Question about RCA D61W20 61" Rear Projection Television
No power to my tv
I checked the plug-in, tried to push the power button on the panel, checked the batteries in the remote, and still nothing. The TV is only 2 years old it worked fine till one day after work I came home and it would not turn on. What would cause this and how much am I going to spend if I cant fix it myself? HELP PLEASE!!!
    Sergeant:
  • 337 Answers
The reason could have been a power surge(lost power in the whole house while you were out)or a lightning strike specially if you have no indication of power(no lights,no click sound),if this is the case you can start by checking the main fuse and it should be close to where the power cord comes in the tv,if the fuse is black you can expect more damage ahead and it will blow up again as soon as you replace it,if the fuse is not black replace it with the same kind and try it,if the unit does not power up you will need the assistance of a service technician to diagnose the problem.
Posted on Sep 30, 2006
Unable to turn on tv at the base of the tv or the remote
check make sure you have power
check the power strip is working
check electrical and power cords
unplug the tv from the wall and remove the plug from the tv
inspect the wire or plug connectors and plug areas
check the batteries for the remote, if not sure replace them all
go to fuse panel reset breaker, trip and reset breaker
than reconnect everything and try turning tv on
see if you can find reset button, push to reset
find out if the tv has a fuse, check the fuse
after all that a new tv/ see if it worth repairing most of the time it cheaper to buy new one or a referbushed unit.
Sep 17, 2015 | Philips Televison & Video
I have a Samsung LN40c530F1F and I accidentally pressed the button below the power button labeled "DVD receiver/TV" and now nothing works at all on the remote. I have tried re-pressing the...
Take the battery out like about hour for a hard resetting.After putting the battery back in u should push the button that said TV only.The remote should be functions again for the tv again.
Jun 18, 2011 | Samsung LN40C530 TV
Cant get the remote to work for menu options just started setting it up already programed to my direct tv remote now nothing is working or either remote t.v or direct tv remote
To diagnose a remote control problem follow these steps.
1) unplug the TV power cord, count to five and plug it back in. (reboot)
2) try to power on with ORIGINAL MANUFACTURER remote.
if that works- your TV and original remote are fine.
if that does not work:
4) try to power on with buttons on the TV itself- if it works- check your remote batteries and try remote again.
Direct TV and Dish Network remotes will ONLY operate SIMPLE function of your TV such as power, volume, input.
They will NOT access your TV menu.
Apr 12, 2011 | Televison & Video
Remote control work very slowly and sometime do not work
Please follow the troubleshooting steps:
  1. Remove the batteries from the remote control.
  2. Press each button on the remote control twice.
  3. Make sure none of the buttons on the remote control are jammed.
  4. Install fresh batteries into the remote control.
  5. Make sure nothing is blocking the Infrared (IR) sensor on the TV.
  6. On the remote control, press the TV FUNCTION button.
  7. Press the POWER button and other buttons to test the operation.
  8. Try using the remote control at varying distances from the TV.
  9. Power reset the TV by follow the steps:
  • Unplug the television power cord from the electrical outlet.
  • Let the television remain without power for 60 seconds.
  • Plug the power cord back into the electrical outlet.
Jan 09, 2011 | Philips 32PF9964 32 in. Television
Do i need a remote to operate tv
once you have front panel in the tv and this one shows power channel +- volumen +- menu then your tv has to work with those ones and the remote is a second option to do the same. With this i mean you tv has to respond and at least show menu when you push that button " if no signal (cable DVD VCR) plug in"
Then if the tv is dead you should try to repair or sent it to repair. and then get the remote control and it can be universal too.
May 01, 2009 | Protron PLTV3250 32 in. LCD Television
My LG remote control is not working
Make sure you push the TV button on the top of the remote before you push the power on button.
Dec 17, 2008 | Televison & Video
Vizio 50 inch plasma -- remote not working
You can also try to take out the batteries and push all of the buttons with the batteries out of the remote. Then put the batteries back in and push the power button on the remote. If this doesnt work press the two TV buttons at the same time and the remote should be fine.
Sep 14, 2007 | Vizio P2 42 in. HD-Ready Plasma Television
RCA D61W20 61" Rear Projection Television Logo
73 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
