Question about Amptron CMV-922D 19" Monitor
My monitor remains black
My cmv cm-922d 1 year old monitor has a blank black screen. The blue power light goes on but nothing on the screen comes on. I have tried different cables, graphics cards, and computers. The screen still doesn't display. Clicking the monitors menu button doesn't do anything either. Help!
  • Anonymous Jan 19, 2008
    computer monitor working properly at the start but it turn suddenly black and i cant see any display but the green light of the monitor below keep flashing
  • davcost Mar 05, 2009
    CMV CM-922D monitor not working, power supply OK, blue power light comes on then screen illuminates for 3 seconds then goes out. Stopped working and then worked intermittently for a couple of weeks now not at all. No loose wires or connections, please help or it goes in the bin, what a shame. David.
  • 37 Answers
Well your screens broken mate the only thing you can do is get a new one
Posted on Aug 30, 2009
I NEED A POWER CORD WHERE CAN I GET ONE?
The power cord should in this case be the same as the one used on a desktop computer. It a 3 connection type plug in.
You will be able to get it from your computer shop of choice.
damnor01
Apr 04, 2011 | Amptron CMV-922D 19" Monitor
Monitor goes blank less than a second after turning on.
Sounds like either there is a bad connection from the computer to the monitor, or the monitor has a faulty power regulator, causing the monitor to overheat prematurely, and shut off.
Feb 21, 2008 | Proview PL926WBi 19" LCD Monitor
Why does my HP vs17 monitor screen keep going to blank black screen like it turned off but did'nt.....blue power button light is still on? Everything is running but no picture.....keeps happening everytime...
this old monitor has 2 issues.
1: it has CCFL tubes that love to burn out (backlamps)
most this old are long go, yell,dim.,blinking or DEAD.
2: push the menu button on front of mon. turn off power saver.
3: if the PC goes to sleep, or hibernete mode (parked)
then that is 100% normal
if you dont like feature then go to windows control panel
click power, ICON and turn off all monitor sleep /hibernate modes.
that assumes windows, no OS stated.
if the lamps are dead,
use flash light pointed to sceen, see data. ? bingo for bad CCFT tubes.
as seen here
http://www.pcdied.com/monitors.html#flashlighttest
Jan 12, 2018 | HP Vs17 17" LCD Flat Panel Monitor
IBM T61 remains with dark blank screen but is on.
Connect it to another monitor,and see if it comes on. Your screen may be damaged.
Feb 22, 2010 | Lenovo ThinkPad T61 Notebook
Monitor Screen goes black every few seconds!
Check the capacitors on your monitors circuit board. If they have opened up at the top, they are fried. Buy new ones, make sure nothing has leaked from the old ones, and replace them.
Sep 26, 2009 | Dell SE198WFP LCD Monitor
Blue power button flashing with blank screen
This is most likely the power inverter board in the monitor - this is common in many monitors. If it started taking longer and longer to display an image, and the power light is blinking on-and-off, that's the problem. You can confirm that it's the monitor and not your computer or the cable by plugging in another monitor if you have one to try.
If it's under warranty, send it back, if not, there are inverter boards for many common models of LCD monitors that are replaceable. The board can run anywhere from $50 on up. Depending on how old it is, you may find it better to just replace it with a gently used one from ebay.
Jan 03, 2009 | Dell E173FP 17" LCD Flat Panel Monitor
Screen goes black
It could be a bad backlight bulb.
Sep 08, 2008 | HP vs15 15"LCD Flat Panel Monitor
Computer monitor screen remains black
try giving the monitor a hot slap or spank at the back, believe me, you'll be surprise, you've got nothing to loose
Jul 20, 2008 | HP Pavilion F1503 15" LCD Flat Panel...
CHIMEI CMV T39D
Sorry to hear that you are having problems with your monitor. While the monitor is turned on and plugged up to your computer system, try looking very closely at sharp angles from above, if you can barely see your desktop the problem is the back lamp inside your monitor. Make sure the settings are not in sleep or standby mode first. If it is your back lamp you can check the following websites for information on how to fix them: The first one is here
The second site requires free registration and you will find the information you need in the members section, the main page is here. Since your monitor is less than a year old, you might want to consider sending it back to the manufacturer since they usually give you a 1-3 year warranty on the products. The only thing you should have to pay is shipping and handling. You stated that you changed the cables and tried hooking up the monitor to a known good system and that still did not help the problem, so I believe the problem may be the back lamp. I hope this helps fix your problem and if you need further assistance please let me know. I wish you the best of luck.
If you would not mind rating my help, I would really appreciate it. Thanks
Jul 07, 2008 | Chi Mei Corporation CMV-T39D Monitor
Problem monitor
Hi, Sounds either a backlight problem (inverter or tube light) or the display interface. Since you have confirmed that it is your LCD monitor, your best bet perhaps is to seek the services of a qualified professional. Should you venture in doing it yourself (DIY), You need to open up the casing. A step by step procedure is better illustrated here . The working principles of notebook/laptop displays are nearly identical to your LCD. Hope this be of some help. Post back how things turned up or should you need further information. Good luck and kind regards.
Sep 25, 2007 | Amptron CMV-922D 19" Monitor
Amptron CMV-922D 19" Monitor Logo
269 people viewed this question
Top Amptron Computers & Internet Experts
Alun Cox
David Payne
David Payne
Are you an Amptron Computer and Internet Expert? Answer questions, earn points and help others
