Question about Sony KP-61S70 61" Rear Projection Television
Popping sound from TV
There is a loud popping sound from the TV occasionally it will shut off the picture. When I power cycle the TV the picture returns. It's a very intermittin problem and only one out of 5 times will the picture actually turn off. The sound remains on. It seems to be occuring more frequently. I've opened up the back of the TV and cleaned all the dust out to see if that would help and it hasn't. Any suggestions on what could cause this?
    President:
  • 3,130 Answers
Most likly it is one of the crt connections to the Hi voltage block that is causeing this problem or the crt it self is archuing , or the Hi voltage transformer, or the Hi volyagre distribution block is going bad. your going to have to observe ther problem happen or know what to look for when troubleshooting this set. I would recomend that you do not attempt to troubleshoot this set as it is a high voltage problem and theres enough Hi voltage inside this puppy to make a grown man cry or kill him!
Posted on Sep 30, 2006
Hello, Last night my Samsung plasma TV made a fairly loud popping sound while I was watching it and then the power went off. When I turned back it on, no picture but sound was o.k.
Yes the caps on theower supply, but you can check power supply board by smell an look for burnt parts it is common. May need more than one board if they are cheap get both.
Jan 29, 2015 | Samsung Televison & Video
Picture but no sound
the loud pop was a capacitor or a resistor popping, it will need replacing.
Jun 19, 2017 | Vizio JV50P 50 in. Plasma TV
I get sound but no picture then the tv shuts off after 5min. It is a Mitsubishi wd-73837
Popping noises are not a good sign; I suspect the sound came from the catastrophic death of an electrolytic capacitor or worse, the death a a power semiconductor.
Open the lower cabinet and using a good light, look for a smaller, separate board with fairly large parts on it; some cylindrical in shape, others block-like that may have copper wire showing.
If, as common, this board is plugged with connectors into other parts of the system, you may be able to swap the failed board out for a replacement bought from a Mitsubishi service center.Expect to pay $100-$150 US if the set is no longer under warranty.
Nov 23, 2011 | Mitsubishi WD-73837 73 in. HDTV
While watching the T.V. I started experiencing a random of two to ten second very loud static, popping sounds then it would go to a green then a digit scene then a gray w/loud sounds the popping sounds the...
Your set has a problem with its power supply. If it is under warranty, have it replaced ASAP. If your warranty has expired, you can take the set to any good repair shop - ask for an estimate before having any work done to it.
Feb 19, 2011 | Element Electronics FLX3711B 37 in. LCD TV
TV LG Model 50PX1D-UC Flat Panel Television Loud Popping Noise. TV goes out. I turned on my tv the other morning and it let out a loud popping noise and the picture went out. Any suggestions...
The problem is that there is a bad capacitor inside the unit, it is either on the main panel or the power panel. The popping sound you got was due to the fact that the lead on the capacitor was bridging, therefore causing some electrical popping sound.
Run a check on the main panel and the power panel for any bad capacitor and replace it with a new one. That way, your television will be in good condition once again.
Take care and good luck
Jan 02, 2011 | LG 50PX1D 50 in. Plasma Television
Pioneer Elite. Loud popping sound and picture disappeared
Power supply board is dead.The board where the power a/c cord plug into it.Replace the power supply board.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
May 30, 2010 | Pioneer Elite PRO-1140HD 50 in. Plasma...
Need the Boston tvee sound bar repaired. Making popping and cracking noise when power is on.
Haven't fixed it yet. Going to find a electronics repair shop locally and have them repair it.
Thanks.
Apr 11, 2009 | Boston Acoustics TVee Model Two TV...
Green screen and distorted picture sound is good but no picture
It must be connected with the color circuit of your tv, a board connected to back end of the tube. Could be dust, cob web or carbon deposit shorting a transistor. Popping noise if loud enough can be attributed to high voltage circuit fault and picture tube.
Have it service by a qualified person.
Apr 04, 2009 | Sony FD Trinitron WEGA KV-27FS120 27" TV
Loud Cracking/Popping Sound
Any other symptoms? You may be just hearing the occasional sound of static being bled off, or, if the set is not working properly, the sound of the high voltage section trying to compensate...accordianman
Feb 25, 2008 | Samsung HLP4663W 46" Rear Projection HDTV
27" GE TV with loud Popping sound
Could be a possible flyback. yes.. for a 27inch i would not think it would be worth it... 27 inch tvs are realativly cheap.. the lowest price to repair would be about 200 if you got lucky.
Dec 18, 2007 | GE 27GT271 TV
Sony KP-61S70 61" Rear Projection Television Logo
105 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
