Question about Sylvania SSD803 DVD Player/VCR
Connection data yes I am using red, white, and yellow connectiion ports in the back of the unit. Says dvd/vcr on the ports, used to work but not now. Tried using the dvd only ports but no go
  • TLW 1963 Nov 03, 2008
    Will this work for the sound, the picture is fine, the sound is the problem
  • TLW 1963 Nov 10, 2008
    If this is a setting problem, how can I fix this ?
  • 124 Answers
Hi, I think you accidently set your DVD player to P.Scan mode. Simply turn the DVD player on. Make sure you do not have a disk in the tray. Press the DVD button 3-4 times. The picture should come back. Let me know if that works. Thanks, Mike
Posted on Nov 03, 2008
  • Mike H. Nov 03, 2008
    I must have misunderstood your request.
    Let's confirmed. You have picture. The issue you are having is with the sound?
    if it is just the sound, then it could be a settting change issue.
    First, confirm where you have the red white and yellow wire connected on the back of the DVD player and on the Television. Make sure the red and white wire is connected firmly as well.
    If the connection remain the same, then the problem is the setting.
  • Mike H. Nov 10, 2008
    Provide the model number of your DVD player so that i can research your audio setting or go into the DVD player audio setting and tell me what option do you have in that menu and also tell me your current setting.
    Mike H
I have trouble setting up my 50 inch T.V. It is connected to a VCR/DVD player recorder. I have a red, yellow, and white cable. Do I need anything more?
If possible use a AV SCART connection lead as you get audio & video! If you want to use the phono connection you need to connect all 3 red/white/yellow to the TV and the VCR/DVD! Red & white are audio, yellow video!
Dec 19, 2014 | Televison & Video
How to get dvd on tv
There are generally 2 ways to connect a dvd player to a tv.1 If you have 3 rca connectors on the back of your tv (they are color coded yellow for video and white and red for audio left and right channels respectively) and the same connectors on the back or side of the dvd player.Use rca cables to connect the dvd player to the tv,connecting yellow to yellow white to white and red to red.Using the remote put your tv on video.Put the channel selector on the dvd/vcr player on video or L1 or E1 (depending on what brand dvd/vcr you have).2 connect a rf (coaxial cable from the rf output of the dvd/vcr and connect this directly to the rf (antenna) input to your tv.Put the tv on channel 3.Play the dvd/vcr to see if you have the video.If not put the tv on channel 4.Some dvd/vcr's put their signals out on channel 3 and others on channel 4.Good luck.
Sep 15, 2013 | Disney 13" TV
I hooked up a DVD player to my RCA Tv/ VCR Combo. I get sound, but no picture. All connections are tight. Cables are hooked up in the order they should be. I get cable from TWC. There are red yellow &...
The red and white are the audio, and the yellow is the video, check the back of the tv to make sure the yellow jack states input, if yes make sure the tv is set to aux/or video.
Dec 22, 2010 | RCA T20TF667 20 in. TV/VCR Combo
Trying to connect vcr/dvd to tv. Do not have
you need to have your basic rca cables (yellow, red and white). The cables you are referring to are composite cables and if you do not have component inputs on your tv they will be useless. You can use rca cables on any tv that has video.
May 15, 2010 | Televison & Video
I tried to hook up my dvd player and i get picture but no sound. when i put the cords in the back of the monitor there is yellow red blue green holes no white spot. Do i need different cords. I have tried...
