Question about Maytag LAT3600A Top Load Washer
Cold water continues to run during entire wash cycle
The washing machine fills as should; but when it kicks the water off, the cold water still runs even at a trickle. If you are not carefull it can overflow the tub if you are using an ex-large load..when the cycle is completely finished the cold water shuts off after the spin cycle but it does take alittle time for it to completely stop...not for sure if we need a new switch or inlet valve or something else....thanks for any help at all.
    President:
  • 878 Answers
Adrea, sounds like you need a new valve. When it's doing this leaking, unplug the washer. If it's still leaking you know for sure it's the valve. Part number for the model posted is 22002360. Catriver..post back.
Posted on Sep 30, 2006
Washer only washes with hot water
consult your owner manual about you are unsure about if the machine is acting anormally
Some machines, is running hot water during cycles, other cold water during cycles.
God bless you
Jul 18, 2012 | Washing Machines
My washer will fill with water during the wash cycle just fine, but during the rinse cycle the water just trickles in. The water lines seem to be fine. What else could be causing my problem?
usually the wash is a mix of hot and cold and the rinse is just cold, that said, it is most likely a problem with the cold water supply. check to make sure the cold water valve is all the way open and the hose isn't kinked. If those are ok turn the water supply off and remove the supply lines on the machine side, you will see a screen inside the washer that may be clogged with sediment. If so, just clean it out and put it back together. You may also want to run a wash cycle on cold only to see if it fills slowly for the wash cycle. If it does fill slowly on cold you have low pressure on the cold side.
Jan 07, 2011 | Whirlpool Ultimate Care II LSQ9549L Top...
Cold water continues to run through the entire wash cycle.
Need a new fill valve . The part that the hoses attach to on the dryer.
Oct 27, 2010 | Maytag MAH8700A Front Load Washer
At rinse cycle, cold water won't cut off after
if you unplug the washer does the water continue to enter? if the answer is yes you have a bad fill valve. is it only when you use cold water? what is the model number?
Apr 05, 2010 | Washing Machines
My washer goes through the cycle but the cold
This sounds like your water fill valve is bad and will need to be replaced.
Feb 01, 2010 | Maytag LAT2300 Top Load Washer
Whirlpool AWO3761 stuck mid-cycle
The cycle doesn't advanceWhen the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
  • Jul 06, 2008 | Whirlpool AWM6100 Front Load Washer
    Maytag performa washer hot water runs continuously
    Littleone.. please check your instructions.. some washers now dont need Hot water connection to them...they heat their own as part of the efficiency settings on the wash programmes themselves!
    Regards Faggly
    Mar 19, 2008 | Whirlpool Estate TAWS750PQ 27-Inch Washer
    Maytag LAT3600A Top Load Washer Logo
    163 people viewed this question
    Top Maytag Washing Machines Experts
    Bill Long
    Ronny Bennett Sr.
    Ronny Bennett Sr.
    John Tripp
    John Tripp
    Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
