Question about Microsoft Xbox 360 Console
My 360 turns on for a mili second then no power fan stops
I have xclamped my 360, and there is no power going to the 360 when I switch it on. There is for a mili second then the fan stops. The cpu and other bits are not heating up like they should. The power brick light turns yellow (green to start for a mili second). There is just 3 red lights flasing. I have tried a working power pack but that does the same. I can not send back to microsoft as warrenty void. Can anyone help.
  • 1 more comment
  • Derby10 Nov 03, 2008
    I have now got it to go to 2 red lights. I highered one of the cpus heat sink. but when the 2 red lights come on it cuts out. What is going on?
    How long do you have to bake the falcon board after the xclamp fix and heatgun? The fan is now working fine, but it doesn't seem to go to the 2rl which means ready. Been like 20 mins but nothing. Am I doing something wrong?
  • Derby10 Nov 04, 2008
    I can not take to store. Warrenty is void. I just want to know if I can fix it? It just won't overheat after xclamping.
From what ive been told during my searches to fix my 360 it sounds like a blown mosfet. go here: http://forums.xbox-scene.com/
Posted on Nov 07, 2008
Ok ive done the xclamp mod on my 360 successfully. i ha the same prob ao what i did was try to loosin or tighten each bolt one at a time on the heat sinks of course. thats what i did and it finally worked...hope it helps
Posted on Nov 05, 2008
    Problem Solver:
  • 17 Answers
Then i would take it back in to the store and tell them more whats going on
Posted on Nov 04, 2008
Xbox xclamp mod
need a new power block or your board might be fryed :S
Jan 07, 2012 | Microsoft Xbox 360 Console
2 and 3 red rings
The 2 red rings error is an overheat problem. Something you did when you attempted the previous repair has prevented the 360 from cooling properly. I suggest having a professional examine your machine.
Jan 21, 2010 | Microsoft Xbox 360™ Pro White Console
Keep getting same thing over and over??
u r going 2 need 2 open it up take the xclamps off so u can get at the CPU and the GPU chips , u will need silicon gel 4 both chips , 1 red light is just the same as 3 red lights its due 2 over heating of both these chips, i had the same problom and after i put the gel on the chips it works fine now, go 2 u tube 4 a video on how 2 take the xclamps off.
Jan 13, 2010 | Microsoft Xbox 360 Console
How do you fix xbox 360 e 74 any assistants would be a lot of help
There are two ways to fix this error.
First Take it to a shop that is able to re-flow the G.P.U.
with out damaging the P.C. board. And then securely
clamp the heat sink down . Im not sure if Microsoft does this.
Second Take the unit apart , remove the G.P.U.s Xclamp
replace with nylon washers and 4 8-32-3/8 long screws
lightly and evenly torque all 4 screws. Place half the
fan over the large heat sink and turn the unit on.
affter 5 min the fan should be at full speed and in
anouther 3-5 min you should get two reds . Unplug
and reassemble . The unit should be working.
If you have any questions just comment and ill respond.
Rob
Oct 18, 2009 | Microsoft Xbox 360 Console
Fan spins for 2 seconds after rrod fix
u can try fixing by mircosoft or try the towel trick on youtube
Sep 07, 2009 | Microsoft Xbox 360 Console
Three red lights and no power
Did you let it heat up untill you get the 2 red rings. If not unplug your fan; turn it on and wait untill you get lights 1 and 3 flashing. turn it off and wait a couple of min. then plug your fan in and add the wind tunnel. then turn it back on. If it still doesn't work you did the X-clamp fix wrong.
Jun 28, 2009 | Microsoft Xbox 360 Console
RED Ring of death xclamp fixed but..
Do you have the fan in? If you do, take it out or put 2 screwdrivers through the back holes to stop the fans from spinning. IF you have the fans out and its still not overheating, just leave it on for a while until it does. It will overheat eventually.
Nov 22, 2008 | Microsoft Xbox 360 Console
Did xclamp repair and now wont come on, stays on stand by
call Microsoft tech support. If they cant help you fix it then they will have you ship it in to them. If its under warranty they'll fix it for free.
Jul 05, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
1,080 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
