Question about Toshiba 53AX61 53" Rear Projection Television
Sound but no picture
I have sound but no picture...the RGB tubes work but no picture. Also I noticed the screen getting darker before the picture went out.
I worked as an electronic tech for Toshiba for 17 years. You could have several issues, but most likely you have a problem that will need to be troubleshot down to the component level. A really good idea is to "shock-test" your tv - meaning to very gently bump or tap on the back of your tv or if you electronically oriented to take the back off the tv and use a "non-conductive" probe to tap on different parts of the circuit board. If the picture comes back when doing this then you have a simple solder joint that needs to have more solder applied.
Posted on Jan 07, 2009
Toshiba big screen tv black screen with sound
It is telling you that you need a new backlamp or that the power supply that feeds it is out. It could be bad Chinese capacitors or you may actually need a back lamp. The hint was when it was working did the side edges have a darker brightness to them? If yest the lamp is needed. If no then the capacitors in the backlamp supply may have decayed.
Oct 01, 2012 | Toshiba Televison & Video
TV MADE A LOUD "POP" NOSIE AND THEN SCREEN WENT
Hell k_sopata
If the display isn't working and according to the conditions you described yes it is the picture tube. You could contact Samsung and get a replacement for it.
Jan 10, 2011 | Samsung PCJ522R 52" Rear Projection...
It started 3 days ago the picture started getting darker and darker everyday then last night after turning the tv off which was off for several hours I turned it back on and a few min later there was a...
REPLACE THE LAMP IT IS LOCATED IN THE BACK OF THE TV THERE ARE INSTRUCTIONS IN THE OWNERS MANUAL FOR REPLACEMENT IT IS CONSIDERED CUSTOMER REPLACEABLE ITEM.
PART NUMBER 915B403001 Lamp (180W)
Dec 16, 2010 | Mitsubishi WD-65736 Television
Sound but no picture is it the picture tube or just another problem
most likely will not be the tubes mate, if the tubes go then you just get a big mix of red green and blue colours in the screen - sound but no picture is more likely to be the starter unit on the flat screen.
flat screens have a starter unit - mine went on a samsung but under warrenty
Sep 08, 2009 | Sony KP-53HS20 TV
No picture,but sound ok
check your ribbon connections coming from power supply board there is 2 of them it will be the second one,theses ribbions connect to signal board.Sometimes causing set not to come on.
May 11, 2008 | RCA D52W19 52" Rear Projection Television
Tune up for Hitachi 60FX32B
Remove rear cardboard cover....can you see tops of red / green /
blue tubes ? Clean lens' with soft , dry cloth......Do you smoke ?
If not , replace back. Picture should now be clearer but not
necessarily brighter.......Next, remove front speaker grill and find
the RGB focus / screen adjust block....turn RGB screen controls
SLIGHTLY clockwise to achieve more brightness....not too much
or you will have retrace lines in background of picture.......Let me know after these steps are done........T.
Mar 02, 2008 | Hitachi 60FX32B 60" Rear Projection...
Toshiba 65Hx81 model rear projection
The picture tubes dim over time. It's possible they need to be replaced and/or cleaned. There are 3 of them (one blue, one red, and one green).
Jan 28, 2008 | Toshiba 65HX81 65" Rear Projection...
Picture is getting darker and darker
if the tv has never been service before you could have dust on the 3 tubes,this will decrease the brightness to the screen. try taking the front or back off & see if you can see the top of the picture tubes. remember to unplug the tv & to clean spray the cleaner on the colth , then clean the tup of the tube. never spary on the tube itself. hope this works for you.
Oct 22, 2006 | Panasonic PT-51HX40 51" Rear Projection...
Toshiba 53AX61 53" Rear Projection Television Logo
178 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
