Question about Kirby G5 Bagged Upright Vacuum
Kirby vacuum problem
While using my kirby every time i bump something it shuts off and i have to hit the power button to cut it back on. this happens every time very annoying. help!!!!!!
  • wbigsby Nov 10, 2008
  • Kirby Expert
  • 324 Answers
I suspect the safety/power switch. When nozzle is on the Kirby the protrusion on the nozzle casting must press the switch on the front of the unit (circled in red in the pictures below). See if that protrusion is not chipped off. It may be that a hook or even both are damaged (circled in blue) so nozzle is a bit loose and when you bump something it nozzle moves just releases the switch enough to shut the vacuum off. Hold the nozzle and try to move it. See if it is loose on the unit or not.
It could be the faulty switch too.
Posted on Nov 06, 2008
Kirby g5 self propels too fast
the slide has shifted forward slightly, this happens when the kirby
is hit against walls and skirting boards. you will need a service by your local kirby engineer. see for local agent
Mar 22, 2013 | Kirby G5 Bagged Upright Vacuum
I have Kirby sentria that shuts off while using the rug attachment and won't start until I change to the hose attachment. I have had it in Kirby repair store 5 times, cord replaced. Took it back t
power switch faulty, slow speed terminal inside switch is burnt,hence
intermittent fault, hose uses second speed different lever inside switch
Oct 12, 2012 | Kirby Vacuums
Kirby G5 only works when the power button is being pushed.
power switch damaged contact your local kirby agent for repair
Jun 02, 2012 | Kirby G5 Bagged Upright Vacuum
I was sweeping my floor I turned it off, then when I went to turn it back on it wouldnt turn on? HELP
Check the power button switch, it is often cause vacuum to shut off. Thus cutting current flow into the vacuum circuit. Also check the cord for intermittent connection. The cord is subjected to bent, twist and other abuse action while vacuum is in use.
Good luck.
Jul 17, 2011 | Kirby Ultimate G Bagged Upright Vacuum
I have a kirby sentria. vacuumed up my son's headphones and immediately shut if off. took brush off, unwound headphones, put it back together. when i turned it back on, the belt snapped. so i went to...
Take the front off the vacuum and check inside both the front portion and the canister for additonal clogs. Sometimes something will get caught in the impellor, causing the motor to overheat. Since there's little suction and the smell, I'd guess this is what happened.
Jan 30, 2011 | Kirby Generation 3 Bagged Upright Vacuum
Power cut out during cleaning
1 could have hit the thermal shut off. if it gets to hot they shut off, or it could be the cord some times they just go bad or it could be something else. Good Luck!
Jul 28, 2009 | Bissell 1698-1 PowerSteamer ProHeat Plus...
Ran over cord and the vacuum shut down, won't
sounds like it might have broken a wire in the cord and may have to replace the cord unless you can find the broken wire and splice it back together
Apr 23, 2009 | Kirby Generation 3 Bagged Upright Vacuum
Kirby Diamond Edition (no power)
You just check the bag "boot" to see if there is something worn down enough to keep the vacuum from turning it back on. If it is worn, buy a new mini-emptor assembly and install it and your vacuum should work fine.
Jan 04, 2009 | Kirby G5 Bagged Upright Vacuum
Kirby G5 Bagged Upright Vacuum Logo
322 people viewed this question
Top Kirby Vacuums Experts
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
