Question about Electrical Supplies
Bathroom Pull switch
My cord switch in my bathroom broke, it didn't click when pulled and the light remained permanently on, it was fitted by a qualified electrician. I bought a new one and replaced the broken one, it worked fine a couple of times then the same thing happened. I have a fan linked to the light switch and 4 different coloured wires which are red, blue, yellow and the earth. on the switch is L1, L2, COM and earth. please can you help and let me know if I am using the right switch and if there is a reason why both switches have broken in the same way.
  • Anonymous Dec 22, 2008
    I have a similar problem but the light is permanently on off. I dont want to open it so could anyone help me?
  • 417 Answers
There are two possibilities here,
1. it is a mechanical failure i.e a part of the linkage has broken leaving the switch in the on position, did you see anything obviously wrong with the old switch?
2. It is an electrical failure either overload or arcing when the switch is being operated sometimes welding the contacts together. This can happen if the light is a fluorescent tube or ring type, which in combination with the fan start up, can cause this situation. If this is the case you need a higher current rated switch.
Please remember to rate this solution.
Posted on Nov 03, 2008
Dimplex bathroom fan heater cord problem
take the cover off and clean the inside and were the cord is and use some wd 40 turn of the supply first and that should loosen it for you
Jan 06, 2014 | Dimplex Fx20ve 2kw Timer Wall Mounted...
Switching on
The switch is failing.
Dec 19, 2013 | Heating & Cooling
Dimplex Fx20ve 2kw Timer Wall Mounted Bathroom Downflow Fan Heater Pull Cord is stuck
turn of the powere and take the cover off and clean the pull cord and the use a bit of lubricant to keep it free that should loosen it
Sep 24, 2013 | Dimplex Fx20ve 2kw Timer Wall Mounted...
Hi there just fitted brand new bathroom pull cord.... works but have to pull it three times. Any ideas why ? Thanks Lydia
if the wires are correctly installed, and tight. then you may have a bad pull chain switch. good-day ! but first turn off electric, and see if the wires are not loose and the wire nuts are tight behind light.
Feb 16, 2012 | Duravit Home
Need wiring diagram live cable from switch to pull switch then to
If I am understanding you correctly .,. then like this ..
Please Vote !!
Jan 12, 2010 | Solar 2-wire Pull Chain Light Switch For...
Bathroom fan wiring.
There are two wires in the power cord of your bathroom fan. Buy an electrical plug with a built-in switch. The plug has two terminals in it. Just get the two wires of the bathroom fan to the two terminals of the electrical plug. Secure all bare wires along the line with an electical tape. Get this done, and send us your e-mail it this help you.
Oct 03, 2009 | Electrical Supplies
Bathroom extractor fan won't switch off
The fan most likely is turned on by the bathroom light switch. You likely have a defective fan motor.
May 01, 2017 | Hampton Bay 24002 Ceiling Fan
Pull cord switch
If it is a 1 way switch circuit (2core +earth cable) it should be LIVE/HOT in COM and Aux live (to the light) in L1 . I
f you have a 2 way circuit (3 core + earth cable) the aux strappers go in L1 & L2. and LIVE/HOT to COM
Remember to disconnect the power before working on electric wiring.
Oct 15, 2008 | Electrical Supplies
Electrical Supplies Logo
655 people viewed this question
Top Electrical Supplies Experts
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
