Question about HP Office Equipment & Supplies
I am having trouble printing out plates (on a coated glossy stock) for our printing presses. Sometimes I will get a ghosting line across the plate, other times there will be marks across the plate like the toner is dragging onto the paper. I am also experiencing the edges around the image is giving me a gray haze. We have done the maintenance kits, replaced toner cartridges replaced rollers. Anything that I thought I could fix, i tried. Please HELP! We are wasting so much money and time.
    Problem Solver:
  • 4 Answers
I know you have replaced the toner cartridge but have you replaced it with the HP Brand. Also, what model do you have? I have taken many, many calls on remanufactured or compatible toner cartridges for steaks, reprinting and and even paper feed problems because they leak.
Posted on Nov 03, 2008
Hi, When printing photos, my photos have horizontal light coloured lines across them. When I print the nozzle check pattern all colours match the guide with the exception of the light magenta....
Epsons are notorious for this sort of problem, especially in used infrequently as ink residue dries on the print head; try using a cleaning cartridge, or swab around relevant print head with cotton bud and ethanol/isopropyl alcohol. Here are examples of cleaning carts, there are others
Jan 03, 2011 | Epson Stylus Photo R200 InkJet Printer
Xerox 6350 prints ghost page every page printed. It is printing a ghost imge of the previous document printed on every page.
If the ghost is black then you might have a bad Black Developer 116-2011-00
If the ghost is in all colors then it may be your fuser, or possibly just your paper settings. (If you are using glossy paper or card stock this needs to be fed from the MPT tray and defined correctly in the control panel)
Item, Inc.
Oct 13, 2009 | Xerox Phaser 6350/YDT Laser Printer
Ink from my deskjet 5650 smears off my glossy postcards.
Hello there jbaerpynes.
You must use HP branded glossy paper in this particular printer as recommended by the manufacturer. Because HP ink is much finer than most other inkjet printers, the ink sometimes does not set in properly on generic papers, especially glossy ones, and can smear right off.
Try new paper and get back to me. If you have any other questions, please don't hesitate to comment on my post. If I helped you, please give me a positive rating.
-Phil Traversa
Aug 19, 2009 | HP LaserJet 1300 Printer
Color prints have two strips of toner that will rub off.
Fixed the problem with the advice of one of your members!
Jan 30, 2009 | Konica Minolta magicolor 2430 DL Laser...
Peeled beater and hook
Stan. If you were to keep these attachments soaking in alcohol (rubbing) between uses, I'd say yes, however this would probably make more coating flake off. This coating goes into the food you're mixing. Bacteria will remain between the metal part of the attachment and the plastic coating,where you can't scrub it off.
Replace them. Try to find all metal ones. While you're at it, throw out all cracked plates and coffee mugs too, as these cracks harbour bacteria that will survive normal dishwashing. If you are ever in a restaurant and are served food on a cracked plate refuse it and tell them not to just scrape the food onto another plate.
I spent 13 years in the restaurant business, anytime we came across a cracked plate cup or mug, into the trash it went. food and all. Dont take chances with your health. If you found this solution helpfull, please rate it Good luck. ricardok45
Jan 08, 2009 | KitchenAid KSM150PS Artisan Series Stand...
Ink not dry when printing photographs
Download the proper drivers from - DON"T use standard Windows drivers.
When you have the proper drivers installed, you will find an "Advanced" tab in your "Printing Preferences" where you can set "Ink Volume" and "Dry Time".
Try using less ink and a longer dry time.
Also, make sure you're using photopaper that is designed for "INK JET PRINTERS".
(Laser Jet paper won't work).
Any photo that you print on glossy/semi-gloss paper will be wet as it emerges from the printer (especially ones requiring lots of ink).
You could manualy "catch" each one and set aside to dry, which should only take a minute or two.
Professional printers use a special drying powder and timed spray rig when printing on coated cover stock and glossy materials.
Nov 27, 2008 | Office Equipment & Supplies
Cleaning Ironing Steam Press
If it is not teflon coated sand it of with 400 grit sand paper. sand from front to back and it will create a nice grain and
this paper is so fine it will not scratch the surface. Sand it gently until the substance is completely gone. Do not do
this if it is teflon coated. Hope this helps you.
Jul 11, 2008 | Yamata PSP-990A Iron
Face plate
You could use fine steel wool to smooth out scratches. If the original finish was glossy, spray plate with light coats of clear acrylate
Apr 28, 2008 | Audio Players & Recorders
try using different 12 pt stocks....they are many different kinds of paper
Oct 25, 2007 | Xante Ilumina Digital Color Press Printer
93 people viewed this question
Ben Johnson
