Quickbooks 2002 and new laptop with vista
Hi. I haven't tried to install my version but wonder if there are any problems, and what the solution is to install this program on Vista.
Thank you so much.
Susan
  • ralphlewis65 Dec 10, 2008
    Just bought a new DELL w/ Vista. Cannot load my 2002 QB cd. Thinking of sending the computer back to DELL because this would be the last straw with Vista.
    Champion:
  • 237 Answers
The 2002 program is not compatible with Vista. Only a later version like 2008 or 2009 will work on vista.
Posted on Mar 10, 2009
Does QuickBooksPro 2005 version run with windows vista
I think Intuit draws the support line at 3 years Even though you have probably registered your product, if there is any trouble with it and the new computer, you will be on your own. I think you would be putting yourself in unnecessary jeopardy to upgrade as you describe at this time. (Your business depends on your computer and software, to operate) You must also be aware of Vista troubles.
If you are in the market for a new computer, you may opt for the new Windows 7 OS and possibly upgrade your Quickbooks at the same time for maximum benefit.
If you have the Vista computer - you already have the Quickbooks, it costs nothing to give it a try. Presumably, you have a XP computer with Quickbooks on it now ... If the Vista - Quickbooks combo doesn't work out you could upgrade the Vista to Windows 7 ... you have nothing to loose in this senerio.
I hope I have provided a little insight for you to consider.
Thanks for using fixya.com
a
Oct 25, 2009 | Intuit QuickBooks: Pro 2005 for PC
Moving QBB data
cant u download the content of the floppy to ur laptop?
Jun 13, 2008 | Computers & Internet
How can i make quickbooks 2005 run on a vista laptop?
Here is how to load and activate Quickbooks 2005 on Vista...
First of all, if you already have an activated copy of QuickBooks 2005 on another computer open it and go to "help" "my license information" and print this out so you have the details needed for activating your reinstalled copy (you don't need a fresh activation key and you may have trouble getting one as QuickBooks 2005 is no longer supported by Intuit).
On your new Vista computer, insert the QuickBooks CD but cancel any program install windows that pop up. Go to my computer and find setup.exe on the CD, right click and select the option to "run as administrator"
Once installed, navigate to the QuickBooks folder on your hard drive (typically C:\Program Files\Intuit\QuickBooks) right click on QB32.exe and on the compatibility tab select both Disable visual themes" and "run as adminstrator". Now open this file to run QuickBooks and select "file" "Update QuickBooks" to download and install all updates. QuickBooks will not work properly until you have downloaded the updates, closed and reopened the program.
I had problems with activation but I got around this by unplugging my network cable so that I had no internet connection. If you run QuickBooks without an internet connection, when the screen pops up asking you to "activate" click next and the screen to enter your license details will appear. enter your details (printed out from your previous installation) and you are done. You can restore the internet connection and use QuickBooks 2005 normally.
Andrew
Jul 09, 2009 | Intuit QuickBooks: Pro 2005 for PC
I AM TRYING TO INSTALL ON MY LAPTOP WHICH HAS WINDOWS VISTA
Welcome Back linda202, please folow thos step then try to installe your application Windows Vista: Click Start button, and select Control Panel. Under Programs, click Uninstall a Program. Select Microsoft .NET Framework 1.1, and click Uninstall/Change. Click Yes to confirm the removal of Microsoft .NET Framework 1.1. Re-install Microsoft .NET Framework 1.1. If QuickBooks is being installed from the installation CD, please follow steps 1 through 6: Insert the QuickBooks installation CD in the CD-ROM drive. Click the Microsoft Windows Start button and select Run. Enter the CD drive letter (for example D:) and click OK. (For Vista users: click the Windows button and type the CD drive letter in the Start Search field) With the QuickBooks installation folder open, locate and open the ThirdParty folder. Open the DotNET11 folder and double-click dotnetfx.exe.
Jun 11, 2009 | Intuit Quickbooks Premier Manufacturing &...
Installed Quickbooks 2009 non profit edition. Finished the interview and created a company. Try to edit/create new from Quickbooks' suggested chart of account but the account list shows "?" mark on each...
Try running all the updates that are availible for Quickbooks 2009, I know there were quite a few bugs with Vista that the patches were supposed to take care of. Let me know if that helps.
Mar 16, 2009 | Intuit QuickBooks Premier Nonprofit...
I am using Quickbooks 2002 First screen says: This file was not closed in the previous session. Rolling back to last fully recorded transaction." Then I click OK and get the message: "Quickbooks has...
That is an "Old QB Software version" installed in to a "Newer Version of Windows" issue.
QB 2002 most likely works best with Win 98 or 2000.
For your best functioning on your PC, I would ONLY do QuickBooks entries when your PC has just been freshly turned on and no other programs have been running first. Also "Pause" or temporarily "Exit" any background running software like Win Defender and/or any Anti-virus programs. Call QuickBooks and ask them how you could go about Up Grading your QB version to a more Windows compatible version without having to purchase EACH version to "UPDATE" your pre-existing database/files so they are not lost or dysfunctional. They once sent me disks to jump 2 versions and they charged me less than 50 bucks but that was a few years back. Good Luck!
Feb 21, 2009 | Intuit QuickBooks: Pro 2005 for PC
Reinstalling 2002 pro
Sorry to tell you that you will need to upgrade. Quickbooks is only compatable with Vista in 2008 and up. Quckbooks is not doing anything to resolve older issues.
Dec 17, 2008 | Intuit QuickBooks Pro 2002 (260102) for PC
Updating Quickbooks on Vista OS
There are a couple of things going on here.
First, and most important, Qb 2005 was not designed to run on Vista. Vista was barley even in the planning stages when 2005 was programmed. Vista will probably run it, but in a compatability mode ( pretending to be an older version of Windows), but updating the program will be nightmarish at best because the updates are pointing to files that are either 1) no longer used by Windows or 2) the versions and functionality of the files has changed.
My best advice- restore the backup on an XP box, or get a later version of QuickBooks that will run on Vista.
Oct 17, 2008 | Intuit QuickBooks: Pro 2005 for PC
Quickbooks Pro-restoring a back up from a previous version 2005
If is any help - we have just had the same problem.......had version 5 (very old) of QB
changed computer to Vista and would not work so had to buy Pro 208 for Vista . We really had to get in touch with Quickbooks - they send you a free upgrade kit (disc which is Pro 2006 version (not a fuull version but enogh to get the data over) then you load that on your old machine transfer your data to that then copy that again - then load into Pro 2008 - worked fine for us - have come across a hiccup with VAT - but however I guess we are going to have to give in and phone them after the Bank holiday........apart from that everything was fine.
be brave and phone 'em - tech support was helpful.
May 05, 2008 | Intuit QuickBooks Pro 2008: Windows
Computers & Internet Logo
303 people viewed this question
David Payne
David Payne
