Question about RCA P61939 61" Rear Projection Television
No power to my tv set.
The tv set gets very minimal use so there is not a lot of hour spent on the tv.On morning the set turned on i viewed it for a while and the fallowing eavning when i got home the set would not power on.There is no picture,no sound there is nothing.Any help would be much apreciated.Thank you.
    Sergeant:
  • 337 Answers
While you were out you might have had a lost of power in the house or maybe lighting that day,if you have no lights and no indication of power at all you can start by checking the main fuse witch is close to where the power cord comes into the set,if you decide to do it yourself be carefull and make sure the set is unplug from the wall,if the fuse is open repalce it with the same type but if it blows right away you will need help from a techinician to find the short that blows the fuse.Be careful.
Posted on Oct 02, 2006
SOURCE:
I have had a total of 3 blown bulbs. The last one worked for about 5 hours. When I woke up the next morning and turned the tv on it made a loud cracking sound and the bulb busted. What could be causing...
Every set that uses a lamp for brightness has a ballast----it essentially provides power to fire the lamp----power in to the ballast will be around 300 volts DC in most sets and the output to the lamp over 14,000 volts with lots of RF---like spark plug wires.
Dec 08, 2012 | Televison & Video
Bought this last night...we spent over 1/2 an hour trying to get it to work properly...finally achieved that...now this morning... 1) I can't get the water to heat up, 2) it keeps turning off, 3) as...
Clearly, your issues are related to issues that can only be corrected at the factory.
Keurig Customer Service: http://www.keurig.com/customer-service
Dec 18, 2010 | Keurig Platinum B70 Coffee Maker
LCD HDTV turns off, displays lines & static w/ loud noises
check in your manual and follow instructions on updating the software. you download the file to computer then move it to a memory stick (USB), then simply insert it into the tv
Mar 01, 2010 | Televison & Video
Have an RCA 60" rear projection tv (Model: P60752EB, Chassis: PTK169PEC). TV will not turn on. While pressing the power button it will make a clicking noise. Otherwise, there is no picture or sound. Have...
It is the 169 chassis-over 300 different models used it and are different-answer something for me--does it have a GREEN power light that comes on for a second and goes off?
I know this set well and to be honest hated working on them--Let me know about the power light and I will tell you what I know.
At one point in time this was a very good set--I do understand about paying a lot to get it fixed and having it bad again.
I am here to help people and I bet I know more about this set than almost anyone else here.
SD TECH
Dec 14, 2009 | RCA P60921 60" Rear Projection Television
Television set does not turn on. Checked power and connections
Common causes for failures in TV sets are the power supply, and or scan circuit failures. This type of repair could be costly. If the set has a lot of hours of usage, it may not be worth to service.
Jerry G.
Jun 30, 2009 | Toshiba 27D46 27" TV
No signal
LOOK N THE MAIN MENU ON THE SATELITE CONVERTER BOX LOCATE WHAT CHANNEL TV IS PROGRAMMED TOO TUNE TV TO THAT CHANNEL WILL EITHER WORK ON AIR OR CABLE
Dec 13, 2008 | Televison & Video
Tv turns off after 1.5-2 hrs
check the power supply, it seems to be a common problem with this tv. this website was made by some brilliant french guy and it gives a lot of good information about the problem, and how to fix it. I recommend either getting a new board from one of the suppliers he lists or do as I did and get the small chip and solder it in or have someone do it for you. mine is working great and I only spent $20 on the chip. http://pagesperso-orange.fr/alain.mionnet/enii3210j.htm
Jun 13, 2008 | ViewSonic N3250W Television
Replacement power cord
I spent about an hour web searching, but I did find the model number of the power cord. From there, I searched the model number and found numerous websites that carried it.
Jun 10, 2008 | GE 27GT616 27" TV
TV don't want to turn on and just sits there and blinks 7 Sony FD Trinitron WDGA
If the led blinks 7 times it means, the high voltage has exceeded 33k and the unit goes immediately into safety shutdown. This defect is normally found in the power supply regulation and horizontal circuits.
I would suggest to have it repair instead of having the set ON the whole time.
In regards to fire hazards is very unlikely since the latest components are using a flame retardant(PBB and PBDE) chemicals to avoid flames.
Jan 24, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Color problem
my guess would be a cold solder joint on the av board. when picture looks good go to connectors and wiggle them if the set acts up you have your answer.
Jun 08, 2006 | Mitsubishi LT-3020 30 in. HD-Ready LCD...
RCA P61939 61" Rear Projection Television Logo
96 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
