Question about Philips DVDR 3355 DVD Recorder
DVDR3350h/37 universal remote code
My product wasn't listed so I'm posting my issue here. I bought a Philips DVDR3350h/37 DVD recorder from Walmart. It was a display item and did not come with a remote. I have been searching online every where for a code for the thing I have a SRU4208WM universal remote. The codes that came with the remote do not work with my DVDR player. HELP!!
  • 2 more comments
  • Anonymous Nov 19, 2008
    looking for same thing
  • glassactmich Dec 23, 2008
    man i got the same deal going exactly big bummer. wal mart special cant get any code to work 12482244629
  • Anonymous Jan 20, 2009
    I bought a Philips Universal Remote at Target to replace the remote that came with my Philips 3355 DVDR, and found that one of the Philips codes listed in the manual will operate a very limited number of the unit's basic functions, like "play" and "stop", but still will not operate any of the advanced features, such as "record" and "menu".  You would a company would make a remote control that works on its own products.
  • kugz Feb 12, 2009
    I also have this problem!! bought the recorder without a remote now I am not even sure if it will work....
devocap
  • 201 Answers
SOURCE: UNLOCK REGION CODE FOR PHILIPS DVDR3475/37 Recorder
Your device is designed for playing back region 1. It will also playback disks recorded with a region setting of all. The region setting of the device is fixed. Also it will only playback NTSC, and not PAL . This is also fixed on your unit. Sorry I could not bring you better news. However there are many burning and conversion programs you can use on your computer (ie Nero Vision, ConvertXtoDvd,..) which provide you the optional settings you are looking for, and allow you to burn in the setting you choose, allowing for playback on your Philips device. Good Luck!
Posted on Feb 07, 2008
SOURCE: philips DVDR 3390/37
I had the same problem. It is likely to get worse. The problem is one of design of the R/W unit. What is "causing" the "blockage" is the stabilization idler mounted on a plastic piece spanning the top of the recorder. It is a plastic disc with a metal ring embedded in it. It clamps down on the dvd once its loaded. It is supposed to release when the eject sequence starts. The read/write head assembly is supposed to rise up to read a dvd or cd and drop back down to a rest position when its time to eject the disc. The head assembly is encased in a metal shell, which is already magnetized or has become magnetized, because mine is. The mechanism pulling the head down is too weak to pull the head all the way down. It moves just a little bit, you hear some noise and the "blocked" message appears on the display. If you take the cover off, you see the dvd still in the "mounted" position, but it has moved a little bit, but the clamp effect of the stabilizer is still engaged.
There are 2 ways I know to get around it, neither is kosher. First, before you go inside, tap the area of the philips case right where you imagine the dvd center to be, if one was loaded. Tap AND hit open, you may break the magnetic link that way, the head drops, the tray slides out. Then always keep a dvd in the player to give the release motor a little help, use a scratch disc you were going to throw away anyway.
Second, you need to open the case, pry the stabilizer up as high as you can, or tap on the plastic near its edge while pressing the "open" button. You may need a pc type screw driver to remove the very small screws that the stabilizer assembly is mounted on. This way you can at least get the disc without further damage to it..You might as well leave the screws off, if you plan to keep using the recorder. I did until I now, 6 months later, have the unknown disc problem. What a shame, it is a good unit, read and wrote to old dvd-rw discs my other recorders refused to touch . Having no real luck finding the drive unit as a sale item, it is really easy to replace, just like a pc drive..that would be under 40 dollars. I would buy another philips, but unless I can find a couple replacement drives to put in the closet it doesn't make sense. I dislike throwing out all those electronics because of a little problem with the R/W unit. Just the words of an old, country network/pc technician.
Posted on Mar 01, 2008
SOURCE: Remote Codes for Philips Universal
These are dependent on your brand of Universal remote control. You should call the manufacturer of the remote control device or check their web site for an updated list.
Posted on Apr 09, 2008
  • 132 Answers
SOURCE: Universal remote code for Magnavox MWD7006
4 digit code is 0458
Posted on Jul 16, 2008
jaffa012001
  • 376 Answers
SOURCE: philips dvdr 3320 v DVD Player Unlock region codes
In DVD mode, press System Menu
Go down to the "Lock " icon
While lock is highlighed press zero "0" for 7 times ( i.e 0,0,0,0,0,0,0)
There will be pop-up window that asks you confirm. Press "OK"
Posted on Aug 12, 2008
Have philips univerasal remote need codes for my panasonic dmr-ez28 dvd recorder
Panasonic DMR-ES30VS DVD Recorder/VCR Universal ...
www.fixya.com > ... > Panasonic DMR-ES30VS DVD Recorder/VCR
Panasonic DMR-ES30VS DVD Recorder/VCR, universal remote related issues. Getfree help ... My remote does not work anymore. what is the code for a universal remote? Thanks in ... Question about Philips DVD & Blu-Ray Players ... How do I getremote code for GE universal remote control Need remote code? How to ...
Philips Magnavox MWR20V6 DVD Recorder/VCR Remote ...
www.fixya.com > ... > Philips Magnavox MWR20V6 DVD Recorder/VCR
Dec 20, 2015 | Panasonic Televison & Video
I HAVE A RCA, RCU404N 4-Device Universal Remote, AND I WANT TO PROGRAM MY TV/DVD BY PHILIPS MODEL NO.20DV6942/37,SO THAT MY DVD PLAYER CAN BE OPERATED. THANKS!
The remote needs to be programmed twice. The DVD button should use either code 0854 or 1260. The TV button should be coded for any Philips TV: 1454, 0054, 0690, 1154, 1483, 1744, 1867.
The only reason that these codes might not work would be if the TV is newer than the remote. Unfortunately the code lists in the remote only have devices that were released 6+ months before the remote was programmed. Since Amazon lists the TV/DVD as being listed on their site in 2004 and the remote manual is from 2003, this could be the issue.
Documentation for the RCU404N is available at http://voxrightnow.custhelp.com/app/answers/detail/a_id/8059/~/information,-user-manual,-code-list-and-support-for-the-rcu404n-remote-control .
I hope this helps.
Jul 01, 2011 | Televison & Video
My remote for the Philips DVDR 3455 stopped working. What can I do?
hello. Begin by replacing the batteries in your remote. If that does not make a difference go to any walmart or radio shack and purchase a universal remote control.
Jan 09, 2010 | Philips DVDR3455/37 DVD Recorder/HDD...
Program RCR4358 to Control Philips DVD player DVP5982/37 C1
I am having the exact same problem. Did anyone ever find a fix for this?
Mar 24, 2009 | RCA Universal Remote Control
Remote code for Akai 37" lcd with Dish Network
I have a akai 42" plasma and went to walmart and bought a Phillips Universal remote SRU3004WM/17 for @$14.95 and it works both my Akai and Dish network.......
Jul 17, 2008 | Akai LCT3201TD 32 in. LCD Television
Dog chewed my Philips DVD remote!
Remote codes
http://www.remotecentral.com/index.html
Mar 02, 2008 | Big Button TV Universal Remote
Remote control code for universal remote
need the code for ilo dvdr05 remote
Jan 01, 2008 | iLO DVDR05 DVD Recorder
Nov 04, 2007 | Philips DVDR3390/37 DVD Recorder
I NEED REMOTE CODES FOR THIS DVD RCA DRC200N
I finally found a code that works. Code 3144 worked. I am using the RCA universal remote control RCR412S and RCA DVD player DRC200N. The code 3144 is listed under Memorex in the code book that came with the remote control.
Oct 17, 2007 | RCA DRC200N
Philips DVDR 3355 DVD Recorder Logo
328 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
