Question about ViewSonic G810 21" CRT Monitor
Screen has 1 solid bright vertical line
Hi... I own a Viewsonic G810 CRT monitor and for the last few days I have been seeing frequent flickering on my screen when I use it. This morning before I left for the day, it was getting worse and when I returned home in the evening, I found my screen black with 1 bright solid vertical line running through. I turned the monitor off and now there is no image/vertical line. Have I blown the bulb? IF so, what are the costs associated and is it worth the repair? It's approximately 5 years old and it is being used quite often, as it's my main work/house computer. Thx
  • susanfaelin Dec 09, 2007
    Mine twitches a bit starting about 3 months ago. Then it started doing it everyday after being on awhile. The last few days it's really bad and actually goes beyond twitching and bulging to the picture looking zig zag crazy vertically. It's only about 2 years old and I can't believe I'd have to get a new one. Is it just needing to be cleaned from dust inside or do I worry about it shorting out and catching fire (I've heard of this happening). Thanks for the direction.
  • 29 Answers
A mylar capacitor 0.22mf 100v may be shorted besides the flyback transfomer.
Posted on Apr 27, 2007
Display in black with one line in 1/4 of the top
Hi.
Please try to connect other monitor to your CPU.because I know the problem is in your video card graphic.also change your screen resolution to 1024 by 768.
if same problem again. need to check-up your viewsonic p75f+ crt monitor. some parts of your vertical video section capacitor leakages.
Jun 13, 2011 | ViewSonic P75f+ (Beige) 17" CRT Monitor
I have a viewsonic g810 21" crt and it will make a snapping noise and the screen will zoom in and back out. How do I fix it?
PLease press reset botton on your monitor display and see any different. hope you find a good result.
Jan 30, 2010 | ViewSonic G810 21" CRT Monitor
The brightness and contrats always appears on the screen.It increases and decreases frequently...
This problem is due to a defective microswitch in the brightness and contrast button of your monitor. To rectify this problem, you'll have to replace this microswitch. Please refer the servicing to a trained repair technician.
Hope this solves your problem. Thanks.
Aug 24, 2009 | ViewSonic E70f 17" CRT Monitor
Always seen brightness and contrast not exit
try turning it on and off, wait a few hours then turn it back on. it that dont work, turn it off then leave it till the next day then try. it should work.
Jul 28, 2009 | ViewSonic E70f 17" CRT Monitor
Reddish tint on the screen
LG 700e
power suply is dad
resistanc is black not show it ohom
plz help
Dec 21, 2008 | LG Studioworks 700S 17" CRT Monitor
A black vertical line on my screen
it risky if you always use your monitor that has a factory defect..i suggest to return to the store for some replacement of your monitor...coz your monitor has a warranty.
Jan 28, 2008 | ViewSonic G810 21" CRT Monitor
if that is a new and have a waranty why did back to the store and need for the replacement if the monitor has a warranty ...so just bring that and need for replacement...
Jan 15, 2008 | ViewSonic G810 21" CRT Monitor
Screen flickers
The problem is that it is on the verge of going out my mother had a monitor go out and it did the same thing. Also if you have any high frequeny things around your monitor thatr also migh be the thing. Try a magnet or demagnitze the screen if you have one on it.
Dec 04, 2006 | ViewSonic G810 21" CRT Monitor
Blinking Light
This is the same problem with my 4 VG800 Monitors, you should be able to find the correct capacitor on your monitors by following the same procedure, I'm sure the boards are similar. Just get the correct value capacitor and try it in parallel with the initial filter capacitors right after the DC power in.
Alright, I had 4 VG800 monitors with the exact same problem. The front led is blinky OR constant reddish/orangish OR picture is white with colored vertical lines OR no picture with whistling from the back of the monitor and backlights illuminated. All problems have the same solution. You need to disassemble the monitor (2 screws on the back, remove lower front button panel, remove 2 screws holding panel in and remove speakers, then remove panel and unplug speakers. Now remove lots of tape and screws from the cover in the center of the monitor). Now that you've exposed the amplifier board and the VGA to LVDS board, you want to look for the pair of 25V 100microfarad capacitors that are nearby the DC power in (they are right next to the black "100" inductor). Desolder the capacitor farthest from the DC jack and replace with an electrolytic with the same specifications. If you want to check that this is the correct solution please put the new capacitor (WATCH THE POLARITY) in parallel with the capacitor there want watch the front panel indicator go green and the monitor work properly.
I'll be posting and Instructable entry in the next few days on the process, watch for the username Waterppk on the website www.instructables.com
-Chris
Dec 11, 2006 | ViewSonic VX910 19" LCD Monitor
Compressed Screen
if you get a video camera & wave it from left to right while pointing it at the screen you'll just see the image in the flicker
Aug 24, 2006 | iiyama Vision Master Pro 510 22" CRT...
ViewSonic G810 21" CRT Monitor Logo
268 people viewed this question
Top ViewSonic Computers & Internet Experts
Steve Allison
Steve Allison
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
