Question about QSC MX1500A 2-Channel Amplifier
Long startup When I turn on my amp (QSC MX1500a) one channel switches on immediately, the other channel doesnt. Heres whats happening...when the mixer turns on, the red light under "prot" (which i assume means protect) turns on and then it clicks over to the green "pwr" light. Well, one channel takes about 15 minutes to switch over. This has never happened before. Eventually it switches over and the channel works perfectly. But why is this happening??? How can i get it to switch over immediately like it used to? Any help will be useful! Thank you so much. Max
The circuit is most likely tracking output DC offset. This offset is floating slightly above the trip theshold level. These levels tend to stablelize during warmup. So, you can find the offset adjustment pots and adjust to as close to zero as possiable. But beware,there likely is a leaky cap or semiconductor causing this unbalance. The relays don't latch untill the green led lights, so the relays are more than likely fine. Best of luck.
Posted on Dec 07, 2008
    Novelist:
    Champion:
  • 275 Answers
Problem is a bad relay. Temporary solution is to clean the contacts. Permanent solution is replacement.
Posted on Sep 30, 2006
    President:
  • 3,130 Answers
There is a bad connection in the other channel or the speaker relay has a bad contact in it.
Turned volume up all three amps shout down at one time
That sounds like it could be a power supply issue to the main amp board. Possibly a voltage control regulator function issue?
Feb 12, 2014 | QSC MX1500A 2-Channel Amplifier
My mx1500a is overheating
If the fans are working correct then you should lower the bias idle current, let me know more.
Aug 25, 2012 | QSC MX1500A 2-Channel Amplifier
I have a mx1500a qsc power amp and i was wondering do i need to rewire a tip/ ring/sleeve cable to make the proper connection to the input of the amp? coming from a snake can i just plug an instrument...
The best way is to make a new cable and connect the tip and sleeve.
Thats the best way to run your QSC, then you're using the balanced input.
But thats only working when the rest of the system is also balanced (snake etc).
Offcourse you can use your instrumentcable, but that is unbalanced and you will loose some gain.
Regards,
Gerard
Mar 07, 2011 | QSC MX1500A 2-Channel Amplifier
Qsc mx 2000a left channel go into protek mode
Does it do it with nothing connected to the inputs and outputs? If yes, something internal.. anything loose in there (is it moved alot and something could have fallen inside of it)
Mar 28, 2010 | QSC MX1500A 2-Channel Amplifier
My QSC GX3 has a red light that turned on (on the front panel). The channel is not working. Is this a fuse or something else?
You should check the speaker set, maybe it's short circuit.
Try remove the speaker set from the unit, than switch on the amplifier again, if the red light still on, surely the final drive is damages( Transistors or IC's).
Replace it with new ones.
Oct 18, 2009 | QSC MX1500A 2-Channel Amplifier
Peavey cs800x a channel drive board what goes bad?
A bit late, but I'll give it a try.
You can measure the outputsignal before the relay.
Often there's a coil, measure if you've got a DC level at that point.
If so, you're power amp is down.
Normally when the relay doesn't switch there's a DC level in your amp.
Cheers, Gerard
Sep 07, 2009 | QSC MX1500A 2-Channel Amplifier
Where can i get the used power amps?
i have one qsc 1500a 1000watts awsome doesn't many hours on it.
New Orleans La,70056 were are you from
Mar 08, 2009 | QSC MX1500A 2-Channel Amplifier
QSC 1420 pwr amp
The weaker signal caused by leaky capacitor and change value resistor is need to replaced with a new one so it's works normal again. Your tech did is re soldering the cold solder he did not replaced some defected parts.
Hope it may help you;
Regards;
VOTIT
Jan 07, 2009 | QSC MX1500A 2-Channel Amplifier
Open Questions:
See all QSC MX1500A 2-Channel Amplifier Questions
QSC MX1500A 2-Channel Amplifier Logo
293 people viewed this question
Top QSC Audio Players & Recorders Experts
 Grubhead
Grubhead
Rob Beech
Gil Shultz
Are you a QSC Audio Player and Recorder Expert? Answer questions, earn points and help others
