No a noise filter is a different kettle of fish. That stops electrical interference noise from affecting your television, radios and electrical devices.
The most likely source of the hum is the start capacitor on the motor, or the motor itself.
Humming or Grinding
If your Samsung dishwasher makes noise when starting that sounds like a low hum, it's part of normal function. The motor makes this sound as it operates throughout the wash cycle. However, a dishwasher making loud humming noise or grinding sounds could mean that debris is caught in the drain pump.
Have you replaced the clutch or spin tube? There is a brake actuator that comes with the clutch kit and if this is broken it can make a very loud grinding or clacking sound.
Noisy machine is due to improper or fault in the drive of the motor and agitator assembly . You might have to remove this unit and overhaul , maybe the bearings or hub need a change.
Also try to use some lubricating oil on the moving shaft so as to lubricate and reduce the noise.
The filter clogging is the fiber that comes from the clothes while it is tumbled and in a period of time will accumulate. you need to clean them occasionally.
the flooding is due to clogging of filter of the drain and resulting in leaks . Check the drain pump/valve, check the hose fittings and make sure these are tight. check the inlet pipelines for leak and the washer door gaskets.
Grinding noises are most often the result of a failing water pump. The noise can increase during the spin\drain cycle due to the added load on the pump. Although less likely it could also be the drive belt rubbing on something or a pulley bearing failing. If you are able to locate and remove the drive belt, you should be able to turn the water pump pulley by hand. If the pump does not turn smoothly it is bad.
