a setting in reports for user that they can turn on, it like error reporting if a fax deosnt go it will print out a error report so same thing to do with copy report.
regards
Fax Tech
Apr 01, 2009 | Office Equipment & Supplies
Error codes 1201 and 1203
Hello, erorr 1203 is telling you there is one of a few issues with your cartridge/s. Check the contacts are cleaned and printheads. Make sure there are no paper jams. Reset the printer by turning it off and completely unplugging it and replugging it and turn it back on again. Clear print queue, check it is set to work offline in settings. Press copy and copy something and see if it is ok now. Error 1201 is a communication issue with data where your cartridge has stoped for one or more reasons and h eprint data was not completed or used. Try the reset to fix this too. Post back if no good. Don't forget to clear print queue.
Nov 17, 2008 | Lexmark X4270 All-In-One InkJet Printer
Lexmark x4270 copy and fax
reference: http://support.lexmark.com/cgi-perl/knowledgebase.cgi?ccs=229:1:0:439:0:0&framed=&docid=ENUS22014&relevance=1
Please rate this solution. =)
Jul 14, 2008 | Lexmark X4270 All-In-One InkJet Printer
Will not make a copy
If it won't copy, it is unlikely to handle faxes either since those functions use the same scanner. If your received faxes are coming out blank, then it is a problem with the ink system; if you can get faxes printed but not copy a document, the scanner may be at fault.
Have someone send you a fax to check this function (printing) and then try sending one back to check the scanner.
If either one fails, then hyou know where the problem lays.
Jul 10, 2008 | Brother IntelliFAX 560 Plain Paper Fax
I am having difficulty printing, receiving error message #1201 which is not in the manual. Re: Lexmark FAx X4270 Please provide me with a suggestion.
Hi teri,
I've seen this before and I know that once it was fixed by cycling the power a certain way. Try this:
1) Turn the printer off.
2) Unplug all of the cables.
3) Plug the power cable back in.
4) Turn the printer back on.
5) If the 1201 message on the Control Panel comes back up, try plugging the printer directly into the wall or into a different power strip. If no error message, plug the USB cable back into the printer and try printing.
It could also be a faulty AC adapter - if you have access to another compatible AC adapter try that. If the message continues, then the printer is probably defective and you should check your warranty status.
Please let me know what you come up with.
Ben
Mar 13, 2008 | Computers & Internet
Lexmark X4250 All-In-One InkJet Printer Logo
238 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
