Toshiba equium A200 15i laptop power problem. The power adaptor jack is getting VERY hot and no charge is reaching the battery! what do i do?
You could buy a new universal power adapter and when you are running it off the mains remove the battery as it will continually charge and burn out.
Posted on Mar 19, 2010
Dc jack of labtop getting vey hot
A common weak spot on most laptops is the DC power jack. If someone trips on the wire while you have the power adaptor plugged into your laptop, chances are that the power jack will get damaged.
On most laptops the DC power jack is soldered directly to the motherboard and there are only three or four small pins holding it in place. Unfortunately that makes the power jack quite weak. Any sideways pulling of the DC power cord while attached to the laptop will usually dislodge at least one of these pins, breaking the solder around it. Modern laptops use quite a lot of power, from about 70W to 120W or even more. The bad electrical connection from the dislodged pin will cause sparks and heating that will eventually burn a hole through the motherboard and can even be a fire hazard.
The usual signs of that are:
  • The battery is not charging properly or stays at half charge despite that you have been using the power adaptor.
  • The screen flickers (the brightness is changing) while the power cord is plugged in. This is caused by the laptop switching between DC power (screen is brighter) and battery power (screen is dimmer).
  • The DC plug gets hot after a few minutes of use and may even smell of burning.
  • There are "scratching" sounds coming from the DC jack.
You need to take the unit apart and check/resolder the DC jack on the system board.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Feb 15, 2011 | Computers & Internet
My toshiba equium A110-233 malfunction
try removing the battery and power adapter for a few minutes then plug in just the power adapter and boot up. then shut all down and put in battery and adapter and see if that helps.
Jan 02, 2010 | Toshiba Computers & Internet
I have got a Toshiba Equium A200 series that won't bootup
if the fan is not running continuously then its the fan ans board problem.because the board is getting hot and fan is not running so the board is getting overheated and the machine is nor working.and if the power light is ON and fan is running but only the screen is black/blank then its the problem of inverterboard.the cost of new board is $25 get it replaced fromn near by laptop repair center. thanks.
Aug 30, 2009 | Computers & Internet
My Laptop Will not sleep on AC Charge
Try using Power Options in the Control Panel. Define exactly how you want laptop to behave with either battery or AC.
May 23, 2009 | Toshiba Satellite A60-S1561 Notebook
Toshiba satellite m35 power issues
Hi !
While power off, disconnect the power adaptor.
Take off battery.
Plug the power adaptor back and try to start !
Is it running?
If yes, than the power adaptor is OK.
Now shut down and disconnect the power adaptor.
Put back your battery and start!
Leave it untill you 'empty' the battery.
Do not start your laptop.
Plug the power adaptor and do not start your laptop yet.
Is there a led idicator showing that the battery is charging ?
Does it shows when the battery is full charged (e.g. red/yellow=charging, to green/off charged)?
If not, leave it for at least 3 hours. After that, start your laptop (adaptor is plugged) and see if you still have an icon saying charging 99%.
If that is the case, then something is wrong with the battery.
Check your warranty, and replace it.
DO NOT OPEN the battery - nothing interesting you will find inside - nothing you can do !
Regards.
Mar 28, 2009 | Toshiba Satellite M35-S456 Notebook
R51 will only start on battery.
Well it sound pretty much like power is not reaching the laptop components so neither the computer turns nor charges the battery using the power adaptor. You mention that you used the power adaptor from other laptop (hopefully same model he he) so it is clear that the fault is not it.
It might be the power "inlet" , I mean the socket where the plug is inserted, it can always get broken.
Another theory is that it might be the power regulation circuit on the mainboard.
In both cases it requieres to send the laptop to be repaired.
A home made "solution" might be to dissassemble your laptop and test the power on the mainboard using a Voltmetter, this requieres some skils so if you decide to try it be cautionous.
Good luck!!
Jan 14, 2009 | IBM ThinkPad R51 Notebook
Battery not charging
most probably you have an IC problem have a licenced repair man to check on it.
Dec 11, 2008 | Toshiba Equium 7100S PC Desktop
Toshiba a100 freezes
check the power adaptor
give a check to your battery also
instead of doing it urself i suggest to show it to a service person
Nov 23, 2008 | Toshiba Satellite A100-S8111TD Notebook
Toshiba Satellite A105-S4064; can't get battery to charge
If you put strain on the jack (e.g. hang power adaptor from it whilst using or charging) then the socket on the mainboard can get hot due to poor contact and melt.
There is no way to fix this except to completely dismantle the laptop and fit a new socket - most likely a repair centre will charge you for a new mainboard.
Try another adaptor to see if that is the problem (broken wire in cord) - otherwise look closely at the socket in the notebook.
Aug 08, 2008 | Toshiba Satellite A105 Notebook
Battery: Fast Discharge, Slow Charge, Charging Lights Flicker, Runs off battery when plugged in
Problems sounds like a damaged power pin from pulling or jerking on the AC cable. I use a Cable Retention Device like the one in this video to keep from hurting the pin.
Dec 29, 2007 | Toshiba Satellite M35X-S149 Notebook
Computers & Internet Logo
111 people viewed this question
David Payne
David Payne
