FixYa.com
Tags:
Mcintosh MC300 Amplifier
McIntosh amplifyer problem
By Chandler - usenet poster
After a move, I have been reconstructing my audio system, which has as
its core a McIntosh preamp/AM-FM tuner and the MC300 power amplifier.
Having gotten some new speaker cable, I attempted to reinstall this
item, but one of the screws on the back fell off and *will not* go back
in. I cannot now attach the cables and cannot use this instrument. Any
help appreciated! --E.A.C.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Aug 07, 2005
Not Rated (0)
Horner
Horner - usenet poster
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
If it is a screw that threads into one of those terminal strips for
connecting speakers?
They do on occasion get worn and the screw doesn't thread in properly any
more.
It may be possible to carefully rethread it for slightly bigger screw! Or
even try (very carefully) a slightly bigger screw and make it cut its own
new thread. But be careful; too much force, danger of cracking the terminal
strip insulator!
If not take the amp. apart. Install a new terminal strip and
reconnect/resolder etc. the wires to it 'exactly' as it is now.
Make sure none of the wires is touching anything else or the metal frame of
the amp.
If the terminal strip is riveted to the chassis it will be necessary, to
very carefully (and watch out for metal drillings falling into the amp.)  to
drill out the rivets and probably use screws or rivets, to reinstall a new
terminal strip.
If you don't have the tools and skills to do this get a competent technical
person to do it.
Not having seen the situation; possibly estimate a couple of hours; after
finding the right parts, to repair and test it (provided it is working
before hand!).
But as with all things technical/electronic you never know what you may find
inside of the unit!
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
Not Rated (0)
pandamama
pandamama - usenet poster
Rating: 0%, 0 votes
Thanks for that advisory! I have taken it to a McIntosh dealer for
"adjustment". FWIW, a message from McIntosh notes that there had been a
"tool box" or something that seems to have come with the amplifyer for
setting up "banana" plugs for the attachments. Meanwhile, I am using a
MC202 amp that does have the "banana" plugs. --E.A.C.
Can you Help with these Amplifiers and Preamps problems?
Connection of Amp to Equaliser
I need to connect a Pioneer... Answer This...
arcam alpha 7 amplifier goes...
Vry recently when playing both... Answer This...
JBL SR4732 amps????
Hello Tech48, I just recently... Answer This...
BEHRINGER 602a MIXER..HOW CAN I...
a crate guitar vamp head with... Answer This...
Can't find a univesal code
I want to set up my reciever to... Answer This...
Repair Service
Find Amplifier and Pre. Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
