Question about LG DLE2532W Electric Dryer
DLG 2524 W
ART 4827
773 406 1307 MOBIL
  • 3 more comments
  • tomantos Nov 21, 2008
    I got same problem, heat not working
  • blacontr Nov 21, 2008
    Same thing here, are they all dropping dead at the same age? I am suspecting it's the element.
  • bugsy69 Dec 24, 2008
    We have the electric version, we bought it in 2005. Same thing, dryer runs but no heat. The thermistors appear to be good according to a ohmmeter, but I can't get the centrifugal swtich that is on the motor and is attached to the red wire that is attached to inner and outer coil. Then the blue and yellow wire go to the other side via a thermistat for each. could it be the centifugal switch?
  • havitmiway Dec 30, 2008
    My dryer is about four years old and the light (clean filter) stays on. I have cleaned the filter, I have changed the hose leading to the trap, and I have cleaned the trap. The clean filter light still comes on. I have to dry the clothes for two or three cycles.
  • Anonymous Mar 15, 2014
    I have no power running to the a/c or heat unit, have checked everything I can locate, need a wiring diagram for a 1996 jayco, 312 FK Eagle series, power is good from behind breaker so is there another fuse in the system that runs behind the breaker to both units that I am missing? Or any ideas on what I am overlooking? everything worked fine until last night?
    Thank you for your time.
    New Friend:
  • 4 Answers
Had the same problem on a whirpool drayer. Get our multimeter and check which heat fuse is broken. Take that one out and throw it in the floor until you have conductivity again. Clean drayer vents and heater. This worked for me, good luck.
Posted on May 25, 2013
I clean exhaust system
art patel
Posted on Nov 06, 2008
E28 error. Why does the thermal fuse keep blowing out?
If the thermostat is not functioning properly the heater will run "wide open" and overheat.
Feb 07, 2016 | Water Water Heaters
Thermal fuse failure
If the relay sticks, that will cause overheating and the thermal fuse to blow.
Feb 27, 2017 | Whirlpool Dryers
Whirlpool model#LEQ8000JQ3 will tumble but not heat up. Vent is not clogged all the way out. Also how old is this dryer?
Maybe what 5, 10 years old at the most. Unplug the dryer and look for air blockages. d404494.jpgThat will give you a clue if it is the heater element or the limits mounted on the heater chamber. Overheating causes these guys to kick out. 012813e.jpgThe dryer itself will still run. If their is severe blockage to the filter housing the thermal fuse will get in the act and kill all power to the dryer through the door circuit. You say it runs so ts get down to the nitty gritty. bc32dd7.jpgUnplug the dryer and take the back dust cover off. There you will find the heater and limits on the right and the filter chute and blower with thermal limit. Lets look at your heater1c9285f.jpgIt mounts on bottom and easier to take out than older ones was16e16c9.jpg
Jul 24, 2010 | Whirlpool Dryers
My 970-c85092 dryer only runs cold air. I'd like
not likely a fuse. check the heating element for a break. the thermal fuse will shut the dryer down completley. could be you need an upgraded thermostat kit for the heater assy.
Oct 04, 2009 | Dryers
Thermal fuse keeps blowing
Mr. Larry (guru?)
The thermal fuse is just that It doesn't protect the circuit from over current although it certainly can open in that case. It is there to protect the board from overheating , thus the term thermal. The dishwasher could be allowing the water to heat too hot or the water heater in the home is turned up too much. The heater could also be shorted to case thus allowing it to be on even though the control is not calling for it especially if the polarity is incorrect to the dishwasher or the relay on the board could be welded closed so that the heater can't turn off even though the thermostat is satisfied. The best thing is to get a person who can check these things. You don't necessarily need to change the board with a fuse. I have changed many fuses with no other problems and verified that the machine was still working years later. sometimes the fuse just blows!
Dec 02, 2008 | Dishwashers
Tumble dryer not giving heat
is the drum turning?if the drum is ok sounds like the thermo fuse on the heater box failed,most of the time it's from a clogged dryer vent hose or wall vent,let me know what you find-mike
Nov 13, 2008 | Dryers
Replacement of fuse and thermostat
DLG 2524W
Jul 05, 2008 | LG DLE2532W Electric Dryer
Dryer not starting
Dryer needs a new motor. I changed the thermal fuse and the dryer worked for a minute then stopped without the ability to restart.
Jul 05, 2008 | Dryers
Tumble dryer
Can be a few things. Start by resetting your circuit breaker. The dryer motor can run with partial power but the heating element cannot. Make sure your not set to a no heat setting. After those checks you have to get into the mchine to check your heating element and thermostats.
Apr 12, 2008 | Whirlpool LER5636P Electric Dryer
Drayer working but no heat
No heat may mean that one side of the 240 volt circuit breaker is tripped or one fuse of the 240v circuit at the fuse/breaker box is tripped. Just replace/reset the fuse or breaker which ever you have.
Dryers will have controls working but not heat if it happens to be that particular side of the 240v circuit that tripped or fuse burned.
Jan 30, 2008 | Dryers
LG DLE2532W Electric Dryer Logo
226 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a LG Dryer Expert? Answer questions, earn points and help others
