Air-O-Swiss U7142 Humidifier
Problem for Air-O-Swiss U7142 Humidifier
Air-o-swiss 7142 humidifier
By neilott on Nov 03, 2008
I need instructions on how to clean this unit
Best Solution
posted on Nov 08, 2008
Very Helpful)
michelle1975
Rank: Apprentice
Rating: 98%, 5 votes
I just cleaned mine for the first time, and the instructions are very unclear in the pamphlet on how to do it.
What you need:
One package of EZ Cal cleaner/descaler for humidifiers ( I got mine at bed bath and beyond)
32 oz of hot water
How to clean your unit:
Mix the hot water with the EZ Cal cleaner packet in a separate container.
Remove the tank from the base.
Remove the cleaning brush and the silver stick that is in the base of the unit.
Pour the solution in the base of the unit.
Let the solution sit in the base of the unit for 1/2 hour.
Then take the cleaning brush, and go over the surfaces in the base.
Pour out the solution, and rinse with hot water.
Put the brush and silver stick back into the base.
Put tank back onto the base.
Reset the unit by pushing and holding the power button for a few seconds.
This will stop the cleaning indicator from blinking.
Let the water fill up the filter for a couple minutes, turn on, and your ready to go again.
I hope this was helpful.
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Air-O-Swiss U7142 Humidifier
Questions and Unsolved Problems for Air-O-Swiss U7142 Humidifier
Do you recommend Air-O-Swiss U7142 Humidifier?
Answer
Answer
Leaking. The white plastic circular ring in the base unit is cracked. This is part of the... (More)
Answer
When if fill the water tank with water and place it on the base the base fills up and leaks between... (More)
Answer
Air flows but no mist.
Answer
hi - i have a problem with my 7142 air-o-swiss humidifier - can you help?
Answer
i pushed the button, the signal shows the heat feature on, but the heat is still the exact same temp... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Air-O-Swiss U7142 Humidifier:
Top Humidifier Experts
Rank: Guru Guru
Solutions: 2511
Experience: ASE Certified Master Car and Truck Mechanic Certified AC mechanic Cert. AWS Cert. welder Contract me
Ask Me
Find more Humidifier Experts
Top Air Conditioner Repair
ARS
(866) 800-3823
When it comes to air conditioning systems,...
ARS
Service and Repair, System Maintenance, Advantage...
Aire Serv Heating & Air Conditioning
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
