Question about Kenmore 15864/15862 Top Load Washer
Kenmore Series 90 Washer dial isn't calibrated correctly
The dial to choose the wash cycle seems to be calibrated incorrectly following my 9 year old son's attempt to do his own laundry. I know this seems easy to solve...but i can't get the knob off and can't figure it out!
  • 640 Answers
Push the knob to off and turn knob only to you left...off is in..always unplug unit first
Posted on Dec 26, 2008
Kenmore 600 series washer
The dial probably was rotated counterclockwise. That can mess up performance.
Jan 26, 2014 | Washing Machines
Kenmore Series 90 washing machine, won't start cycle
First, see the Sears Parts site for your washer:
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=110.26912691&pathTaken=partSearch
Next, see the Whirlpool / Kenmore Service manual for top load, direct drive washers:
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
I hate to say it but it sounds like a Timer problem.
I'd use the troubleshooting section of the Service Manual and the timer testing procedures to confirm the problem.
Note that there are two types of timers with different procedures to remove them.
Also see the following for how to release the console for access to the timer and other controls.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131&osCsid=5216f244d51176ce1069bbf148b14335
May 07, 2010 | Kenmore Washing Machines
We have a 9 year old Sears Kenmore 90 Series top loading washer. We have noticed that it makes a loud slamming noise as it goes into the spin cycle! What the heck is going on???
If I remeber correctly
There are three springs that hold the tub to center.
either they have lost there tension or one is no longer connected.
Feb 22, 2010 | Washing Machines
Doesn't agitate and spin cycle work when reset
you have a worn motor coupler
you can order a new one at sears
and its a ver y easy repair
Oct 06, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
We have an Kenmore 70 Series Heavy Duty Plus washing machine that is about 20 years old. The washer stops after the wash cycle and we have to manually move the dial one notch. The washer then completes the...
This is the deal, your washer is way to old to fix. The board is going bad and that is why it will not cycle properly. It would cost about $150.00 to fix and that does not even include labor. Consider craigslist as you can find some great deals from 40-60 for a newer one. Hope this helps.
JimmyC
Sep 26, 2009 | Kenmore Washing Machines
Kenmore 90 series washer will get stuck in between cycles
Sounds like the timer has failed. It's a common problem.
Part number 8545379, $83.69 from SearsPartsDirect.com
Feb 04, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore 90 series slow spin
You need a repairperson. It is probably a belt or a switch problem.
Jul 29, 2008 | Kenmore 22422 Top Load Washer
Kenmore 90 Series, washer Model 24924200
probably a sticky or broken bearing clutch, call a repairman. Probably be under 100k dollars to repair.
Jan 29, 2008 | Washing Machines
Intermittent spin cycle on Kenmore 90 Series washer
You may try the speed selection switch.....Ive had problems with these.
Jan 23, 2008 | Washing Machines
Kenmore 15864/15862 Top Load Washer Logo
170 people viewed this question
Sal De
fordexpert
Robert Rankin
