How can I clear DR mode I can't recievd
My machine is a Brother MFC 5841 cn2
  • 318 Answers
Open front cover press and hold clear button untill it ask you if you replaced the drum select yes.
Please rate me?
Posted on Nov 04, 2008
I replaced my drum and the output quality is poor and light in areas
did you clear the required counters and run required procedures? If not the machine still thinks it has a old drum because counter was not cleared only way copier will know it has a new drum
Mar 23, 2012 | Brother DCP 8060, 8065DN, HL 5240, 5250DN,...
I cannot set my MFC 8460n to receive faxes - it says it is in DR mode
The machine is set to Distinctive Ring mode.
Turning off Distinctive Ring
Press Menu, 2, 0, 2
Press a or b to select Off. Press OK
Press Stop/Exit.
Mar 05, 2011 | Brother MFC-8460N All-In-One Printer
My brother mfc6490cw says dr mode what is this
DR stands for distigntive ring.
Before you are able to change the receive mode, you will need to turn off DR.
To turn off DR press MENU, then the down arrow until FAX and press OK. Then with down arrow choose MISC and press OK. Then with down arrow chose DISTINGTIVE and OK, then down arrow until OFF and press OK.
Jun 06, 2010 | Brother MFC 210C All-In-One InkJet Printer
Can't set mode to receive fax, read through manuel says DR mode in use. fax does'nt pickup when a fax or call comes in stuck in manual.
DR MODE is in use means that your machine is setup with the distinctive ring feature, to turn it off follow the directions below.
Turning off the Distinctive Ring
1 Press Menu/Set, 2, 0, 2.
2 Press ▲ or ▼ to select Off.
Press Menu/Set.
3 Press Stop/Exit.
Then you will be able to change the receive mode.
Apr 16, 2010 | Brother MFC 210C All-In-One InkJet Printer
Dr-360 mfc drum reset
Brother MFC-7345n. DR-360 With power on and door open hold down the Clear/Back button. When asked new drum 1 for yes and 2 for no. Press 1 for yes to reset drum life
Feb 02, 2010 | Brother HL-2040 Laser Printer
Brother MFC-7420 just started printing a shadow image
Sounds like a bad drum cartridge. Pull the toner/drum cartridge out of the machine and set it down. Press down on a (blue?) tab to release the toner cartridge, and you can lift the toner cartridge out of the drum cartridge. There is a cleaning blade in there - a soft plastic blade that rides against the drum and scrapes off toner that didn't get transferred to the paper. If it gets stuck off the drum surface, images repeat a few inches (one drum circumference) down the page.
A new DR-350 drum unit should fix it. have the machine's power on when replacing it. While the door is open, touch the CLEAR key. The display will read "REPLACE DRUM?" or something like that. Press 1 for Yes.
Jan 05, 2010 | Brother MFC 7420 All-In-One Laser Printer
How do you shut off dr mode on brother mfc 7340
press menu, go down to fax press ok.
go to miscellanious press ok,
press ok on distinctive.
go up or down until it says distinctive off press ok then stop.
Nov 10, 2009 | Brother MFC-7340 All-In-One Laser Printer
MFC 465 CN - says FAX in DR Mode...What is that?
DR mode is distinctive ring, you have to go into fax setup and step through the options. If you go to print reports and select user settings the report will tell you what it's set for and the options are found in the same order they are printed.
Jun 24, 2009 | Brother MFC-465CN InkJet Printer
WHAT IS DR MODE AND HOW DO I TURN IT OFF
DR Mode is "Distinctive Ringing". You can turn it off in the menu (Menu -> Fax -> Other, if i recall correctly).
Jun 04, 2009 | Brother MFC-465CN InkJet Printer
Mfc 8460n dr mode in use
The message DR mode in use or BT Call Sign On will appear on the display of the Brother machine if you attempt to change the receive mode from Manual to another mode when the Distinctive Ring feature (BT Call Sign) is turned ON. If you want to change the Receive Mode, set the Distinctive Ring feature (BT Call Sign) OFF.
  1. Press Menu or Menu/Set.
  2. Select Fax => Miscellaneous or Tel Service => Distinctive or BT Call Sign.
  3. Press the Up or Down Arrow key to select off. Press OK or Menu/Set.
  4. Press Stop/Exit.
Jul 16, 2008 | Brother Office Equipment & Supplies
139 people viewed this question
jasbo
jasbo
