Question about Sony FD Trinitron WEGA KV-32FS120 32" TV
Scrolling endlessly through channels
When I turn the tv on, it acts like the Video Input button is being pushed (scrolls through video 1/2/3 and dvd), but bounces back to video 1 often. The channel indicator is just constantly scrolling up through the channels endlessly then loops back to 2 and keeps counting again, like its stuck on channel up. I pulled batteries out of the remotes to be sure it wasn't a stuck button and tried unplugging tv to see if that would clear it. Could you please tell me if its an easy enough fix or time for a new tv?
SOURCE:
techman
  • 3130 Answers
SOURCE: Remote/tv buttons not working & start-up menu flashing
You can get an original replacement remote that will work all functions from Here: http://www.remotes.com/remotes/servlet/rs?o=c&a=Search&m=KV-27FS200&uid=11829594841080 Good Luck
Posted on Jun 27, 2007
bkvinr
  • 76 Answers
SOURCE: Sony KV-27FS100L -
This is due to switches malfuction due to corrosion in switch and dust accumulated in the switch. Since you rarely used switch now after failure of remote of remote control you tried to operate the switch. Another thing you said did"t get picture, maybe memory problem is there. This can be sorted out by the technician only.
Posted on Sep 06, 2007
SOURCE: remote control not responding
Perhaps you can try what I do when my KV24FV300 runs through channels and will not stop.  Hard to watch and remote will not work.  Nothing works but on and off from set.
Sony Says:  Take all batteries out of ALL remotes that you use in any way for that set, VCR, etc.  ALL batteries out.  Turn TV off at set.  Unplug TV.  Wait at least 15 minutes then replace all batteries in ALL remotes.  Plug TV back in and turn TV on from set.
Maybe, just maybe it will work.  If it does not work why not call Sony, they always say that cannot happen but they have a solution for it.
niteowl@dejazzd.com
Posted on Oct 26, 2007
jerryg50
  • 1691 Answers
SOURCE: No Signal through on my main TV input.
This may be the tuner or IF module that is failing. It may also be a voltage supply fault to these modules. It is impossible to accurately speculate without actualy troubleshooting the set.
Jerry G.
Posted on Apr 19, 2008
SOURCE: My Sony Trinitron TV does not respond to remote control commands
the tv wont come on the standy timer light is on
Posted on Jan 02, 2009
MY TV JUST KEEP COMMING ON THE DVD PLAYER WILL NOY DISENGAGE
Not sure what you mean. The TV comes on and is always showing the DVD instead of TV channels? If that is the case, you need to change the TV input from what the DVD player is using. (for example component or Video 1, or HDMI 1 to whatever the TV is using for television provider's input. (for example HDMI 1 or HDMI 2 or component, or video 1, or video 2.) Usually the remote will have a button that says "input". If you push it, it will scroll through the various inputs. You may need to wait a few seconds between each choice for the change to happen.)
You can look at the cable from your DVD player to the TV and see if the inputs on the TV are labeled, and also look at the cable into the TV from the television provider (comcast, dishnetwork, or TV antenna) to see what input that is as well.
Dec 20, 2011 | Televison & Video
I don't have a remote and I need to get to input is there anyway from the tv to do so ?
channel button--keep scrolling through channels. right before channel 2 it should say input 1 input 2 tv video then channel2,3,4,5 etc
Nov 14, 2010 | Emerson EWF2703 27" TV
Admiral TV model GRD15272 video/dvd
Using the buttons on the TV, go to the setup menu, and scroll to "edit channels" by pressing "setup" button until "edit channels" is highlighted. Then, using the channel up/down buttons, go to channel 91 and press + volume. This should add the video input to your channels. 92 is S-video. It is helpful to have what ever device (dvd player or game console) hooked up and powered on, so you know when you are on the right channel, but it should be 91.
