Question about Samsung RS2630SH Side by Side Refrigerator
Water filtre cartridge exploding
Help my water filtre cartridge exploded yesterday lucky i was home...to mop the flooding why has this happened now not sure to replace incase it happens again so no ice maker or fresh clean water...
  • 237 Answers
Ouch. Check your house water pressure for sure. DIY stores like Home Depot or Lowes, etc. have a pressure gauge that screws onto the garden hose faucet outside so you can check for pressure. It should be around 45-50 pounds (PSI). Only other thing I can think of is the filter had a defect that caused it to crack. They're generally real tough cases.
Posted on Nov 09, 2006
2004 ford explore just cut off after ... Cranking a this morning going 2mins down the road it just cut off ... What is this problem
Sorry but , Ford is noted for not recalling the Pinto exploding gas tanks. Internal memo said, "Cheaper to let people burn in 15 MPH crash than accept responsibility" Also look at Explorer exploding tires.
On my Ford, the steering arm snapped off. Zero steering control!! Lucky I was 100 feet from home not on freeway
May 27, 2015 | 2004 Ford Explorer
My cartridge is clogged
Here are two links to the exploded parts diagram and the installation instruction:
http://www.moen.com/shared/docs/exploded-parts-views/87499pt.pdf
http://www.moen.com/shared/docs/instruction-sheets/ins10205.pdf
You may refer to them to take the cartridge out.
Feb 11, 2014 | Moen 87499SRS Harlon High Arc Kitchen...
Why does the Hot water does not run
Hot water need to pass through the hot water hose (under the benchtop) and then to the faucet especially the cartridge. If any of them are blocked, hot water cannot come out.
Here is a link to the exploded diagram:
http://www.moen.com/shared/docs/exploded-parts-views/7460pt.pdf
Jan 07, 2014 | Moen Chateau Loop-Handle Kitchen Faucet...
Why do water-tank explode
have you checked that the electric cooling fan is working ?? if so check the thirmostat by removing and placeing in boiling water and placeing a thirmomitor in the wather the stat should open at aprox 88- 92 deg, failing that have the head gasket checked
Dec 30, 2013 | 1995 Mazda MPV
I have a Bosch GWH 425 HNO propane Tankless Water Heater which began intermittently exploding when demand for hot water occurs.
Call a qualified service tech immediately.
Gas explosion indicates dirty combustion parts, and gas is not fully igniting when tankless turns on the gas. So gas builds up and then explodes causing serious damage to tankless, and serious risk to homeowner.
Aug 14, 2012 | Bosch & Tankless LP Hot Water Heater
Hot water handle got loose then eventually popped off this model Moen L4720 Villeta faucet. Where can I go for detailed repair instructions?
http://www.moen.com/shared/docs/exploded-parts-views/l4720pt.pdf
i just sent you a clarification request. The link above is an exploded parts diagram. You should be able to get some of these parts at lowes or home depot. Especially the cartridge.
No really all you have to do to change them out is turn off the water supply, and use the diagram to tell which parts go on when. I doubt you will be able to get everything from the store. But you can probably get any part on there from the moen website.
I hope this helps. I will be more than happy to help you further if you need it.
Thanks,
Mike
Jul 27, 2011 | Moen Villeta Chrome Faucet W/ Valve &...
My tempered glass vessel sink exploded. Does this happen often?
No it doesn't and it is not supposed to. They didn't have the temper right and it should not have happened. The manufacturer will tell you that you must have chipped it or hit with something and the water temp made it burst. Don't buy it, Glass is tough, and when done right, does not explode easily. Hope this helps.
Feb 20, 2011 | Elite Clear Green Tempered Glass Sink
Kenmore front loader - how to manually drain water
This problem is commonly attributed to either a leaking water inlet valve, or a pressure switch malfunction. The following link explains how to diagnose the problem and repair as necessary:
http://www.fixya.com/support/r3753262-front_load_washer_fills_when_not_in_use
Replacement parts (if required) can be purchased at any of the following websites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
All these sites are reputable and offer great service with competitive pricing, so shop and compare. The first three sites I listed also include helpful exploded view parts diagrams to assist you in locating and properly identifying the parts you need.
If you have any questions, please post back and let me know. I hope this helps you. NOTE: The easiest way to remove the water from the wash tub and avoid flooding your laundry room is to remove the drain hose from the standpipe at the wall and use a wet/dry shopd vac to pull a vacuum on the line. If you do not own a shop vac, you can use a mop bucket and lower the drain hose enough to allow gravity to drain. Make sure to place the drain hose back in the standpipe between emptying the shop vac or mop bucket to prevent water from running on the floor.
Apr 06, 2010 | Kenmore Elite 45986 Front Load Washer
My Canon iR 6020 explodes
usually bad power, power surge or spike, from mains, is very common.
Mar 26, 2010 | Canon imageRUNNER 5000 Copier
Samsung RS2630SH Side by Side Refrigerator Logo
136 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
