Lines on top of screen
Hi I have a vs-55707 and there are 3 colored lines on top of the screen and the top is a bit oblong. There is also a black bar on top of the colored lines thats about 2" tall. Slowly the lines fade away and the lines start rolling then after about an hour it works itself out and starts working fine.
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Initially, sounds like a capacitor at the vertical section about to fail, leaking or blistered. Additionally, have seen some of these models suffers from vertical fault due to a defective capacitor in the power supply section or cold solder.
Just a start, do postback how things turned up or should you need additional information. Good luck and Thank you for using FixYa.
Posted on Nov 30, 2008
Can i buy a new tv screen for mitsubishi vs-55707 tv
Yes, You can buy another screen for Your mitsubishi television, You can get it from any part dealer store, also, You can get it from someone whose television is having a different problem than a faulty screen. There are some television that develop other kinds of fault, therefore, they are moved to stores where they can be disassembled and sold in parts.
Hope this information helped. Thank You for using FixYa!!!
Jan 15, 2011 | Mitsubishi VS-55707 TV
My mitsubishi vs-55707 was smelling burnt and the picture was imbalanced, (an almost 3-D effect) then all color and sound went out. turned it on a few days later, got sound and somewhat of a red tinted...
That would be the CRT Board to Red Tube,Mats Electronics did have some CRT boards $9.95
Encompass Parts Distribution might have them 1-800-638-3328
Jan 14, 2011 | Mitsubishi VS-55707 TV
I have the Mitsubishi Big Screen TV Model number VS-55707. When I turn on the power the light flashes 3 times and will not turn on. It was working great then just stopped. I assume that 3 blinks on the...
Your power supply board is not yet dead, u know basic electronics' and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like, to buy a whole refurbish power supply board for the replacement.
I hope this will help in solving the problem....
Dec 20, 2010 | Mitsubishi VS-55707 TV
After changing color wheel on my samsung hlr 5067w tv my picture is high with black bar on of heads are cut off.what went wrong? no proble before.
Hi,If you are experimenting vertical lines ,black bars ,color
distortion,pixilation,or white dots on the screen you might be having an
issue with the Dmd chip.This is how the DMD chip works: Basically the dmd chip
is composed of around 2 million pixels that create the image on the
screen.You will need to replace in order to fix your problem.Have a
blessed one!
Feb 09, 2010 | Samsung HLR5064W DLP Projection TV
Mitsubishi vs-55707 or vs-50707????? bouncing horizontal lines weird color
If the picture looks like a 3D then you have a convergence failure.
I would suggest to visually inspect the STK Ics for dry or crystallized solder joints.
IC8C01 - STK392-110
IC8C02 - STK392-110
Dec 11, 2008 | Televison & Video
Jumping screen on a mitsubishi vs-55707
check the high voltage leads on the multiplier flyback transformer for leakage
Nov 17, 2008 | Mitsubishi VS-55707 TV
For some reason it started to take a longer time to warm up...
This model has several caps. on the power supply voltages such as the 5v, 9v and 12 v lines that begin to dry out and open and such problems begin to manifest themselves. Most likely this problem will continue to get worse and worse. As far as burned in images there is nothing that can be done short of replaceing all three picture tube and that is very expensive and this unit is to old to consider a 1000.00 repair.
Feb 10, 2008 | Mitsubishi VS-55707 TV
Mitsubishi VS-55707 Shuts Down
I would not recommend working on a TV unless you have a great deal of knowledge about them.
it is probably your power relays do you have a part # i could help you look around
Jan 26, 2008 | Mitsubishi VS-55707 TV
Hi there!
Sounds like convergence Amp to me. Refer to a repairer if you are not sure. Good luck,JUS004
Jan 11, 2008 | Mitsubishi VS-55707 TV
Televison & Video Logo
Top Televison & Video Experts
