I just received cable @ my new house,im trying to program t.v. from antenna to cable . on set-up mode once i'm down to channel set-up ,it will not let me switch from antenna to cable!!! please help.....thanx
Do not have remote available. Want to program for cable but can't find button on front or procedure. Do not have manual.Do not have remote available. Want to program for cable but can't find button on front or procedure. Do not have manual.
AnonymousMar 18, 2008
Do not have remote. Want to program for cable but can't find any front button or procedure to program.Do not have remote. Want to program for cable but can't find any front button or procedure to program.
In settings, find INPUT or SOURCE, select CABLE and go from there. To find channels on when using the ANTENNA mode, you have to have a DIGITAL antenna hooked up to the TV. It will then search for any stronger digital signal. Most of the time if you move the antenna after the signal search, you will have to do another search to receive the signal.
This can happen when there is radio interference near the coaxial cables. Sometimes the interference is behind walls. The solution is to try a different combination of modulation and channel than what the DISH receiver is current set.
The DISH menu screen for this setting is Menu-6-1-5. With dual-tuner receivers, typically "TV 1 Out" is the TV that is connected in the same room as the receiver is located. "TV 2 Out" is the tuner that is fed to the remote TV via backfed coaxial signal.
All that needs to be done is to change the channel and mode going to the effected TV to something different. If your channel/mode is currently set to Air/60, try changing it to Cable/73. When you change the mode/channel in the DISH receiver, you need to set the remote TV to the same mode and channel.
Keep in mind that with some TV companies like VIZIO, they call their "Air" mode "Antenna". With VIZIO's the TV must be set on TV input and then go into the Menu to the Settings, Tuner Settings. Change mode type to match what you are trying on the DISH receiver, exit the VIZIO menu and manually enter the channel number.
Eventually with trial and error, you will find a mode/channel combination that isn't effected by your particular environmental interference.
If you are trying to get the remote programmed to the receiver you can remove the smartcard from the receiver and that will prompt the system info screen. This will allow you to program the remote to the receiver.
If you need the process for programming the remote, here it is:
Go to System Info screen (in this case -- obtain by removing smartcard from receiver)
Hold down the SAT button until all mode lights light up.
Enter a number between 1 and 15 using the numeric keypad on the remote.
Press the pound (#) button
Once the SAT button blinks three times, press record.
Press menu on the remote and search for programing and you should see choices for receiving air channels or cable. Keep trying..and then go ahead and prees auto or search programing.
You probably have to find your original remote to the set and go through setup in your menu. On most sets, there will be a menu item which will allow you to switch from Cable mode to Air mode. If you have no Cable connected, then you must set tuner in Air mode.
If you are using an external device to run on channel three, then try this:
Make sure device (rather it's a vcr or game console), is hooked up to your Antenna Input connector. Also, some of these devices will have a small hidden switch on back that says 3 and 4. Move the switch to 3 position. Turn on device. Go into TV menu and do a Channel scan. This should auto program any device hooked up to the TV antenna input jack to channel three.
Keep in mind that you may not receive anything by Feburary of this year without an HD converter box to tune in channels with and outdoor antenna.
Your "tuner" in the menu is set on "off air" or "antenna. It should be set on "cable" or "dish". See if you can go into your menu with the buttons on the set and change your tuner setting. Keever
Most tv's have an Antenna mode and a cable mode. If you have cable tv service, the cable mode must be selected in order to receive channels higher than 23. Then you must auto program the channels thru the menu screen on the tv to receive the channels above 23. If you have a house antenna or rabbit ears, its hit or miss on receiving all VHF and UHV channels.
In the menu theres a channel set up mode. You want to switch from antenna to cable mode, then do an auto search. Then all your cable channels will come in. Your going to need the original remote to go into the correct menu. good Luck
model # WF13C1
I need the remote code becaus I can't find the Symphonic remote that camee with the TV?VCR
