Question about Delphi Roady2 SA10085 XM Radio Receiver with Car Kit
Match frequencies XM to Tuner
Don't have enough output jacks on my system, and want to connect outdoor speakers and the roady 2. Want to connect wirelessly, and can't find the instruction manual to find out where the fm frequency selection to accomplish wireless connection.
You should be able to go to the menu on your unit as long as there is not a plug in the audio out socket, and it should give you the FM Frequency option. If you remove the plug from the audio out, you will want to power the unit off and back on to get the FM option to appear when you push the menu button.
Posted on Dec 11, 2008
Xm roadie xt. Can't get the fm frequency option to appear
IF you have an audio jack plugged-in, it won't turn the FM transmitter on, so UNPLUG the audio jack, then go to the MENU and you will see the FM frequencies to select. Okay? Let me know if any more questions.
May 25, 2014 | Audio Players & Recorders
Roady XT works fine on Boom Box/Will not transmit to car antenna/will not show "set frequency" on menu,,
Cannot have anything plugged into the audio output/audio jack, or it shuts off the FM Frequency modulator.
Sep 05, 2010 | Delphi Roady XT XM Radio Receiver
What do I need to install my roady to a 12volt dc system?
Just a Delphi 12VDC cigarette lighter adapter plug that will plug into this unit. You will also need an XM mini car antenna plugged into it. This has a nice FM transmtter, so you can use that, or use the audio output plug to go to your car AUX input jack or use a cassette adapter. Okay? More questions, just ask.
Apr 18, 2010 | Delphi Roady SA10035 XM Radio Receiver
Trying to install Roady 2
If the Roady2 has a fm modulator built in, you can go to the menu and set the fm frequency. If it doesn't, you could use a fm transmitter that they have for mp3 players to listen to in the car
Apr 13, 2009 | Delphi Roady2 SA10085 XM Radio Receiver...
Yamaha rx v1800 receiever will only play tuner on zone 2 speakers
Solution on page 111 of the owner's manual:
"Connect the source component to the analog audio input jacks of this unit to play back the source in Zone 2 or Zone 3.
This unit does not output the audio signals input at the DIGITAL INPUT and HDMI jacks to the ZONE OUT jacks."
Basically you cannot use an HDMI input if you want to play in Zone 2 or 3. A simple solution is to add an extra audio cable from your PS3 audio output jack to an analog audio input jack on the receiver.
Feb 22, 2009 | Yamaha RX-V1800
Connection
If it has a radio get a fm transmitter you just plug it into the roady headphone jack, You can find them about every where they make them for iPods but they work work these way too. there about 20 to 25 dollars on the net
Feb 02, 2009 | Delphi Roady XT XM Radio Receiver
Brookstone Wireless Outdoor Speaker with Bose 123 System Problem
AUX usually refers to an INPUT, such as a CD player, etc. No signal comes out of a standard AUX jack, unless it specifically says "Aux speaker output". Instead, look for another speaker output jack, such as remote speaker, B speakers, etc. You may only have one set of speaker output jacks, in which case you would need to connect your wireless speaker to the speaker output jacks along with your main speakers, or buy a little speaker selector switch box to switch between main and wireless speakers. There's usually no harm in connecting more than one speaker set to the same outputs, though it is technically not recommended. In the real world, just don't crank it too loud and you'll be fine. The wireless speaker MIGHT run off of a standard line output also, if the wireless speaker has its own power amplifier.
Dec 15, 2008 | RCA WSP150 Main / Stereo Speaker
Zone 2 Can't Handle a Digital Input ? ! ? ! ?
it is very frustrating... I just have discovered today. I can't solve this because my Itunes mac is only digital audio output, I can share its sound to Zone 2..
Apr 16, 2008 | Audio Players & Recorders
Great signal, so sound
My XM Boombox is also white and it is a Belkin. The folks at Delphi told me the receiver in the boombox is screwed up which over time also screws up the Delphi receiver. Belkin is sending me a new boombox and Delphi is sending me a new Roady XT.
Mar 01, 2008 | Delphi Roady XT XM Radio Receiver
Set frequancy
Mount your Roady 2 in your Truck .Make sure the power is on & the antenna is connected. The middle connection should be open. Push the menu button, you should see FM Frequency at the top.Push the scroll button(Top Right) and you should see FM station numbers. Scroll though the stations and pick a frequency that isnt being used in your area. Push the scroll button in to set the station. The display will show that number set 88.3 set for example. Set the FM Tuner in your truck to the same station. You should be go to go. Good Luck
Dec 18, 2007 | Delphi Roady2 SA10085 XM Radio Receiver...
Delphi Roady2 SA10085 XM Radio Receiver with Car Kit Logo
185 people viewed this question
Top Delphi Audio Players & Recorders Experts
John
John
Darrell
xxxxxx xxx
Are you a Delphi Audio Player and Recorder Expert? Answer questions, earn points and help others
