Question about Brother MFC 210C All-In-One InkJet Printer
Initialize Error the lcd screen reads can not initialize, please refer to manual. i have unplugged and reset the printer, but this still happens. what else can i do????
  • lfrangione Nov 04, 2008
    My brother MFC 210c printer appears to have the same problem. Failure to initialize ... check troubleshooting in manual... what do I do??... nothing seems to work
  • Anonymous Nov 12, 2008
    it keeps saying can clean
MFC210C unable to print and error message check troubleshooting and maintenance guide book. Check guide and cannot find any solution.
Posted on Jan 25, 2009
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 143 Answers
1. reset absorbers counter
2. if #1 does'nt work, see for mechanical problems...
If you're never disassembly your printer - call service...
Posted on Nov 14, 2008
Epson Pro 7800 Maintenance Request 0040
Hi Frank,
Please supply a detailed description of the problem. Give as much details leading up to the problem as you can so that I may understand what's happening.
I'll be waiting for your response.
Randy
Feb 07, 2012 | Epson Stylus Pro 9800 InkJet Printer
Touch screen frozen
the best solution to fix this problem is to get it repaired or replace if it is still under warranty.
I'll let you know if there is any other solution to fix this.
Apr 12, 2008 | Sony Cyber-shot DSC-N2 Digital Camera
When camera turn , on screen -turn off and on again
Error: TURN THE POWER OFF AND ON AGAIN is displayed on the LCD screen when the Lens Mechanism is stuck or when affected by any malfunction. If turning the power on and off again does not resolve the error message, try doing a power reset and Initialize option.
Performing a manual power reset
Turn off the camera.
Remove the battery pack.
Press and hold the power button for 30 seconds.
Allow the camera to remain without power for 60 seconds.
Reinsert the battery pack.
Turn on the camera.
To reset the Camera back to factory default, select the INITIALIZE Option from the Main Setting Menu of the Camera to OK. This will set the user defined settings back to factory default. The images and videos will not get deleted.
If the issue persists, service may be required.
Thanks for contacting FixYa.
Aug 14, 2011 | Sony DSC-S930 Digital Camera
My Cyber Shot DSC W55 when i open it the lens keeps moving forward and backward and then something shows on the screen which says First "ACCESS" then the next one is "Turn The power off and...
Error: TURN THE POWER OFF AND ON AGAIN or Access is displayed on the LCD screen when the Lens Mechanism is stuck or when affected by any malfunction. If turning the power on and off again does not resolve the error message, try doing a power reset and Initialize option.
Turn on the camera.
To reset the Camera back to factory default, select the INITIALIZE Option from the SET UP1 Menu of the Camera to OK.This will set the user defined settings back to factory default. The images and videos will not get deleted.
Feb 24, 2011 | Sony Cyber-shot DSC-W55 Digital Camera
I have a problem with my hp printer, problem read on mini LCD "refer to printer documentation" I can not switch to any bottom or anything I will need your help to reset my printer hp C5250
Turn the printer on and unplug the power cord from the back.
Press and hold the pound (#) and (6) buttons at the same time.
Plug in the power cord back into the printer and wait for the printer to initialize.
Release the buttons.
Feb 14, 2011 | HP Photosmart C5280 Printer
LCD is almost white , no picture seen, Video section is not responding
This may be due to the LCD Screen issue or the CCD Image Sensor failure in the Camera.
To confirm the issue, please check if the previously captured images are displaying normally. The previously captured images and icons will get displayed normally if the CCD image sensor issue is there in the Camera.
If this happens only with the live view, then try Initializing the Camera.
The Initialize option works only if you're able to access the menu of the Camera, otherwise power reset the Camera.
The Initialize option can be done only if the Menu of the Camera is accessible. To access Initialize select MENU-->SETUP-->SETUP 1-->INITIALIZE-->OK.
To power reset the Camera, remove the batteries from the Camera and then press and hold the POWER BUTTON of the Camera for 15 seconds and then reinsert the batteries after 1 minute and check if the Camera works normally.
If the issue is not resolved after resetting, service may be required.
Thanks for using FixYa.
Jan 19, 2011 | Sony Cyber-Shot DSC-S40 Digital Camera
Turn on the camera.
Thanks,
KenSolutions
FixYa
Sep 17, 2010 | Sony Cyber-shot DSC-H50 Digital Camera
Printer is showing "error: 0xf0af0001 Reset Power". I have unplugged and then plugged in printer multiple times and printer comes ok for about 30 seconds and then the same error message appears will all...
last month i had same problem and i contacted customer care and i got this solution. And this works.
Step 1:
Perform a partial reset.
A partial reset returns the user settings to the factory defaults. The language and country/region settings may also be deleted.
Please perform the partial reset using the following steps:
a. Unplug the power cord from the all-in-one.
b. Press and hold the "#" and 3 button on the front panel keypad.
c. While still holding the buttons down, plug the power cord back in. Release the buttons after the all-in-one begins to initialize.
If the issue persists, follow Step 2.
Step 2:
Perform a semi-full reset.
b. Press and hold the "#" and 6 button on the front panel keypad.
Jun 24, 2010 | HP Officejet 5610 All-In-One InkJet...
Unable to open printer(read error) this is the error message I have received. I have turned off the printer and the computer but the message is the same. I also deleted the printing job, turned everything...
try to remove printer from add printer wizard, unplug cable and insert, found new hardware must be appear, from that locate driver manually to initialize. restart pc and run test print wizard.
Mar 25, 2010 | Canon I960 InkJet Photo Printer
HP Laser Jet 3200se fax machine
Hi..
The service error refers to an hardware issue with the printer.. U can try the following step,if this didnt resolve the issue only option is servicing.
1. Unplug printer.
2. Press and hold SYMBOLS & ENTER/MENU.
3. Continue to hold down the buttons while you plug back in the printer, through the entire
power-on sequence.
4. When display reads PERMANENT STORAGE INITIALIZE or HP LASERJET 3200
release the buttons.
Jan 09, 2009 | HP LaserJet 3200se Printer
Brother MFC 210C All-In-One InkJet Printer Logo
199 people viewed this question
CheckitRight
CheckitRight
Soulvisitor
Soulvisitor
Ron Dufek
Ron Dufek
