Question about Toshiba (P000204210) Motherboard
No BIOS activity
I tried to update my laptop chipset, after the reboot, the power stays on but there all other activities have stoped.
When I push the power button the screen stays black. I notice the DVD light tray stays on for a while and goes off, thats all the computer will do.
  • 70 Answers
I dont understand u properly . if u r talking abt bios file , u have not downloaded the correct bios file. or corrupted bios file,
Posted on Aug 23, 2009
Download drivers
Ummm, no such thing.......
Driver: Small piece of software that allows the Operating System to communicate with a device
BIOS: Basic Input/Output System program
When you press the Power On button, the plastic assembly of the Power On button; presses against the Power On switch located inside it.
The Soft Power On circuit is activated.
This 'excites' the Power Supply, and turns it on.
The first chipset to receive power is the BIOS chipset.
The Basic Input/Output System program is initialized.
BIOS looks to see what devices are installed, does a Ram Memory count, turns the CPU (Processor) on; and hands the computer over to the Operating System.
To perform ANYTHING with BIOS in the respect you are stating, you would be performing a BIOS update.
The BIOS program in modern personal computers, no longer uses BIOS drivers.
"Older types of OS would use the BIOS to access hardware on the computer, but most new versions now access hardware directly through drivers built into the OS."
(OS = Operating System)
http://www.wisegeek.com/what-are-bios-drivers.htm
(Sometimes people just have to see another tech state this, just to make them feel comfortable about it, IMHO)
Know this;
IF, the power goes out when you are performing a BIOS update, your computer turns into an expensive doorstop.
IF, the BIOS update is not compatible with your computer, your computer turns into an expensive doorstop.
IF, you do NOT save the original BIOS program, and the above happens, your computer turns into an expensive doorstop.
Now,..........why is it you wish to fool with your BIOS program?
Post back in a Comment. Or click on Reply at end of this solution, and post.
Regards,
joecoolvette
May 14, 2013 | ASUS Eee Computers & Internet
ASUS eee 1008 dead
First - re-seat the hard disk and reboot the computer. If the computer does not boot up then reboot and go into the BIOS configuration to see if the BIOS detects the hard drive. If it doesn't detect the hard drive then it could be faulty.
Then the hard drive needs to be replaced in the computer/laptop, Windows installed and the computer or laptop's device drivers plus your programs etc. to get a functioning computer/laptop again.
Mar 29, 2013 | ASUS Eee Computers & Internet
Bios Beep
Motherboard BIOS Recovery Jumper
  • Install the bootable BIOS upgrade disk which you previously created to do the original flash upgrade into drive A: and restart the system. If the update failed because you used the wrong BIOS update you should get the correct one and repeat this step. When the computer reboots there will most likely be no video prompts, however you can monitor this procedure using the floppy drive light and the PC speaker. When the PC speaker beeps and the floppy drive light is lit it means that it is currently copying the new BIOS onto the motherboard.
  • When the floppy drive light goes off and the PC speaker beeps (twice in most cases) the recovery should be complete. During the update procedure there might be pauses that looks like your computer is doing nothing, if so be sure to wait at least a minute to make sure the update is complete. When you are sure the BIOS update is complete and there is no more activity, power off the computer.
  • Change the jumper you changed before back into the original position so the computer can operate normally.
When you turn your computer back on your BIOS will be functional and you should be able to use your computer normally again.
Apr 30, 2012 | Acer VL460-UD4500C WINDOWS VISTA BUSINESS...
Is there a way to update the bios on windows 7 for a sony vaio pcv rx550.. i am trying to activate sleep mode on windows 7 is not available
If the Power Management Settings are not available in the BIOS, attempt the following solutions.
A. Update your Chipset and Video Graphics Drivers to the latest versions.
B. Complete the following steps to activate the sleep function in Windows 7.
1. Open Control Panel - Hardware and Sound - Power Options
2. Choose to change a power plan's settings
3. Click "Change advanced power settings"
4. After Expanding "Sleep" option, turn "Allow hybrid sleep" to "On" and set "Sleep after" to desired amount of time.
Dec 23, 2010 | Sony VAIO Digital Studio PCV-RX550 PC...
Toshiba Satellite P25-S5093 screen/boot problem
the memory cards are loose or are dirty and need the contacts cleaned with pencil eraser.
when the memory cards lose connection you lose video on screen.
Jun 18, 2010 | Toshiba Satellite P25-S5093 Notebook
Computer wont stay on once power button is pushed
yes unfortunately with this series of laptops it is VERY common for the motherboard to fail because of something called an NVIDIA chipset so if you are not hearing any fans or hard drive activity for more than 3 to 5 sec than im sorry to say that this is what it is but you can however get new motherboards on ebay for a fair price! i am sorry and i wish you the best of luck.
Dec 16, 2009 | HP Pavilion dv6000z Notebook
Same exact error here...
just disable the floppy drive through bios
and it's ok
Aug 31, 2009 | IBM ThinkPad A21m 2628 Notebook
My Hp 520 Laptop doesent show standby option activated
Either it is not enabled in your BIOS or you dont have the chipset drivers installed .
Reboot , hit F1 , go into settings for APM and verify it is enabled.
In it is enabled in BIOS and not selectable in windows , renistall the chipset drivers. Go to this link , select your OS , download and install.
http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?prodNameId=3375954&lang=en&cc=us&prodTypeId=321957&prodSeriesId=3375952&taskId=135
Should be enabled. If not check device manager for any ! symbols.
Mar 04, 2009 | IBM ThinkPad R40 2722 Notebook
Dell Insprion 8100 won't boot after bios flash
open your computer plate then refix RAM and clean dust from all circuit.also reattch all cables connectors.then put your cmos cell for 15 minutes thenrefix it.ten it resets to factory defaults.then save all settigns.then restrt the computer and then check your harddisk is propely detected or not.
Feb 09, 2009 | Dell Computers & Internet
The 4X override and fast-writes can't be supported totally in XP..........
first check the bios version and tyan's compatability site for the video cards support...
if all checks well and the bios has been updated ...
then: try running a ps/2 mouse and verify the usb components is not the error....
be sure you have support for 1.0 and 1.1 usb activated for a mouse support.. and keyboard mouse options on in the bios...
is it a mouse error ... or video card error... check for updates on the manufacturers of the mouse if usb...
Apr 27, 2008 | 3Dlabs Oxygen GVX210, (64 MB) Graphic Card
Toshiba (P000204210) Motherboard Logo
64 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
