Question about Refrigerators
PFSS6PKWASS GE Refrigerator Ice Maker problems
My french door GE PFSS6PKWASS refrigerator is a little over a year old and it stopped making ice a few weeks ago. This is the second time we've had this problem (last time was when it was 3 months old), but last time it was still under warranty and they had to replace some parts.
Is this a recurring porblem with this model? Is there a way to prevent this from happening?
  • jelasea Feb 20, 2009
    We have the same problem in that the ice continuously gets stuck in the Ice drawer and the GE Tech said it was a bad design. The screw mechanism that is supposed to feed the ice through the trap door is off-set and therefore piles the ice up at the trap door area. The Tech said the only solution is to empty the ise every few days at the trap door area... A pain for such an expensive fridge.
  • Anonymous May 19, 2009
    Ice gets stuck inside and does not dispense properly. The ice sticks together and the auger will not dispense it.
  • 641 Answers
SOURCE: Ice maker freezes up
In case that the ice maker fill tube is blocked with ice (as per your thought), melt the blockage using a hair dryer, but be careful to not melt any plastic parts!!! Also check the water shut-off valve and the water-inlet valve for working properly. Does this problem appears immediately after the water leaking repair ? If so, its look like the water leaking problem was "solved" by blocking the fill tube to the tray !!!
Posted on Apr 10, 2006
  • 116 Answers
SOURCE: Amana French Door Refrigerator "on" but no cooling; freezer still works
There are 2 possible problems. One is the defrost cycle is not working properly this is usually indicated by a large amount of frost on the back freezer panel. If so, the circuit will have to be repaired and the evaperator thawed to remove the ice build up. The other is the fresh food damper is not working properly this is behind the "lump" in the back of the fridge compartment above the top shelf, remove the louver panel to see if it is open or closed. closed will be warm open should be cold. The water dispenser reservoir is probably frozen due to poor air circulation.
Posted on Mar 11, 2007
huuum
  • 750 Answers
SOURCE: Regrigerator shows error code 1F
Hello tr-6
Welcome
You Wrote,
LFX25960ST LG FRENCH DOOR REFRIGERATOR DATE OF PURCHASE 7-7-07 DELIVERED 7-13-07 ICE MAKER REPLACED ABOUT THIS TIME LAST YEAR AFTER TWO MONTH WAIT. NOT PLEASED WITH PERFORMANCE OR SERVICE TO DATE. REQUEST THIS PROBLEM BE COVERED BY WARRANTY.
Below is the service manual And the explanation for your error.
Thank You for using our site.
Huuum
Please remember to leave a solved rating.
Error Detection Category
ERROR CODE : IF
Abnormality of
BLDC FAN Motor
for Ice Making
Error Generation Factors
It is caused when F/B
signal isn’t over 115
seconds during BLDC
FAN motor operating
Remark
Poor BLDC Motor
connection, DRIVE IC, and
TR
Resource reference located here:
http://136.166.4.200/contents/Fridge/LFX25960/LFX25960_Service_Manual.pdf
Huuum
Posted on Oct 12, 2008
SOURCE: lg refrigerator LFX25960SW
the answer to the problem from a LG training class is... if the bottom left side of the refer is freezing food the liner has split no fix at this time. some people have beEn able to turn off the ice maker and the food will stop freezing. the ice maker has a fan in the freezer that blows all the cold air up the ice making Cobby.
DO THIS ONLY IF OUTA WARNTEE
for most of you with bad ice makers you could drill a hole in the very bottom of the ice maker towards the front right under the little metal arm in the wight plastic AND DONT DRILL DEEP just enough to put a hole in the outer case then hit it with a blow-dryer for a little bit to remove ice that's blocking the gear on that arm this works 5 outs 10 times
Posted on Oct 29, 2008
  • 1891 Answers
SOURCE: Samsung French Door Refrigerator not cooling
it's only 4 weeks old ./ don't mess with it it has a warranty you may void it if you work on it . it is probably in the main digital control in th fresh food .. but i would call the seller and they can set up a service for it .. mm
Posted on Dec 24, 2009
Ge refrigerator gts22wcm ice
Inspect the ice maker itself, sounds like either you have a jammed cube or your ice maker is not turning on heater to eject ice cubes from mold. If heater is the failure - replace ice maker. If unit is jammed, clear the ice maker mold and allow to cycle to see if damage was done to gear or ice production is restored.
Good Luck
Oct 23, 2013 | Thermador T36IT71NNP (196 cu ft) Bottom...
GE french door bottom freezer will not make ice
HI.DIFFICULT WITHOUT A VISUAL.BUT TRY MANUALLY PUTTING SOME WATER ON THE ICE TRAY AND TRY.IF ICE DROPS ONCE THEN IT COULD BE THE VALVE BRAKE IN THE LINE OR THE ICE MACHINE ITSELF GOOD LUCK ALI
Jul 12, 2012 | GE GFSS2HCYSS 22.0 Cu. Ft. Stainless Steel...
Water dispenser in ge profile pfsf6pkx 1.2 year old fridge works fine, icemaker stopped making ice, no sound of water refill from maker, ice lock not on, recycled filter, any ideas before we spend $ ?
Have the same model and same exact problem. Did you find any solution? If so, pls post - willing to try anything before the $200 service call. Thanks and good luck on yoiur situation.
Oct 20, 2010 | General Electric PFSF6PKX Bottom Freezer...
GE profile Artica, MDL# psc23mgnabb, ice maker won't make ice, plus refrigerator side is freezing the contents
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
Aug 27, 2010 | GE Profile PFS22 33" Artica French Door...
Our GE Profile Ice maker is not making ice,and water is not cold?
heatman101
Aug 24, 2010 | GE Profile PFS22MBS Bottom Freezer French...
Kitchenaid ice maker not making ice
first check the tube running to the ice maker where the water flows in see if it is frozen if not take the cover off the ice maker front and see if the little tabs in the middle of the gear is broken there are two one might be broken off
Mar 30, 2009 | Refrigerators
Ice maker doesn't make enough ice
Try turning the thermostat all the way down if it works you can back it down.
Nov 21, 2008 | GE Profile PFS22 33" Artica French Door...
Ice maker LFX25960ST
3 months old?? warranteed for a year call for service , you bought new so you wouldnt have to fix it!
Oct 31, 2008 | LG LFX25960ST Stainless Steel French Door...
Refrigerators Logo
1,150 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