May 12, 2010 | Emerson Televison & Video
What channel does video player work on?
your line in or front RCA yellow/white/red cable input is usually defaulted to channel -1 and is accesible by either pressing the tv/video button on tv or remote or sometimes by scrolling down channels past 1
Mar 30, 2010 | RCA 20F424T 20" TV
How do I get to the input screen on and Admiral TV model GRD15272
Using the buttons on the TV, go to the setup menu, and scroll to "editchannels" by pressing "setup" button until "edit channels" ishighlighted. Then, using the channel up/down buttons, go to channel 91and press + volume. This should add the video input2_bing.gif to your channels. 92 is S-video. It is helpful to have what ever device (dvd player or game console) hooked up and powered on, so you know when you are on the right channel, but it should be 91.
Dec 13, 2009 | Televison & Video
Can't get the tv set to video input mode
You may be able to press the channel down button, past channel 1 to the av inputs.
It works on some tvs, but not all.
Aug 27, 2009 | RCA F32632SB 32" TV
Comcast Remote requires 3 digits be entered to change channels
l. Push the "Menu button"
2. Push the "Menu button" again
3. Scroll to "Setup" and push "OK"
4. Scroll to "Guide setup" and push "OK"
5. Scroll to"No Auto Tune"
6. Click on arrow next to "No Auto Tune". This will change it to "Auto Tune".
7. Now exit, or just punch in any channel number.
You should now be able to go directly to a channel without entering zeros.
Nov 23, 2008 | Philips Tivo HDR812 80-Hours Video...
I have purchased a Samsung V 375 - it says it automatically tunes in and installs itself - trouble is I can't get the TV to display the signal by manually searching through mhz channels - I have the rellow...
Forget the mHz channels for now.
On the TV, or TV remote, look for a button that is labeled "Input" or "Video" or something like that. Depending on your TV, there might be a few choices that present themselves once you do this, such as "Video 1", "Video 2", etc. Keep going until you find what looks like the DVD player signal.
If there is no button as described, then look for another button on the TV remote or on the TV labeled "Menu". Then scroll thru the menu until you find "Input". Choices here might be "Cable", "Antenna", "Video". You'll want to choose "Video", or "A/V", or "Line".
Let me know...
---axoplasm
Nov 02, 2008 | Samsung Televison & Video
I have a 1995 nagnavox tv and i cannot figure out how to hook it up to a dvd player. There doesn't seem to be a hook up of any sort. help me?
If you have a VCR you can run the video out from the dvd player to the input of the vcr. then run the vcr coax cable to your tv. You have to set the tv on channel 3 and the vcr to line in. You set the vcr to line in either by scrolling the channel down button below ch 2 (the display will say "LINE") or find the "input" button on the vcr's remote control and scroll through the inputs untill you see your dvd movie playing.
barneyluc
Oct 01, 2008 | Televison & Video
Input problem
If you have the original remote, hit video, source, or input button, if it dont have them, then try to change the tv to channel 00 (zero or zerozero), if not then the channels might have to scroll to it, from channel 02 down to make it loop, if it goes to the next highest channel, then you need a remote. It may be set in the menu options to have the video source not saved to your list of saved channels. when you scan the channels, the tv might not look for the A/V source (audio / video), maybe just the RF source. The 3 DVD RCA wires are 1 video and 2 stereo, one stereo for left and one stereo for right. The TV has only 2 , 1 for video and 1 for mono 1 channel sound. This wouldnt have anything to do with why you cant use the DVD player. but try that with the original remote (or a universal remote that is set to your tv set that has either video, input, source or something similar. It is what tells the tv to change from the cable source (RF) and the AV source (the Red White and Yellow plugs, in your TV's case, 2 plugs, one yellow and the other either red or white or something). Dont really know how to explain it much more but hope it helps.
Jan 05, 2008 | Sanyo DS24205 24" TV
Sony FD Trinitron WEGA KV-32FS120 32" TV Logo
47 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
