Question about InFocus ScreenPlay 61" Rear Projection HDTV
Ghostly picture We thought that the lamp was burned so we purchased the new lamp for $600, replaced the lamp the picture is still ghostly. The sound is good but can't see the image/picture, just shadow. Help!
  • india518 Apr 01, 2009
    How do I check the color wheel? There is nothing about a color wheel in the user's guide. We have also replaced the lamp, this is our 2nd lamp and we replaced it about 2.5 months ago.
    Genius:
  • 2,920 Answers
Have you checked the colorwheel onthe tv to see it if its still good?
Posted on Nov 03, 2008
LG LED tv no picture but do have sounds,
the LCD screen has a light source (like a monitor). It can be an lamp (like a projector TV), a mercury tube (like a monitor) or a LED-based lamp (so-called LED TVs have that, not to be mistaken for OLED TVs, where each pixel is a LED). I don't believe this model is an OLED. It could be one of the others, most likely a mercury lamp that lays at one side of the monitor and illuminates the screen.
You could shile a flashlight to the screen (from close distance) while the TV is powered on and see if any image is being formed on the LCD. If it does, the lamp is burned out and needs replacing. If no ghostly image is seen, then it could be the video processor and then it's a bigger problem.
Apr 09, 2014 | LG 42LC3R 42 in. LCD TV
I have a sony kdf 50e-2000 the green light goes on then it goes to thr red blinking lamp light. I have no sound or picture. If I replace the lamp light will I get sound and a picture again?
Yes, if you have not replaced the lamp since you purchased this TV.
Lamps usually last about 6000 hours.
I've seen lamps last much longer than 6000Hrs, it all depends on the usage.
Remove the lamp from the TV and do a visual inspection, see if there's a crack on the glass or the bulb.
If the TV is few years old then the Lamp may be bad.
For a new Lamp: 800 638-3328
https://www.encompassparts.com/
DO NOT BUY the lamp from ebay
Good luck to you.
Nour Sabre
www.tvservice.com
May 24, 2012 | Sony KDF-50E2000 50" HDTV
62HM 95 TOSHIBA. HAD THE PICTURE JUST GO BLACK THE OTHER NIGHT. I HAD A LAMP FOR IT GIVEN TO ME BY A BUDDY IT MAY BE A USED ONE NOT SURE. REPLACED BULB TV CAME BACK ON BUT PICTURE IS TO DIM TO WATCH. DONT...
These Toshiba DLP's were lemons.
There was a class action lawsuit in the US and Toshiba were forced to issue a recall on the lamps. Toshiba replaced the first lamp for free but when the lamps are burning out every 6 months at a replacement cost of $200 these tv's are expensive to run.
Sounds to me like the light engine has failed. This will probably be a $800-$1000 repair.
Scrap it and take the hit.
Nov 01, 2010 | Toshiba 62HM95 62" DLP HDTV
There is no picture or sound and the lamp light is red.
Most likely the lamp is burned out buy you a new one and replace it. It is consumer replacable.
Aug 06, 2009 | Panasonic PT-61DLX76 Television
TOSHIBA 62HM15A
It sounds like you need to replace the lamp. Take the lamp assembly out and inspect it. It will have a white smokey look or may be cracked if it is bad.
Aug 02, 2009 | Toshiba 62HMX84 62" Rear Projection HDTV
My 60" philips tv
sounds like the LSB board, which is a common fault with your model. You can get a new DPTV 300 series LSB at the following link.
http://servicemanuals.vstore.ca/
Sep 27, 2008 | Philips 60PP9202 60" Rear Projection...
Picture on my TV starts to flash after a few minutes of use
This problem is common in Samsung projection TVs. The DMD board is going bad.
Mar 21, 2008 | Samsung HL-R6167W 61" HDTV
Sony KDF-E42A10 Screen is Not Bright
try a lamp first, through best buy their about $150 -250. If that fails it might be the optic block assembly which is about $1,000, and i just recently had replaced, and the picture is as bright and clear as when i got it two and half years ago
Sep 01, 2007 | Sony KDF-E42A10 42 in. LCD Television
Sony Wega KDF-55WF655 blue ghost problem after replacing lamp
It is a defective light engine and it must be replaced. I hope you have a warranty because Sony will not help you.
Apr 06, 2007 | Sony Grand WEGA KDF-55WF655 36" Rear...
InFocus ScreenPlay 61" Rear Projection HDTV Logo
233 people viewed this question
Top InFocus Televison & Video Experts
Donni Steen
rostit
Are you an InFocus Televison and Video Expert? Answer questions, earn points and help others