That could be a result to that TV either not having the ports you need, or you may need different cords. On my TV. With the 360 they have two cords. Red,white, and yellow and also green blue and i think red but im not 100% sure. You may need to find a different port on your TV for your cords, or do what I do and have your VCR hooked up to your tv, and your DvD player hooked up thorugh your VCR. Hope this helps and don't forget to rate ^^
(and yes that yellow and white are a necessity)
Feb 23, 2010 | Computers & Internet
I have a toshiba D-VR610KU combo. Cannot get the
Oct 15, 2009 | Toshiba D-VR600
Lost manual...I cannot get DVD or VCR to record
You need to decide which set of inputs or outputs you want to use. To record, and watch what you have recorded on your TV, you will need TWO sets of audio/visual patch cords. One for recording and the other for playing. Let's start with the recording. Look for the Line in or video in plugs on your DVD-VCR unit. Some recorders have separate inputs for the VCR and DVD. Others let you select with the remote. Usually Line 1 is at the back and Line 2 is on the front. Your remote will have "recording source" to let you select, or sometimes you can use the channel up and down arrows to select your input source. Your remote will also allow you to select either the DVD or VCR for recording. Connect the Yellow plug to the Video In socket, and the red and white plugs to audio in., Connect the other end of the cord to the TV or cable box. Yellow goes to Video Out, red and white go to audio out. Recording from the cable box is much easier because you wiull always have a signal going into the DVD-VCR recorder no matter what happens at the TV.  Now look for the Video out connection on the DVD-VCR recorder. Connect the Yellow plug to video out and the red and white plugs to audio out. Ignore the other connections at this point. They are for RGB component video. Your DVD -VCR should have one output for both functions. Use that one.
Now connect that cord to a Video one or Video 2 input on your TV.
Test the set-up. Play a DVD or a VHS tape and try to bring it in using the TV remote.
Then turn on a program and try to record it on  the DVD-VCR, then play it back.
This sounds very complicated, but all that's involved are two patch cords with three plugs on each end - 12 connections in all and color-coded. YELLOW is always video.
Dec 13, 2008 | Philips Magnavox DVD/VCR Dual Player
Hd tv to vcr
What model and manufacturer DVD/VCR combo are you using. if it has a HDMI port, you should buy a HDMI cable to your combo player than to your HDTV (most don't have this High Definition port.) 6f3606c.jpg
 otherwise, it probably contains a composite port, connect the red to the red (Left) white to white (mono) and yellow to yellow (Video) than connect the wires to the matching port on your HDTV) then switch the input to AV or Composite. 9701d83.jpgb5e3eb0.jpg
If this fails, you need a coaxial cable.85dec5e.jpgconnect a coaxial cable to your player then to the coaxial port on your tv. change the input to "either Coaxial, Cable 3 or any input that sets it to coaxial input.
Mar 24, 2008 | Sanyo DVW-6100 DVD Player/VCR
Can't get my dvd/vcr to tape and play back
Color codes for A/V cables:
Yellow: Composite Video
Red: Right Audio Channel
White: Left Audio Channel (mono)
Does your TV have a video & audio OUTPUT on the back of the TV?
If so, will need another set of audio/video cables and you need to connect the yellow cable from the video OUTPUT of the TV to the video INPUT (yellow) of the DVD/VCR and connect the Red cable from the right OUTPUT of the TV to the red INPUT of the DVD/VCR. Then connect the white cable from the left OUTPUT of the TV to the white INPUT of the DVD/VCR. If your TV is not in stereo, just connect up the white cable for mono audio.
If your TV set does NOT have audio/video OUTPUTS, then you will still need another set of audio/video cables and connect the yellow cable from the video OUTPUT of the cable box to the yellow video INPUT of the DVD/VCR and connect either the red or white (or both if possible) to the red or white audio INPUTS of the DVD/VCR.
You need two sets of cables because you want to watch DVD's & tapes on your TV (Path #1) and you want to record the TV channel shows back to your DVD/VCR (Path #2).
Please let me know if I can be of further assistance to you.
Good Luck!
- Jim
Feb 21, 2008 | Televison & Video
RCA ColorTrak 27" (non flat) connection to VCR/DVD combo
Yes, To change the input to video jacks, you must change the channel to 00.
Jun 25, 2006 | RCA F27645 27" TV
Sylvania SSD803 DVD Player/VCR Logo
70 people viewed this question
Top Sylvania Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
