Question about Panasonic DMR-E50 DVD Recorder
DMR-EH50 I have lost all video and sound, live or recorded.
  • 4 more comments
  • roy85215 Nov 04, 2008
    The timer does keep counting when a DVD disk is inserted or when I select HDD then play. The machine was left playing over night and the next morning there was no picture or sound.
    I nhave a manual it won't help.
    I have lost all video and sound, live or recorded. Comment by roy85215, posted on Nov 04, 2008
    I have a manual it won't help.
    I have tried this but what I want is a rel solution to repair this machine.
    this won't fix anything
    How about a real technical answer that would tell me what circuit board to replace?
    Scholar:
  • 124 Answers
Hi There, You are simply having a setting issue not a hardware failure. Your DVD player has been accidently set to Progressive Scan. Before I can help you to reset the unit, I need to know your connection. Are you using the Yellow, Red and white cable? If so, where is it connected on the unit ( Front or Back). Thanks, Mike
Posted on Nov 05, 2008
Try to plug your dvd player into a different tv port !!!!
good luck
Posted on Nov 04, 2008
  • Anonymous Nov 04, 2008
    the only circuit you can replace is the sound circuit located where you plug in your video and sound cables !!!
    good luck
    Brigadier General:
  • 3,614 Answers
Try getting the manual here";
Operating Instructions DMR-EH50
  • Panasonic Master
  • 19,396 Answers
Check the cable eventually try a replacement cable.
  • Ginko
    Ginko Nov 04, 2008
    Check the cable, and eventually try a replacement cable to ensure it is not a cable problem.
    Try also switching the video input button on your TV remote until you get the DVD signal back.
    Most likely it is a faulty cable.
  • Ginko
    Ginko Nov 04, 2008
    Try also unplugging the power cable for twenty minutes, to see if draining power completely from the set can help, then isert a different DVD to test it.
    If this does not work , a factory reset is performed by unplugging the unit, and holding down the start or play button (try both), while you connect power cord back (be careful doing this).
    If that still does not work, then the unit is faulty.
Panasonic DMR EH50. Picture is dominated by the colour pink. TV not affected.
Please check your Blue and Red component cables on both the recorder and your TV. One is probably loose.
Apr 07, 2014 | Panasonic DMR-EH50 DVD Recorder
Pan DVD Recorder DMR-EH50
Press enter and 2 at the same time for more than 3secs
Oct 29, 2009 | Panasonic DMR-EH50 DVD Recorder
Looking for the region codes!
I want to make my panasonic dmr-eh50 to multi dvd region player. How to get the dvd multi region code?
Jun 24, 2009 | Panasonic DMR-EH50 DVD Recorder
Trying to make DVR work after 2-17-09
I have been able to record down converted HDTV shows on my Panasonic DMR-EH50 recorder directly to the unit's hard drive and/or directly to a blank DVD-R disc.
I do not know of any DTV converter box that can provide the proper codes to the Panasonic DMR-EH50 to allow recording and scheduling of shows using the unit's built in TV Guide menuing functions (the program recording codes are essentially VCR Plus codes in the USA and VCR Video codes in the UK, and this technology was previously owned by TV Guide/Gemstar but was purchased by Macrovision within the past couple of years.)
When the DMR-EH50 is hooked up to standard RG-59/U coaxial TV cable, the cable company provides the specific VCR Plus recording codes, as well as auto setting the time and date information required for the TV Guide recording schedule menus. The VCR Plus recording codes are sent via the cable company through the coaxial cable to the end consumer's recording device. Since Gemstar's VCR-Plus patents are now owned by Macrovision, I am not sure of how this works (or will work) for non-cable/non-satellite customers or if such codes will be made available by Macrovision to record shows when one receives HDTV signals (or down converted DTV signals) from an over-the-air antenna.
Though the DMR-EH50 recorder can only record at Standard Definition (SD) broadcast resolutions, I connect the DMR-EH50 to my High Definition TV using the three progressive scan YPBPR output cables and switch my HD-TV into the YPBPR mode when I want to watch shows from the DMR-EH50.
YPBPR are the analog video signals carried by three color coded component video cables. The green cable carries the Y signal; the blue cable carries the PB signal; and the red cable carries the PR signal. The added benefit of using the YPBPR hookup is that you can 'up convert' a standard DVD disc (non HD Blu-Ray disc) in progressive scan mode to somethin akin to 720p resolution using the DM-EH50 (or any other progressive scan DVD player) to get a better quality image on your HD-TV.
Visually speaking, the same appears to hold true for playback of programs recorded on the DMR-EH50's hard drive even though down converted via the DTV converter box, and when played back on an HD-TV using the YPBPR progressive scan cabling hookup.
I also been able to successfully record programs from the DTV converter box to the DMR-EH50 recorder in both 16:9 wide screen and 4:3 normal aspect ratios, but again only in Standard Definition quality.
For NTSC and PAL formats, the correct aspect ratios for any particular TV (the rectangular height and width of your output resolution for a TV screen) can usually be setup correctly for most any DTV converter box by going carefully through the menus on the converter box. Though the converted DTV often will yield 'better looking TV' than cable, it's certainly not high definition however, as the purpose of any DTV converter box is * not * to yield a High Definition digital TV signal but a lower quality Standard Definition signal for viewing on older SD-TVs.
We must remember that what is happening here is that (by NTSC USA standards), we are transcoding (i.e., down converting) an over the air 1920 x 1080p (progressive scan) High Definition digital broadcast signal, captured by your over the air antenna, back to a Standard Definition 720 x 480 resolution analog broadcast signal (the 720 x 480 resolution is a 4:3 aspect ratio.)
Hope this helps a little -
Greg Loveria
Conklin, NY USA
Jan 03, 2009 | Panasonic DMR-EH50 DVD Recorder
Setting a new Panosonic TV
If it has no freesat tuner then you can only record what the TV is viewing/tuned to as an output from the TV.
Mar 21, 2017 | Panasonic CT-27SF36 27" TV
Check your user guide for the answer.
Nov 08, 2008 | Panasonic DMR-EH50 DVD Recorder
No video no sound
may be recording on the wrong input. Do check cable connections
Nov 04, 2008 | Panasonic DMR-EH50 DVD Recorder
DMR-EH50 DVD Loss of TV Guide and Auto Time Update.
http://www.pasctraining.panasonic.com/specialapplications/productfirmwaredownloads/DVD.ASP
the firmware and instructions are located there.
Jun 26, 2008 | Panasonic DMR-EH50 DVD Recorder
Panasonic DMR-EH50. Dubbing NTSC VCR tapes to HDD
That's normal with different region signals. Only a multiregion recorder/player combo will transfer properly
Jan 03, 2008 | Panasonic DMR-EH50 DVD Recorder
Does the DMR EH50 work with satelite tv
Yes Connect using Scart
Sat to EH50, Sat to TV as per page 15 of the manual and it should work fine mine does
Dec 05, 2007 | Panasonic DMR-EH50 DVD Recorder
Panasonic DMR-E50 DVD Recorder Logo
203 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
