Question about Jwin JD-VD502 DVD Player
DVD Jwin JD-VD502 dead
This DVD have U3 burn *(power supply), I need part number or ID for this .
2 Suggested Answers
shaggyrat
  • 1224 Answers
SOURCE: JWIN DVD PLAYER JD-VD502
its the new disc setup for dvd's there using a new dvd conversion set up disc old dvd players just dont read the new dvd's just the other night did what you did but i went out and bought a new dvd player gotta keep up with technology
if you have warranty return for update or buy new technology it sucks i know but just put old dvd in another room have fun with the old one when you buy the new one
Posted on May 07, 2008
JD-VD502 DVD player blew a fuse. I replaced it with a 1-amp 250 volt from radio shack but as soon as I powered on, the fuse flashed and blew again. I tried twice, same result. Is there a reason this keeps...
Hello
Never put any fuse in it and switch ON. It has some short with internal circuit, and should be repaired before installing a new fuse. The fuse use is as a protection device to protect the other circuit parts from further damage. If you will put an other fuse, and switch it ON again, you are making things more worse than present. Find out the reason for buring out fuse. If you can do it by yourself. Otherwise get it repaired by any experienced service personal. Never make it irreparable. OK.
May 07, 2011 | Jwin JD-VD502 DVD Player
Ten pieces of my jwin portable dvd player has a problem with the display it shows white how can i fox that?
White light means that your LCD display panel is not triggering only the back light of the panel is working. They come from China.
Mar 08, 2011 | Jwin JD-VD502 DVD Player
How to connect to cable box and TV using only coax cables
If I understand you correctly you do not have the RCA inputs on the TV and need to hook up this DVD with a coax cable.
What you will need to get is a RF modulator with both coax and RCA inputs. This will allow you to connect the Cable box up to the modulator with the coax line as normal and then the DVD with the RCA cable to the modulator and then the modulator will connect to the TV with a coax giving you access to both. Here is an example of the type of Modulator you will need.
MODULATOR
Good Luck....
Jan 14, 2010 | Jwin JD-VD502 DVD Player
I have jwin jd-vd503 it does not work it shows
Jwin JD-VD200 / JD-VD203 / JD-VD500 / JD-VD503
  1. (Open the disc tray)
  2. Press SETUP
  3. Press 1, 3, 6, 9
  4. Press LEFT 3 x
  5. Press RIGHT
  6. A new menu entry appears (Version)
  7. Select it and select RC (0=codefree)
Sep 15, 2009 | Jwin JD-VD502 DVD Player
May 07, 2008 | Jwin JD-VD502 DVD Player
Standby Mode
power down the main supply and swithc it ON normally.
now try to restore the factory settings. then try to put it in stand by and bring it to normal mode.
Dec 24, 2007 | Jwin JD-VD502 DVD Player
No Picture
Pull the AC power out, wait 30 seconds and plug it back in. Sometimes pushing the on and off button isn't enough.
Sep 07, 2007 | Jwin JD-VD502 DVD Player
JWIN JD-VD502
Sounds like a PAL/ NTSC problem which you must fix on either your TV input or DVD player output or settings. This should fix the problem if you alter the settings.
Nov 15, 2006 | Jwin JD-VD502 DVD Player
Jwin JD-VD502 DVD Player Logo
26 people viewed this question
Top Jwin Televison & Video Experts
Jaime Hernandez
romy sibug
romy sibug
Raj Patel
Are you a Jwin Televison and Video Expert? Answer questions, earn points and help others
