Sony bravia KDL-26V40 HOW DO I REMOVE ON SCREEN DETAILS SAYING HDMII ETC
Rifaa
  • 99 Answers
SOURCE: Color problem
Try loading the default settings
Rifaa
Posted on Nov 20, 2008
  • 4234 Answers
SOURCE: Sony Bravia KDL-40W4500 turns off
This can indicate a problem with the high voltage circuits. Since this is a new set, it should still be under warranty. DO NOT open up the unit as that will void the warranty. Return the set or request warranty service. Note the 8 blinks when you request service as that should allow them to bring the correct replacement parts.
Keep us posted.
Dan
Posted on Jan 05, 2009
  • 4 Answers
SOURCE: tv bravia kdl 40v3000 problem turning on
To wayne: The balancer board is in fact available by itself. You can get it at many different parts depots here on the web. I just suffered from a similar problem, on the same tv and it solved my problem perfectly (Stupid 13 blink, blink code...)
The searchable part number is SSB400WA20. Its referred to as a voltage inverter (for the backlight of the lcd panel.)
Good luck!!!
Posted on Jul 08, 2009
  • 8 Answers
SOURCE: how do I remove the stand of the Sony Bravia XBR
you have to lay the tv on it's front on something to protect it from being damaged.on the back you'll see where the base joins the bottom of the display, this needs to be unscrewed and a wall bracket screwed in instead.
Posted on Nov 26, 2009
tvtek
  • 1284 Answers
SOURCE: sony bravia kdl 32l4000 - color bars running vertically on screen
In most cases is the screen is covered with vertical lines all the way accross the screen then the T-Con module is at fault. The t-con board is replaceable without having to replace the entire LCD panel which would usually make it cheaper than replacing the TV. The part number I come up with is 1-857-213-11. Please take a moment to rate my answer. Thanks...
Posted on Dec 02, 2009
Sony bravia KDL 40S4100 No picture
If you wish to get some details; check the site linked here. Pull up older posts.
Troubleshooting procedure for No-Picture is given in detail.
Sep 06, 2016 | Sony Bravia KDL-40S4100 40 in. LCD TV
COLORED VERTICAL LINE ON THE ENTIRE SCREEN AND NO PICTURE Sony Bravia KDL-46VL160 46 in. LCD HDTV
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Dec 03, 2015 | Sony Bravia KDL-46V4100 46 in. LCD HDTV
What board is defective on a sony bravia KDL-XBR6 that has a colored vertical lines on the whole screen? No pictures on screen an its just a colored vertical lines...
T'Con board. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Sep 05, 2015 | Sony BRAVIA KDL-52XBR6 LCD TV
MY TV SONY BRAVIA MODEL#KDL-40V5100 ONLY SHOWS A BLUE SCREEN AND IT DOES NOTHNIG
Sounds like tuner fault. Contact any service technician to check and confirm. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Oct 06, 2014 | Sony Bravia KDL-40V5100 40 in. LCD HDTV
How do i repair Sony Bravia KDL screen? screen comes on but half doesn't refresh, it smears the picture. after 30 minutes (warmup), i turn the screen off and on and it works. How do I fix it?
It sounds like the LVDS cable [the flat cable that connects its T'Con board to display panel] have loose contact. Re-set this cable at both ends, and check. If you wish to get some details, http://electronicshelponline.blogspot.com/ Pull up older posts.
Dec 13, 2013 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
When I change the channel the program details appears twice in the bottom of the screen.
If you do not see this when playing a DVD etc it is more likely a issue coming from a cable or sat box etc.
Apr 29, 2012 | Sony BRAVIA KDL-52S5100 52 in. LCD HDTV
When we have our Sony Bravia on AV input, it displays a clock at the bottom right. How can we stop this?
It is On-Screen Display. Press Info " i " button on TV remote so on-screen display will disappear.
Thanks.
Oct 02, 2009 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Cracked LCD Screen
its cheaper, and this is honest as it happened to me as well it's cheaper to buy a new tv.
Jul 20, 2009 | Sony BRAVIA KDL-46V3000 Television
Screen too big for mitsubishi black diamond tv
It was actually a problem with the satellite feed, not the TV. Dish Network was zoomed in, hitting the asterisk button on the dish remote fixed the problem.
Dec 01, 2008 | Sony BRAVIA KDL-40V3000 Television
Televison & Video Logo
49 people viewed this question
Top Televison & Video Experts
