Panasonic 32 inch LCD TV will not turn on-red light flashing
I have had my Panasonic 32inch LCD TV about 18months. It will not turn on with the remote or the power button on the TV. I have unplugged it from the wall and plugged it in again but no change. The red led light on the lower left hand corner of the set is flashing intermittently. Power light stays on, but no picture or audio
  • 1 more comment
  • Anonymous Nov 23, 2008
    I have same problem. Has happened twice over the last year. Each time, I unplugged the TV for 10-15 seconds and then it was OK .
  • Anonymous Dec 12, 2008
    and it is fresh out of the box but i have tried the unplugging trick without success
  • chris Aug 12, 2012
    wat does it mean if it blinks 4 times then pauses and blinks 4 again
Its not hard to replace the bulb and you can go to any tv shop and have them order it.youll need to give them the make and model number off the back of the tv so they know what to order
Posted on Nov 03, 2008
3 Suggested Answers
  • 31 Answers
SOURCE: Panasonic 32 inch LCD TV will not turn on-red light flashing
sounds like a hardware failure, let me know which model # it is and i will run through service manual.
Posted on Oct 26, 2008
  • 5 Answers
This is a known fault. John Lewis in the UK sent out an engineer under their 5 yr TV guarantee and completed the firmware upgrade for me. The only other store to compare with them for price and service is Richer Sounds but I believe you now have to buy the warranty for 10% of the purchase price. This problem will persist unless the upgrade is completed. For those of you in the UK, I would insist the seller repairs the problem under the Sale of Goods and Services Act as the TV is not fit for purpose without the upgrade. You have 6 yrs (not a year or 6 months) to claim under this Act.
Posted on Feb 13, 2010
Panasonic VIERA TC-L32C3 32-Inch 720p LCD HDTV by Panasonic
Hello, welcome to Fixya!
You didn't state any problem concerning this TV. What precisely is the problem with your Panasonic VIERA TC-L32C3 32-Inch 720p LCD HDT?
I look forward to your reply.
Regards.
Sep 27, 2011 | Panasonic Televison & Video
Hi I have a Panasonic VIERA TX-32LZD80 32 in. LCD TV TV which will not turn on. The standby light will flash continuously, but will stay on red if I press on the on button using the remote. My TV is...
BECAUSE THE QUESTION WAS ASKED BACK IN December 8, 2010, it is more likely that he has moved on. Anytime you have a product UNDER WARRANTY, USE IT OR LOSE IT. THINGS HAPPEN. DEVICES FAIL.
Dec 08, 2010 | Panasonic VIERA TX-32LZD80 32 in. LCD TV...
TV won't turn on with remote (new batteries)
Sounds like a power supply problem. The blinking light is never a good sign. Is it still under warranty?
Jan 06, 2010 | Panasonic Viera TX-32LX70 32 in. LCD TV
Wont turn on
The power supply board has been defected. Replace it with a new one.
Aug 15, 2009 | Samsung LN32A330 32 in. LCD TV
The number of flashes is an error code. Count the number of flash. It looks like one of the boards in your set is failing intermittently. Panasonic codes for a guide as a starting point. Exact board STILL has to be verified;
One Blink: One blink of the power LED indicates a problem in the inverter circuit located on the LCD panel. The inverter board is not to be repaired in the field. Therefore a replacement is required.
Three Blinks: Three blinks of the power LED indicates an over-current or over-voltage condition in one of the DC supplies of the AP board. The AP board is repairable. Therefore the use of an ohmmeter and peak-hold-voltmeter is required to determine the cause of the shutdown. An over-voltage condition is definitely a defect of the AP board. An over-current condition may be due to a short circuit located in the AP board, A board, or the LCD panel.
Five, Seven, or Eight Blinks: The A board is responsible for five, seven or eight blinks of the power LED. The MAIN +3.3V, MAIN +5V, and MAIN +9V sources are all produced on the A board. The detection input pins of the MPU, IC1100, monitor for their presence.
Four or Six Blinks: The AP board is responsible for four or six blinks of the power LED. The DTV9V, and SUB_5V sources are produced on the AP board. The MPU IC1100 monitors for their presence when the unit is connected to AC Power. A short or open circuit on the A board may also be responsible for their absence.
Nine Blinks: Nine blinks of the power LED is due a short circuit in the audio output circuit (s) of the unit. The audio output circuit is located on the A board. Confirm the status of the speakers. If defective, perform a replacement. If ok, replace the A board.
Ten Blinks: Ten blinks of the power LED indicates a malfunction of IC4200, the frame converter. This IC resides on the A board. Therefore ten blinks of the power LED requires the replacement of the A board.
Jan 24, 2009 | Panasonic TC-32LX70 Television
Oct 23, 2008 | Panasonic TC-32LX60 32 in. LCD Television
Sony tv wont start up???
The flashing should be a repeated number of blinks. Please post that count as that will indicate the circuit in which the set detected a problem. The set is in protective shutdown. Using hte blink count, we can determine the possible problem and solutions.
Dan
Jun 18, 2008 | Sony FD Trinitron WEGA KV-32FS100 32" TV
Televison & Video Logo
2,266 people viewed this question
Top Televison & Video Experts
Electro Med Services...
