Question about Briggs & Stratton Prosumer 20324 Gas Pressure Washer
Pressure washer motor runs, filter clear, lance not blocked but no pressure
  • Anonymous Mar 14, 2014
    leaking from joint in lance
  • Anonymous Mar 19, 2014
    lance broken
    Problem Solver:
  • 6 Answers
The piston in the lance trigger may be stuck . This will cause the flow to be blocked...try another lance trigger mechanism
Posted on Apr 23, 2009
  • 92 Answers
Dear Davidpaulson,
There are many reasons why there is no pressure. The simplest one is try a new lance. The lance you say it is not blocked, but it could have a wider hole with wear and tear.
The second most possible reason is, faulty valves. The suction valves are the most that give low pressure when they are faulty. To check the suction valves, put on the machine in the normal way and as it is working, disconnect the water supply. Than check if air or water is blowing out from the inlet. This is not 100% but you can have a picture of the function of the suction valves.
On the other hand if you do this exercise with the outlet, after removing the gun, you can check for the delivery valves. If you feel suction at the outlet, than the delivery valves can be faulty.
If all is correct, than there must be a fault in the swash plate. This could become loose and so the pistons will stop moving. Also another fault could be broken springs.
Also if the machine is leaking, the high pressure and low pressure seals are damaged. This also lowers pressure.
Other faults are related to the famous spill valve. Also faults could be to internal water leakages, due to corrosion in heads. Finaly I like to add that a faulty electric motor, could also not deliver enough rotation and power, and this also reduces pressure. This could be rewinded or changed for a new one.
Regards,
MG.
Posted on Nov 05, 2008
I switch the pressure washer on motor starts pressure builds up motor stops. OK pull the trigger on the lance the moter starts sounds different water pressure low. Release trigger motor still runs.
It isnt very clear your explanation of the problem but what type washer do you have first? It sounds like you have a bad unloader or need a new variable nozzle tip. Can you explain in more clear detail. Thanks
Feb 16, 2015 | Garden
SPW-2 WONT RUN UNLESS GUN TRIGGER IS HELD ON ?
Check the intake and discharge water lines the filter screens get clogged with calcium etc. Make sure they are clean and clear.
Jan 22, 2015 | Garden
Pacific hydrostar 68333 1500psi pressure washer...motor keeps cutting out, but reset breaker does NOT trip.
dont know the model or if it has a pressure switch inside the box but try and remove your lance and just operate the gun... if it runs ok your last could be blocked
Aug 21, 2013 | Pacific Hydrostar Pacifichydrostar...
K3.86 The motor will not start. It starts for a few secons than stops. Does not products any power Thanks Jim
Dear Sir,
Normally when one closes the gun the machine stops. So you may have a blockage problem that is shutting the machine off. You may try to diusconnect the gun so that you run the machine without load. But..ALWAYS...with water being fed. Never run a power washer without water being fed. Without gun and water fed normally....your machine should continue working. If so you can attach the gun without the lance. If it works, you have a blocked nozzle in the lance. If so try with a very thin needle to clear the nozzel. Do not make the nozzel's hole bigger with cleaning, because then you lose power. Now these machines stop automatically by means of a control valve (Spill Valve). The spill valve when the gun is closed, pressure is created and the spill valve in turn will move to close the electricity by means of a micro switch. Spill valves give a lot of trouble if machine is left with soap in it, or if the machine is stored with pressure in it. NEVER STORE A POWER WASHER WITH PRESSURE IN IT.....always when finished working disconnect electricity, disconnect water and finally press the gun to release pressure. Well as I already said start by putting on machine without load. Then add the gun without lance so that you see that when you close the gun the machine stops....and when you open the gun machine starts again. All this without lance attached. Also in cases like these the Spill Valve sometimes gets jammed in the cutting off electricity position. Spill valves only need to be serviced with good silicon grease....but in doubt change the spill valve. If you open the machine the spill valve is located where you see 2 wires coming out. You should have special tools to remove and service/change the spill valve. Well hope you have a small idea from where to start.
Apr 19, 2011 | Karcher Garden
Will not **** soap or universal cleaner up
Make sure that there is any bloackages in the suction or the end filter is blocked. Also make sure that your lance is set to mix/ low pressure.
Jan 18, 2011 | Karcher FactoryReconditioned 1400 PSI 13...
I have a Kew Hobby 80. The output from the lance is not constant but pulsates.
Could be the input water pressure is not sufficient. There is a pressure valve inside the machine that will cut off the motor if input pressure is too low or non existent.
Try a different source for the water input.
Feb 22, 2010 | Karcher PSI Electric Pressure Washer
Honda 2400 psi before it went out i cold tap the end of the wand on the ground and the pressure would return now when pull the trigger there is no pressure only a fine spray .its a karcher with a honda...
hi,
there is a small ball bearing inside the nozzle on the end of the lance , this can get jammed or missaligned and the nozzle orifice can get blocked , clean this or replace the whole lance with another 200 Bar lance .
hope this helps
Feb 01, 2010 | Honda Karcher G2400HH-R Pressure Washer
No pressure. Have cleaned inflow filter, checked water supply and cleaned and lubed the uploader valve.
if there is water comming out of the back of the pump then your piston seals need replaced , if the lace vibrates then one or more pump valves are blocked ) theres 6 in total /in pairs ) , try running the machine with no hose/lance connected as the lance nozzle often blocks up /malfunctions
hope this helps , if it does please vote
Nov 13, 2009 | Alfred Karcher K2400HH 5 Hp 2.5 Gpm @ 2400...
Lost pressure
try this
dissconect hose and lance , and check for water flow through the machine , if theres none or just a trickle then you may have gunk in your inlet filter ( usually a small plastic gauze insert just where the water feed hose connects )
then start machine , check for high pressure flow ( you will see the difference )
its quite common for the nozzle on the lance to become blocked
if all this seems fine but the lance is vibrating then you have a blockage in one or more of your pump valves .
Nov 11, 2009 | Honda Pressure Washer PSI 3000
Craftsman model 580.752020 electric pressure washer. First time I used it worked for about three minutes then the motor stopped. I cannot get it to start again. Plugged into a 15 amp gfi circuit which did...
turn off water and machine electrics.
remove high pressure hose from front of machine, this may be tight if there is still pressure in the system.
turn on water, when water comes out of machine hose outlet turn on machine. does the machine turn on and water flow increase, if so you probably have a blocked lance jet or trigger.
remove lance extension if fitted and fit hose back to machine, try again. If its ok then this proves you have a blocked lance jet, maybea poke about with some stiff wire will free the obstruction.
If this doesnt bring on the machine you probably have a jammed pressure switch on the pump.
this pressure switch turns on the pump when the trigger is pulled and switches the motor off when the trigger is released.
hope this helps.
Jul 16, 2009 | Electric Garden
Briggs & Stratton Prosumer 20324 Gas Pressure Washer Logo
638 people viewed this question
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
