Question about MicroBoards PF-2 InkJet Printer
Will only print 5 discs and then quit.
When I print a big project, the printer will only print 5 dvd's and then stop. The out of paper lights up on the printer on the left and a red light comes on on the left side of the printer. I have exchanged out cartriges and cleaned it thoroughly. This had been an issue before when we tried to use a different cartrige instead of microboards but that hasn't been a problem since. Does anyone know why this is happening and how to fix it?
  • Dawn Hames Sep 29, 2006
    Microboards PF2 Printer
  • Anonymous Dec 18, 2007
    I have the problem that the printer only does 5 prints then it stops and also it does not always let the CD's down so it says it's out of paper. Help as once I was able to leave it print overnight now I have tto sit with it and watch it like a hawk.I tried moving that board as you suggested to another person but it does not help.
There is a magnetic strip in each cartridge of ink under the label. If you open up the cover of the unit on the left hand side facing the unit, you will see a bracketwith a circuit board on it that the ink carraige slides over. Under the board there is a magnetic reader(like a credit card machine) the ink carraige slides by and it reeads the ink to make sure it's proprietary cartridges. the reader has to be very close to the cartridge or it will send the machine into error mode after 5 discs and not drop any more. You have to physically bend the metal arm down till the readers within a few mm's of the cartridge (like the width of a quarter) this will fix your problem.
Posted on Jan 20, 2007
How do I make a CD label?
There is a user manual on the install disc, pdf-format. To get to the manual, insert the install disc and wait for the small window to appear. At the bottom are some options, one being "View User's Guide". Click that. Or you could access the pdf-file itself manually and copy it to your hard drive: After inserting the install disc, go to "My Computer", right-click on your writer drive, choose "Explore", double-click on the folder named "SE1", and look for a file called "SE1 Guide.pdf". Open it, or copy it and paste somewhere on your computer for future reference. Read Chapter 4 of the user guide - it is titled "CD&DVD LabelMaker". Here follows the chapter, illustrations excluded:
Chapter 4
Introduction
CD&DVD LabelMaker makes designing and printing disc labels
and CD/DVD inserts fast, simple, and fun. Customize labels with
your own photos, text, video stills, and music playlists. Hundreds of
professionally-designed themes are included inside. Supports
label paper templates by Avery®, Memorex®, Neato®, CD
Stomper®, and Direct to CD/DVD Printing with supported printers.
Getting Started
When you first start the program, you're prompted to select the type of
project you want to design and print: Disc Label, Jewel Case Insert,
and DVD Case Insert.
Once you've selected the type of project, you'll be prompted to select
the paper to which you'll be printing. Select your template from the list,
and then click OK. (You can also change your project type by selecting
a new one from the top pull-down.)
Designing your label
You can customize various sections of your label/insert depending
on the selected paper type/template. The main workspace in the
Design Label tab starts by focusing on one section of the label/
insert. For example, if you're using paper that has two disc labels, the
focus will be zoomed onto one of those labels.
Adjusting your view
Notice the two up/down arrows on the left side of the screen. When
applicable, you can click either arrow to shift the focus to the top/
bottom of the page. Click the Paper View button in the lower left
corner to see a small thumbnail of the page. Click the section that
you'd like to edit, and it will appear in the main workspace.
Changing the Background
The right side of the screen lets you change the paper background,
either by applying a color (Use Color) or graphic design (Use
Theme).
To change the background color, select Use Color. A color palette will
appear. Click the color you want. The color will then appear on the
label/insert in the main workspace. The palette is fairly robust. If you
select a new color that doesn't appear on the grid, you can add it to
your My Favorite Colors.
To delete a custom color, select the color, then click the - icon.
To add a design, select Use Theme. A pull-down at the top lets you
select from a variety of categories. Each category offers a variety of
designs. To select a design to apply to your project, simply click it.
Click the button to the right of the pull-down to search for additional
designs online.
Printing your project
A print preview displays your project.
If there are certain sections/components that you'd prefer to exclude
when printing, simply click that object (it will appear dulled in color).
