is it possible to align by taking the back off and adjust the colours ... all 3 light tubes have a butterfly to turn and losen ... but is this safe or not to do ? any suggestions on how or which ones i should adjust ?is it possible to align by taking the back off and adjust the colours ... all 3 light tubes have a butterfly to turn and losen ... but is this safe or not to do ? any suggestions on how or which ones i should adjust ?
no adjusting them will only mess the alignment up. If the sets out of convergence then the STK730-130 IC may be bad on the convergence power supply board.no adjusting them will only mess the alignment up. If the sets out of convergence then the STK730-130 IC may be bad on the convergence power supply board.
You can't post conmments that contain an email address.
Vertical blanking has shut down vertical Deflection but allowing the menus to appear. Replace the vertical transistor. You can get replacement vertical Ics at www.tvrepairworld.com
Convergence outputs reliable.Suspect power supply to control convergence bad.Small PCB
mounted above two main PCB.Check STK730-010 &
associated circuitry. If This info not helpful,
please provide complete service # and chassis
number.
