Question about Canon I960 InkJet Photo Printer
Canon i960 Waste ink tank is full....I need help with the codes and disassembly for replacement of the sponge that soaks up the used ink.
I cleaned the waste tank pad following the directions at
http://forums.techguy.org/hardware/421538-solved-printer-used-ink-tank.html
These were from Lanmaster.
Note carefully how you take it apart - with photos if necessary - so re-assembly goes well.
Wear gloves!
Posted on Nov 05, 2008
I have a Canon pixma MP130 It is saying waste ink absorption is almost full. How do I fix this
I've used 99% Isopropyl Alcohol in some. Is this a sponge or just a cup like absorber? For the sponge I usually remove it and soak it in alcohol and then, wearing rubber gloves, squeeze out the ink/alcohol mixture (multiple times if needed) for the cup type, I just use Q-tips to remove what I can and then clean the surface with Alcohol.
hope it helps, if so do rate the solution
Nov 26, 2010 | Canon Office Equipment & Supplies
Waste ink tank full
hi can yo please give out the part number and more detail of the problem
Sep 07, 2008 | Cannon Office Equipment & Supplies
Canon i960 puts up an error code "USB003" used ink tank almost full. how do i reset the printer? please.
Start with the printer OFF
1. Hold down RESUME and then hold down POWER
2. Release RESUME
3. Press RESUME twice, then release POWER
4. Let green light blink until printer is done futzing
Select function with RESUME press POWER to execute:
presses - light color - function
Number of presses - light color - function
0 presses - green - Test print (or exit service mode on i960)
1 press - orange - EEPROM info print (plus grid nozzle diagnostic on i960)
2 presses - green - EEPROM initialize
3 presses - orange - Reset waste ink counter
Mar 06, 2009 | Canon i950 InkJet Photo Printer
Waste ink absorber full--where do I get it serviced? or, can I do anything?
I sent you a solution
here it is again
let me know if you require anyhthing else
Reporting solution by daweed:
"WASTE TANK ALMOST FULL or FULL ERROR MESSAGE PROBLEM
This is true with many Canon Ink Jet Printers: Eventually, you'll get an error message "Waste Ink Tank Almost Full, Contact Your Canon Repair Center". Canon is totally sly about this, and is actually a pretty ridiculous design flaw that they should be ashamed of- planned obsolescence. Anyway, don't let this problem discourage buying an otherwise fantastic Canon printer.
This problem will also be indicated by flashing orange lights on your printer. Different flashes for different models.
LOOK IN YOUR PRINTER MANUAL TO KNOW WHAT NUMBER OF FLASHES INDICATE. In any case, your computer printer software will also tell you exactly what is going on.
You need to do this after you get the WASTE TANK ALMOST FULL message and the printer continues to work, but BEFORE the WASTE TANK FULL message and the printer completely stops. I think. ;-)
Here's the fix:
The waste ink take is actually just a felt pad that sits under the printer mechanism inside the case and absorbs the ink from your cleanings. From what I gather, its both a time consuming and expensive proposition to take to Canon to fix. And they won't tell people how to do it themselves. Well, I WILL. And this works.
Remember of course, you've got to cycle the cleaning process a huge amount of times to get this to occur.
But when it does, there is a fix-it-yourself solution that is both safe and effective for the printer, and free. You have to be slightly mechanical to do this. If you get this message and you've never used a screwdriver and are all thumbs, well, Canon gotcha. But give it a shot even then, or give it to someone halfway coordinated to do this for you.
You may RESET the printer code first if you like or do it after you clean the pad
In some cases you may need to REMOVE THE PRINT HEAD FIRST or the reset code will not work. This was true of the S900 and i960 so, remove the print head first before doing this reset.
This is the correct code for the S and I (like i960) series of printers. (M series below this)
1) Power off printer
2) Hold RESUME button then press and hold POWER. (The beeper MAY sound once, or may not depending on your model.)
3) Hold POWER and Release RESUME.
4) Press RESUME twice then release both POWER and RESUME buttons.
5) When the indicator lights steady, press RESUME 4 times (for the S900, 3 times for the 8200 apparently).
6) Press power to set data.
7) Print away!
For other codes for other printers and more info go here to this big forum (but try the above first) Fix Your Own Printer Generally many of Canon's models use exactly this same code, the i models use the same code, all the s models use the same code.
I did this and it works fine! No more error messages and so..."
Sep 04, 2008 | Office Equipment & Supplies
Canon i950 will not reset counter for waste tank full.....
For Canon i850, i950, S600
2. release RESUME
3. press RESUME twice, then release POWER
Jun 04, 2008 | Canon I990 InkJet Photo Printer
My canon printer will not print - i get a waste ink reserve tank if full. where is the tank and what do i do to get my printer working again. thanks
Your waste tank is full. It is located at the bottom side of your unit. Actually, the tank is a flat sponge or foam like material about 1/4 inch thick. I have experience removing it and cleaning it by soaking it in water and soap, but I wouldn't suggest you do it cause it is hard to remove it and pretty messy to clean it. Take it to the service center.
May 18, 2008 | Canon Office Equipment & Supplies
Waste Ink Absorber full - Canon Pixma
Here's the fix:
7) Print away!
Mar 13, 2008 | Canon PIXMA iP90 Mobile Printer
The waste ink disposal is almost full and it won't print
The waste ink absorber is almost full. Press [OK] to continue but early replacement recommended. <See manual>
WASTE INK NEAR FULL The printer has a built-in waste ink absorber to hold the ink used during print head cleaning, for example. This error message indicates that the waste ink absorber is nearly full.
Press the OK button to cancel the error so you can continue printing.
Before the waste ink absorber becomes completely full, contact a Canon1.gif service representative. (You will need to replace a particular part of the printer.) Canon recommends that you call for service as soon as this error occurs. Once the waste ink absorber becomes completely full, printing cannot be performed until the Waste ink tank is replaced.
this answer is directly from canon
Jan 30, 2008 | Canon Pixma iP6210D InkJet Photo Printer
I960 canon printer
Lift lid ,let carriage stop in middle, un-plug the printer > Remove all ink tanks > Remove print head > Soak print head in > 3 parts very warm water an 1 part ammonia over night. Rinse under faucet with water directly over ink ports, shake out excess water,(if when you shake it out and if color still comes out repeat soaking for another hour or two and rinsing again ,HAD TO DO MINE TWICE) let air dry. (hair drier helps) Cured my problem for a while ,but if not used almost every day, this will happen again, I also use compatible ink tanks. Don'T believe the inks are as good as Canon Ink. But who the hell can afford them. So fill your owe with Canon ink from Canon. Still seems that the cyan always dries up first. Good luck Lestero1
Oct 18, 2007 | Cannon Canon i960 Photo Printer
Canon I960 InkJet Photo Printer Logo
342 people viewed this question
old marine
old marine
