Question about Arrow T25 Staple Gun
Arrow T-50 stapler
Jammed and can't figure out how to open?
  • Anonymous Nov 24, 2008
    i can pull out the spring loaded mechanism but I cannot figure out how to release the bottom door hinge to load the staples.
  • sonographer Feb 01, 2009
    how do I load the Arrow T55 stapler?
Take out the screw/nut combo @ the end of the gun where you load the staples. The whole rail that holds the staples will then come out and you can then get the little devils of the nested, jammed, rousted up staples out by sliding them out with a screwdriver. Don't jam the screwdriver into your fingers/hand when doing it.
Posted on Dec 08, 2008
  • Colleen Chittam
    Colleen Chittam Oct 30, 2013
    I held a pair of pliers on the nut while unscrewing the screw, otherwise it was just spinning. Thank you it worked great!!!!
T50 doesn't hinge. Push in and down on the spring mechanism and it should come out. The staples are then loaded by inserting them on the rails that the spring mechanism was one. Hope this helps.
Posted on Nov 30, 2008
Why my arrow fastener ct50 wont staple
Open up the stapler and look for a jammed staple near the opening the staples c0ome out of, had this very same problem, just a few screws to open the gun up and a small screwdriver to pop the staple out.
Jan 11, 2018 | Arrow Tools & Hardware - Others
How do I free up a jammed staple in an Arrow P22 model?
Hi Francis. Remove the staples from the Arrow P22. Place a piece of wood (rod) about a quarter of an inch thick between the arms of the stapler just behind where the stapler is ejected and press down a couple of times until the jammed staple is dislodged. If the plunger is already jammed in the downward position then first pull it up and then push it down again. This procedure has worked for me on a variety of staplers over a period of very many years. Good luck!!
Feb 04, 2015 | Arrow Plier-Type Stapler - P22
An office dummy put regular staples in the Swingline 660HD stapler which is now jammed. I can't figure out how to open the stapler to get access to the staple tray. I can't pull them out with a large...
There's a rectangular opening at the front end of the stapler. You can insert a rod that fits in the opening, and push the staples back out if they're not hopelessly jammed in-place.
Feb 04, 2011 | Office Equipment & Supplies
How do I load JT21 staples into a Arrow JT27 Stapler gun?
I was having the problems everyone listed... with the staples loading & firing... I guess the instructions are lousy .. should be ON THE PACKAGE to make it clear.. but.. on the stapler itself on the bottom.. it explains how to correctly load.. you don't put the staples on the piece that slides out.. you slide it out, load the staples in the open tunnel ..then slide the piece back.. that piece is the spring loader... since i finally figured it out ( by coincidence that I turned it over & noticed some faint words printed) - it works PERFECT every time! great little stapler... please fix your directions... seems to be a common misunderstanding!!!
Nov 07, 2010 | Arrow T50P ARROW STAPLE GUN
Staples are stuck inside the stapler and will not come out
Typically you do not open these up.
Makes it difficult to remove stuck or wrong staples.
I have had good luck removing the staple ram rod and rapping firmly on the **** of the stapler against a wooden table. The idea is jolting the stuck staples into reverse out the way they went in. Tedious process but usually works. Removing the jammed staples in the nose at the striker plate requires using needle nose pliers and a sharp awl or small screw driver used on very small screws.
My T50 Arrow stapler is over 20 years old.
Still works great. Sometimes I slide in the wrong size staples by mistake. The process above usually works.
May 26, 2010 | Arrow T50P ARROW STAPLE GUN
REATTACH PARTS
Should slifde right together from the back. If you will go to the company web site, there is an exploded picture there for your convenience.
I hope this helps
a
Oct 02, 2009 | Arrow Fastener T27 Light Duty Household...
My jt 21m stapler is jammed and i cant get it to open
At the end of the stapler opposite where the staplers are driven out is a release. Push it in and turn it should come out with a long spring.
Jun 26, 2009 | Arrow Fastener Co. Lt Duty Staple Gun -...
There's a jammed staple but I can't figure out how to open it to fix the problem and refill it
This is how it works on the Arrow staple gun. On the back bottom, opposite end from where the staples come out, there is a little plate. Push it in and it unhooks and pops out. attached to a rod. When you refill with staples, just push them in, then put the rod back in and the spring applies the pressure.
May 31, 2009 | Staples Swingline® 36115 Staple Guns Tools...
Hi can't seem to reload stapler
All you do is open the end peice and slide the staples in on the two rails, point down. You should be able to see in the end to make sure nothing is blocking the rail with a flashlight. You probably have the wrong size staples. You can only use # 214, 215, 276.
Nov 26, 2008 | Arrow T50P ARROW STAPLE GUN
Stapler works intermittantly
If not the power source or cord, the next activation point would be the trigger. Does the stapler make any sort of noise when the trigger is depressed? What type and model stapler is it?
Nov 02, 2008 | Arrow No.ETF50PBN Extra Heavy Duty...
Arrow T25 Staple Gun Logo
4,043 people viewed this question
Top Arrow Tools & Hardware - Others Experts
JOHN LAPIER
Mike
Are you an Arrow Tool and Hardware - Other Expert? Answer questions, earn points and help others
