Question about Kenmore Elite HE4 Electric Dryer
Kenmore elite quiet pac 9
Inside light comes on but nothing comes on the control panel when door is open or closed
  • vandyn Nov 10, 2008
    Light is coming inside but nothing comes on the control panel.how to resolve this problem.
  • akota Nov 21, 2008
    On a lightly used dryer (towels & sheets twice weekley) the control panel has no lights or function , however the interior light works when the door is opened
    Sergeant:
    Champion:
  • 324 Answers
Unplug dryer, then take the top off and check your connections to door switch.i believe this model has a broke belt switch.open the bottom with the machine unplugged and reach inside and see if the belt is broke.if it is then replace the belt.
Posted on Nov 05, 2008
The kenmore elite smart wash quiet pak 9 I opened the door and threw something else in and now a light is on thar says controls locked and it wont do anything
There should be a button on the control panel that says "open door" you need to push that button and wait for the washer to shut off before you open the door. Try pushing that button to see if that resets. My guess is that you broke the safety latch when you opened the door and it will need repair.
Mar 10, 2014 | Kenmore Washing Machines
My Kenmore Elite Quiet Pac 4 allows water to slowly come in after a cycle has finished and everything says it is off. What is the problem?
There is a valve inside your washer that needs to be replaced. Call sears and have them replace it. You'll need to give them the model and serial #'s.
Jan 11, 2012 | Kenmore Elite 45986 Front Load Washer
My Kenmore elite HE4 quiet pak 9 electric dryer is working, but it emits a constant series of 3 beeps, and sometimes shuts off before the cycle is complete. I have to unplug it to stop the beeping....
You are getting moisture in the control panel buttons. After a while the panel will not function at all. The light in the dryer tub will still come on when the door is open. When you unplug your machine and it sets for awhile you are allowing the moisture to dry and the machine can reset. Some people use a hair dryer to dry out the control panel for a temporary fix. Eventually, you will have to get it replaced once it stops resetting for you.
Oct 25, 2010 | Kenmore Elite HE4 Electric Dryer
Kenmore Elite Smartheat Quiet Pak 9 won't start. Light turns on and off inside drum when door opens/closes, but no lights come on on the outside display.
My Kenmore Elite dryer keeps beeping..just going through the end of cycle alarm-high,low,off...anyone have any suggestions?
May 30, 2010 | Kenmore Elite HE4 Electric Dryer
I have a Kenmore Elite Dryer, Model # 11061066000 and nothing happens when you touch the buttons on the control panel. Light inside works. Any solutions? thanks.
there is a thermal fuse mounted on blwer housing w/2 blue wires coming to it,thats a popular fix...also check that the door is activating the door switch when closed....its usually one of the 2
Mar 10, 2010 | Dryers
My kenmore elite he3 electric dryer control panel is not working. When the door is open the light inside is on, but with the door open or closed the control panel above does not turn on or light in any...
The control board is bad. You will have to replace it. You might aslo theck the fuse, sometimes they look a little different than you are used to. Refer to your owners manual and wiring diagram to find it. You can also find more info on the Whirlpool website. Whirlpool makes Kenmore.
Apr 10, 2009 | Kenmore Elite HE3 Steam 8674 Dryer
Kenmore Elite quiet pack washer quit. Please help!
The F70 and F71 error codes on this model of washer indicates a communication problem between the user interface control board and the central control unit (main control board). These error codes can sometimes be caused by a power surge or glitch through the electrical lines. Try unplugging the washer to completely disconnect electrical power. Wait 1 minute and then plug the washer back in to the see if the fault code clears. If it does, then the washer may work normally.
If the code reappears, then you could have a wire harness connection problem, a failed user interface control board or a failed central control unit. I recommend calling a service technician to properly diagnose and repair this type of problem so that the correct component can be replaced.
Be sure your unit is plugged into a 3 prong grounded outlet as well.
F71 is a "heatbeat failure" which means that your front interface control board is shorted and will need to be replaced. it's actually fairly easy to replace and can definitely be done by yourself. To access the part, just pull the unit forward and remove the 3 screws coming in from the back of the top panel. Remove the top panel by pulling it back, up, and off. Then remove all the screws going into the top of the control panel. Remove the dispenser drawer and remove the screws coming in through the dispenser. Remove the screws coming from the inside of the dryer going forward into the control panel, then remove the control panel (it's just clipped in on the bottom. After that you can disconnect the wire harnesses to the front interface control board and replace that part.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Feb 18, 2009 | Kenmore Elite HE4 Electric Dryer
Kenmore Elite HE4t Washer Control lock lit, door locked
121 MINUTES USUALLY DRAIN CYCLE PLZ REMOVE 3 BOTTOM PANEL SCREWS 7 MM SCREWS, TO OPEN DOOR SLIDE RIGHT HAND TOWARDS DOOR LOCK ,THERE WILL BE A SMALL LEVER TOO PULL DOWN ,NOW ITS OPEN,,, SINCE U HAVE BOTTOM PANEL OFF PUMP IS RIGHT IN FRONT REMOVE PLASTIC HOUSING CLOCKWISE ,,,REMEMEBER HOLD 3 GALLONS OF WATER STILL ,HAVE BUCKET READY ,NOW CLEAN OUT PUMP AND DEBRIS ,, CLOSE IT UP SHOULD BE FINE NO MORE PROBLEMS ,,,,,
Jan 01, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite problem
1. Remove the lower panel under the door by loosening the three screws under the bottom edge on the front of the washer. HINT: If you prop up the front feet of the washer with some small blocks of wood, this will make access to the screws much easier.
2. With the screws removed, the lower panel should drop down then come off. If the panel sticks, a light tap on either side will knock it loose.
3. Reach your hand up inside the washer behind the front casing on the right-hand side. This is where the door latch assembly is located.
4. At the bottom of the door latch assembly is a small pull tab. This is the manual release for the door. Pull the tab straight down and the door will come open.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.%^@#
Apr 28, 2007 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite HE4 Electric Dryer Logo
178 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
