Question about Daewoo Microwave Ovens
Daewoo microwave problem
There are no microwave repair places in my area, so an engineer friend diagnosed the problem. He said there was a short circuit in the printed circuit board, and he told me the part # to replace.
However, Daewoo won't sell it to me, because it didn't come through an "official" repair shop. Is there any place that sells Daewoo boards?
It's M254 DS 8-V-0.
Thanks,
Bart
  • William Miller
    William Miller May 11, 2010
    That is not a proper Daewoo part number you're showing.
    What's your oven's model number, and what specific problem are you having with it?
    We regularly repair these control boards for
    customers nationwide by mail for $39.95 postpaid in about a week with a one-year guarantee.
    William E. Miller
    prototech@usa.net
    http://www.microwavedisplay.com
The Daewoo model # is WM 1010CC.
The unit blows a fuse every time I open the door to get food out.
Please suggest a fix!
Bart Gibbons
Posted on Nov 13, 2008
Flashing fire came out of the element which if on top of the microwave. This is an old model
Hello, Rosemary -
Apparently something in the microwave shorted out. You don't state the make and model of the microwave. There may be some kitchen appliance repair place in your area where you can take it to be looked at and _possibly_ repaired. However, it may be quicker, and more cost effective, to purchase a new microwave and have your old microwave recycled properly.
Note: These days many municipalities or counties have electronics recycling centers or specially identified days for residents to bring old and "dead" electronics for proper recycling. This is the Earth911.com web page you can use to find a place to recycle electronics near you (in the USA): https://search.earth911.com/?utm_source=earth911-header&utm_medium=top-navigation-menu&utm_campaign=top-nav-recycle-search-button .
Best wishes
Dec 17, 2017 | Microwave Ovens
How do I repair the turntable in a DAEWOO DMR603 microwave oven
Purchase a new motor, take the dish out and remove the mains supply. Place the oven on its side with the door open. Remove the cover plate beneath the motor, disconnect the motor and remove it. Replace it with the new motor. Replace the cover using a 3.. self tapping screw to secure it. Refit the turntable and dish, place a cup of cold water on the plate then plug it in and test.
Aug 18, 2017 | Daewoo Microwave Ovens
Daewoo microwave does everything except heat?
Possibly the high voltage fuse or the diode pack or capacitors have failed. BE VERY CAREFUL if you are attempting repairs on microwaves. The high voltage side is usually up to 5000 volts. If you are uncertain about electrical repairs on these, DONT attempt it. The high voltages in certain areas of a microwave oven can kill... The machine can store this electricity in its capacitor circuits even when the unit is unplugged.
Aug 26, 2014 | Microwave Ovens
Hi I have a daewoo microwave kor/6n9rr 800watt the upper fuse has blown ,enquired with spares suppliers ,only fuse showing on their parts was one with wire attached each end with terminals which I...
Hello Mary
You shouldn't be working on, or inside a microwave oven. They are not a consumer repair job due to the debilitating effects of microwave energy, the high voltages inside the capacitor, and the highly poisonous core to the magnetron.
Fuses blow for a reason, you have to find the reason before replacing the fuse. Unless you are an electrical engineer, take it to an authorised repair centre, or just buy a new one.
Apr 17, 2017 | Daewoo KOR6N9RR Microwave Oven
Need owners manual for Koc-925T-WHI
HELLO.
solution below.
The best place to get the microwave oven manual guide is to visit the manufacturer website to order for the manual stating the microwave model number and give our house detailed address.
However microwave manual guide can also be purchase at any microwave oven authorized dealer around your local area with the model number for compactibility(easy use).
Thanks.
Sep 19, 2011 | Daewoo KOC-925T Microwave Oven
Daewoo microwave KOR-6QAB is not not heating anything plz help me
It sounds like the magnetron may have either failed or is not being supplied with the extremely high voltage required to run it.
YOUR SAFETY IS PARAMOUNT
This is a job for a professional but if you are safety clued up, here's instruction.
Make sure the !!!!capacitor is discharged!!!!! before attempting any sort of repair.
Check the door interlock switches first then the high voltage diode with either an AVO model 8 or moving coil meter on high resistance range for short circuit, (DVM's won't show the fault!), the capacitor can fail and go short circuit, the feed fuse on the primary of the high voltage transformer and then finally, the magnetron is best checked by substitution.
Hope that helps.
Feb 20, 2011 | Daewoo KOR-63DB Microwave Oven
Not heating up
weve found its not worth repairing microwaves
Jun 29, 2010 | Daewoo KOC-925T Microwave Oven
Daewoo kor-861h, electrical smell and will not heat.
Turn if off, and leave it alone, remove it, if you can remove the unit, take it in for service, something is wrong if you smell electrical, most people for some reason can smell and identify correctly electrical or at least insulation burning smells, which means something is burning internally, not safe, fire hazard, unit needs to be repaired by qualified technician or replaced with new unit, take no chances, nothing you can do to repair this, could be a shorting transformer, or shorting power cables, but to attempt to trouble shoot this with email is a long shot, and depends on your experience expertize and testing equipment.
I wish I could give you a short easy answer, but the hazard and your safety is more important than a microwave.
Will
Nov 30, 2008 | Daewoo KOR-860A Microwave Oven
Microwave wont start
It sounds like a door switch going bad, or a bad connection on your control board. If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info (as well as a text file which helps in diagnosing and repairing door switch problems) at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk If it's a problem with the control panel assembly, we repair those nationwide for $39.95.
Sep 22, 2007 | Whirlpool RMC275PD Microwave Oven
Microwave Ovens Logo
277 people viewed this question
Top Daewoo Microwave Ovens Experts
William Miller
William Miller
Oloyede Monsuru
Are you a Daewoo Microwave Oven Expert? Answer questions, earn points and help others
