Question about Microwave Ovens
Older tappan microwave (10 yrs?) won't turn off!
It did allow me to punch in time and power, then wouldn't start. Opened, closed it and then it just turned on and wouldn't turn off. (well, fan and light were on, I assumed microwaves were happening)
The only fix we could do was unplug it. So is this worth repairing the main circuit board, or better to just get a new one? I was told the part would probably be $150....  I would prefer to repair the old than get a new, but would love to hear a "pro"  on this.
Thx. bkmitch5@comcast.net
  • Microwave Ovens Master
  • 9,098 Answers
This is usually caused by either a bad door switch, a loose door switch mount (which are pretty simple problems to fix) or occasionally a problem on the control panel.
Door switch or mount trouble can be caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa:.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
There may also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
If you only need a switch, you can order a universal type from us for $5 postpaid.
If you think the problem is on the control panel, we repair these nationwide by mail for $39.95 postpaid in most cases.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Posted on Nov 09, 2008
My Tappan TMV 151FS (2008) microwave is not working.
You likely have a door switch or mount. See a handy help file on door switches here.
The service manual for the TMV151 model series is here, and the parts manual is here.
You can order Tappan parts from the Pros here.
Nov 30, 2012 | Tappan TMT104E1 Microwave Oven
Kenmore 401.80083700 won't turn off
It is one of two things, a defective door switch, or the keypad control board has failed.
Apr 18, 2012 | Kenmore 68361 Microwave Oven
On the Emerson MW 8992 SB microwave oven how does one change power settings,e.g., from 100% to 50%?
Emerson MW8991SB 0.9Cu.Ft. 900 Watt Touch-Control Microwave Oven, Stainless Steel has the same face as your microwave. I own one of them Look at the bottom three uo to the left it says (POWER) push the Power button it starts at 10 and goes to 1. 10 being the highest and 5 being half power and 1 being the least. then select the amount of time you will cook by punching in the numbers.
Jan 17, 2011 | Emerson Microwave Ovens
I have a Tappan Model 56-9338-10/04 Microwave. The microwave stays on when you open the door! Can someone help?
  • Don't operate an oven if the door does not close firmly or is bent, warped, or otherwise damaged.
  • Never operate an oven if you have reason to believe it will continue to operate with the door open.
  • As an added safety precaution, don't stand directly against an oven (and don't allow children to do this) for long periods of time while it is operating.
Nov 28, 2009 | Microwave Ovens
Microwave will not heat food. punch in heating time, press start and nothing happens
HI. your control board has failed. you will need to replace the control board asap if possible.
May 30, 2009 | Panasonic Microwave Ovens
Turns on when door opened
this is dangerous; replace or adjust your door switches the interlock switches should only allow you to turn on the microwave when the door is closed
May 29, 2009 | Jenn-Air JMC8100 Microwave Oven
Microwave is not working
One of the door switches needs to be replace.
Oct 30, 2008 | GE JVM1440 Microwave Oven
My Microwave flickers and buzzes
This problem normaly happens when the door is not closed properly for a long time and flashing and buzzing starts to give user a indication for same. Allthough it is not risky as microwave oven has safty door switches wich does not allow oven to operate while door is open. Take care and close the door properly before you leave kitchen..
Aug 02, 2007 | Kenmore 66469 / 66462 / 66464 Microwave...
Microwave Ovens Logo
89 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
