Question about Bushnell Trail Sentry 11-9200 Digital Camera
Doesnt stay on
It will power up sometime. if i can get to power up, it shut down. tried new sd card and batteries
  • 4 more comments
  • pharris22 Nov 10, 2008
    yes it goes off, will set it and apears to be working then goes off will never buy this product again, and will not recormend it to anyone.
  • Anonymous Nov 20, 2008
    i totally agree it sucks!!
  • rockysith32 Nov 27, 2008
    go off some and want take pictures sometimes it shows error or somthing
  • Anonymous Jan 04, 2009
    i just put new batteries in it, tryed turning it on and all it did was - - - - in the screen and the red light blinked for awhile?
  • bass380 Jan 05, 2009
    Yep, shuts off automatically after about 2 days. What is bushnell doing (if anything) about this issue?
    Yep, I have the same problem. Works for about 2 days and then automatically shuts off. What is Bushnell doing (if anything) about this problem?
This camera eats the batteries. I have had the same problem. I would suggest buying rechargeable batteries and keeping them fresh. It will work fine with a new set of batteries. The 30 day battery life is a lie. More like a couple days if that. I use this for paranormal research and since I don't need it in a field or trail, I have a conversion from D cell to 110 volt below.
BE-4AA adapter, four AA to D size shell adapters along with a 110VAC to 12VDC adapter . This will give you 4 D size cells and an output voltage of 6VDC @ 500mA, from a 110VAC source.
But if this in on a game trail, there will not be a use for the 110 volt. Bushnell needs to review this camera alittle better and fix it's energy drain.
Posted on Nov 13, 2008
Sanyo vpc-s1213 12 megapixel, 3x optical zoom lens stuck out, won't turn on
Mine did the same thing after I put in a new sd card. Finally after trying everything else, took out the sd card and it worked.
Apr 10, 2012 | Cameras
My camera switches off immediately after swithching on, it just shows a low battery sign and goes off. On the contrary if I select the discharging option from the camera settings menu the same batteries...
These cameras use both SD and XD cards. The SD cards are the cause of the draining. Switch to an XD card or remove your SD card while not in use and your batteries will not drain. :)
Jan 01, 2011 | Fuji FinePix S1000FD Digital Camera
Camera works with standard SD memory card, but not SDHC
There are hardware incompatibilities between SD and SDHC cards. They're upward compatible in that SDHC devices will accept SD cards but not the other way around. You will have to hunt down SD cards, 2GB and smaller.
Apr 28, 2010 | Nikon Coolpix L1 Digital Camera
I have an extensa 5420-5687. 1 day my laptop just
the power cord has shorted out you will need to buy a new one
If I have helped you please click the yes this was helpful button
Dec 03, 2009 | Acer Extensa 5420-5687 Notebook
Lines on LCD display, file error, lens not opening all the way.
Sounds like 2 things, unformatted SD card and carbon based alkaline batteries. If using SD card, you MUST FORMAT the card upon first use and then occasionally there after. This model camera cannot use an SD card bigger than 1GB, so make sure you aren't using a 2GB or higher. Also, make sure you stay away from alkaline batteries, you will waste your money. Try using Energizer Lithium or Duracell Power Pix, you will get your moneys worth.
Aug 17, 2009 | Polaroid i733LP Digital Camera
Micro Sd card not working
try getting a new sd card
Mar 25, 2009 | Nintendo DS Console
Shuts itself off but lens won't retract
Have you initialized the SD card? Go to the set-up menu and initialize the card. Also check for a timed-shut-off option.
Dec 03, 2008 | Kodak EasyShare C613 Digital Camera
Dropped digital camera and it won't stay on
try taking ou sd card once maby u shocked it the lite card try it out oif not then most likey the main bord broke off a small connection sellon ebay broke or take it in for major repair i owuld try kodak v1233 models i own i droped mine once still works lol tuff cam full hd 12 mp
Oct 06, 2008 | Olympus Stylus 750 Digital Camera
Memory card problem
Are you sure you have the right type of memory card? Make sure you use an SD/MMC card. You might try another SD card.
Is this a new camera? I bought one once and the card slot was defective. I took it back right away, rather than trying to force a card into it.
Mike
Nov 21, 2007 | Samsung Digimax A400 Digital Camera
Coolpix 8800 shuts down
Make sure to use good NiMH batteries. Another possiblity is a problem with the card. Borrow a card and see if it has any effect. check to see that the pins in the card slot are all aligned, none out of place. check that the card door and the battery door close firmly, with some pressure. The camera can shut down when it has a problem detecting that the doors are closed. When it does turn on, play with the zoom without taking pictures, zoom in and out, if during zoom the camera shuts down then you might have a lens problem, something is malfunctioning in the lens mechanism and the camera shuts down to prevent damage. Good luck
May 19, 2006 | Nikon Coolpix 8800 Digital Camera
Bushnell Trail Sentry 11-9200 Digital Camera Logo
281 people viewed this question
Top Bushnell Cameras Experts
Johnny Massengill
Johnny Massengill
Are you a Bushnell Camera Expert? Answer questions, earn points and help others