If you change your mind and decide to print the object, simply click the
object again and it will become active for printing.
Print with Mask: This option is only applicable when printing disc
labels. If you notice that your prints aren't aligning properly with your
labels, uncheck this box. Instead of printing over the circular area of the
label only, a square version of each photo will print to cover more area
and fill the disc label.
Select Your Printer: From the Printer pull-down, choose your
printer.
Modify Your Printer Settings: Click the Printer Setup button to
view/modify your printer settings.
Set the Number of Copies: Use the arrow buttons to increase/
decrease the number of copies you'd like to print, or key in the value in
the available box.
(To be continued - ran out of space) From: 11407336
Dec 01, 2010 | Individual SlideShow Expressions
Printer stops after the first paper
while all 3 lights lit up hold go button and different light pattern if big and middle light are on fuser if just big light scanner if anything else post light pattern
Jul 27, 2010 | HP LaserJet 1100 Printer
Red "Paper" light stays on; printer will not print.
Paper light flashing could mean several things on this machine.
There could be a paper jam in the machine. Open the front cover remove the drum and toner and look in the machine. You can also check in between the drum and toner by removing the toner from the drum. Open the back cover and look for a Jam as well.
Try putting a piece of paper in the manual feed tray which is right above the paper tray, sometimes on certain documents the margins are too big and asks to go into the manual feed slot.
Apr 11, 2010 | Brother HL-2040 Laser Printer
Big black vertical line on back of the paper.PIXMA CanoniP4200
Your black ink seems to have spilled a bit at the nozzle. The fact is even if you do nothing it should seize staining the back of the paper after a while, so long as the spill is only temporal. But if you want it over with quickly, you may try printing quite good number of pages till you see that the stops. With every print you will most certainly observe that the stain will reduce. Otherwise if you can reach into the printer with a stick or something, you may try to clean it.
Dec 19, 2009 | Canon PIXMA iP4200 InkJet Photo Printer
Stopped printing, need drum? but no light on
Hi! sandy; Your printer not really heavey duty one, and you give them big jobs, for a sample, you give adult jobs to the baby, it not going run, so your machine need a break! nothing wrong just give them little bit rest.
May 06, 2009 | Brother HL 5250DN Laser Printer
HP C5580 print settings
Hey! I found this in a review site (can't remember)
"If you use Nero 7 Essentials to print CD/DVD labels, make sure you print just the page for the disc, and under print setup make sure you have CD/DVD 120mm under size and CD/DVD tray from source, then under Preferences set your calibration to -0.185" horizontal, -0.182" vertical, and you'll be golden."
I hope it helps!!
Nov 07, 2008 | Office Equipment & Supplies
HP pc 2175 problem
The paper advance is wrong.
In the left side - inside the printer there is a plastic encoder disc that should be glued to a big white gear. If it is free to move, than press it to the geas with your hand (without opening in parts the printer).
I hope this is it.
Mar 05, 2008 | HP PSC 2175 All-In-One InkJet Printer
DVd label
All document printers with disc printing capabilities suffer from disc feed problems. It is an inherent design flaw that results from the machines original design to print documents. Loading discs to be printed must first "go around" the printer's paper feeding mechanism to accept discs. I got tired of using document printers to print labels on discs. I switched to a DiscPainter made by Dymo. It is a dedicated disc printer that was designed as such from the outset and not as an afterthought. It prints every bit as well as any document/disc printer but without the frustrating mis feeds. Although the Canon printer is great for documents its design limitations for disc printing are not easily overcome.
Feb 10, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Problems printing from my Epson RX 595
>disconnect the unit from the computer
>try to make a standalone copy
>if the message still appears on the printer´s LCD screen, hardware issue
>contact vendor for warranty
Jan 03, 2008 | Epson RX595 Photo All-In-One Printer
MicroBoards PF-2 InkJet Printer Logo
233 people viewed this question
Top MicroBoards Office Equipment & Supplies Experts
Starnley Johnwells
Starnley Johnwells
Don  Farrell
Don Farrell
Are you a MicroBoards Office Equipment and Supply Expert? Answer questions, earn points and help others
