Question about Roper 24 in. RUD3000 Built-in Dishwasher
DISHWASHER my freestanding dishwasher has stopped working the dial does not rotate it seems to wash but dial does nothing
  • 6,784 Answers
This is a sign of a defective timer mechanism. replacing the timer will fix this issue. Replace the timer/control model asap.
Posted on Jun 11, 2009
Ffbd2407lm frigidaire dishwasher stops washing cycle?
Sounds like you need a professional to diagnose the unit for repairs. You are either having a timer issue or a control board communication error.
Aug 24, 2012 | Frigidaire Dishwashers
Dishwasher runs and never stops
hi,
Sounds like you would need a new timer which can be purchased from Miele directly or through a authorzised service agent
Jun 30, 2010 | Miele 24 in. G870 Built-in Dishwasher
No water goes into dishwasher. Dishwasher has only been used 2times. Came new with house 3.6 years ago. Pulled front panel off...everything appears to be connected motor fan runs.
I've experienced the same thing. Try very slowly rotating timer dial, click by click, until the water starts. Sometimes 3 or 4 clicks will start water. (You're advancing the clock.) Usually water starts in before the dial points to, "Short Wash." If this doesn't work, advance the dial to, "Off," unlock and open the door, reset, close, the soap dispenser, close and lock the door, and slowly advance the dial until the unit starts. I think this problem is a clock to pump issue and what I've described does a reset of the system. This happens to me once or twice per month. Poor engineering but still better than buying a new machine...at least 'till now.
Jan 04, 2010 | GE Nautilus 24" Built-in Dishwasher
Danby Designer Dishwasher sprayer arm stopped working
is anything in the way of the arm? Sometimes you can't see an item sticking down too low ... interfering with the spinning.
Oct 05, 2009 | Danby DDW1805W Designer Series...
Dishwasher stalls
If the cycle doesn't complete, check these:
Water-heating cycle
Timer
Water-heating cycle Many dishwashers heat the wash and/or rinse water to a higher temperature, as the cycle calls for it. In these cycles, the dishwasher pauses after it has filled with water, waiting for the water to reach the pre-set temperature. What happens next, depends, as follows:
  • On some units, the pause is timed and the unit continues after the allotted time.
  • On others, the cycle can't continue until the water reaches the higher temperature. If you have this type of dishwasher and the water isn't being heated (say, because of a problem with the heating element or thermostat), after the unit stops at the heating cycle, it never continues. When you repair the heating-system problem, the "cycle problem" is fixed too.
Timer Timers don't often fail. But if every other part of the dishwasher seems to be working properly and the timer knob seems to be stuck in one place--doing one function continuously--the timer may be at fault. Dishwasher timers can't be repaired. If yours is defective, replace it.
May 31, 2009 | Bosch SHU4006 Dishwasher
Our Nautilus dishwasher won't turn on. I can hear a buzzing noise, but nothing is happening. Does anyone now what I should do?
The same thing happens with my dishwasher. I have made it work by doing the following. When you start up the cycle, turn the dial to just a tick before "start." If you hear the buzzing, but no water is running, unlock and then lock the dishwasher door again. This usually gets it running. If it's still not running water, unlock, advance the dial a little bit, and lock again. This should work. You need to be around for the early parts of the dishwashing cycle because this machine tends to stop up and buzz without running water until it gets past "short wash." Every time this happens, do the same thing, unlock and lock, and advance the dial a little when necessary. Once you get past "short wash," it should complete the wash without intervention.
Feb 22, 2009 | GE Nautilus 24" Built-in Dishwasher
Noisy Bosch dishwasher SHU43C05UC
your main wash motor is faulty it must be replaced.
May 05, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Powder not dispersing
possible the wash arms are not rotating - a common cause of powder not being taken. check by opening the door when in use and look to see if arms rotate. if not, then remove the arms and clear the jets especially the angled jets at the end which cause the arm to rotate
Jun 21, 2007 | Westinghouse 24 in. MDP531 RF...
Dishwasher Does Not Cycle
IA, these GE pumps have a habit of sticking if the unit hasn't been run for a while. First you want to verify that the motor is in fact getting power, this will eliminate the timer. You can use a meter on the quik connect from the motor while in the wash cycle. If the motor is getting power, see if the pump is stuck by turning the motor vanes (Do this with the power off). If it's hard to turn and then frees up than this was more than likley your problem. You remove the bottom toe panel and will be able to check this out without removing the dishwasher. Catriver..post back
Dec 29, 2006 | GE 24 in. GSD2230Z Built-in Dishwasher
Roper 24 in. RUD3000 Built-in Dishwasher Logo
139 people viewed this question
Top Roper Dishwashers Experts
Mike
paul
paul
Melissa Martin
Melissa Martin
Are you a Roper Dishwasher Expert? Answer questions, earn points and help others
