Question about Zebra 105Se Thermal Printer
Zebra 105SE configuration settings
Is there a way to set the "Left Position"? The printed characters are shifted to the very left edge of the label and sometimes get cutoff. I don't know of any front panel settings to change this parameter.
RB Jarrett
Please scroll the printer parameter untill you fine LEFT POSITION parameter and adjust as you needed.
Posted on Nov 25, 2008
Hi, I have a Zebra 140xi2 printer. When I print, everything is shifted to the left. I checked the PRINT WIDTH (set at 127 4/8 MM), and the LEFT POSITION (set at 0000) in the printer configuration. Is there...
turn off printer and press "pause" button + "power on" at same time, keep pressing "pause" button for 5 secs. it will star printing a
'pouse test" ike a barrcode. After 3-4 labels, just paused the job otherwise it will never stop printing untill u swicth off again.
if printing halp printer, tried to reser printer to factory default and try again. if still printing half, the printhard its faulty.
Mar 17, 2014 | Zebra Office Equipment & Supplies
Zebra 105se printer is printing out of the label on the wright side
re donload software for it maby firmware update cheak settings in software ok
Feb 02, 2008 | Zebra Z6M Plus Thermal Label Printer
I am using a Zebra 105SE printer. When I print labels, I can not get the text to start at the top of the label. No matter what I do, the text starts half way down the label.
Label position may be off. Power on while pressing the cancel key for 10 seconds. This should print a configuration label. Use large label for this. Check the parameters, specifically top position and tear off position. The default is 0. You might also check the main drive belt for stretch or missing teeth. You need a user manual for that printer because there is no lcd panel. It is not user friendly without manual.
Nov 11, 2010 | Zebra 105Se Thermal Printer
My Zebra 105SE is printing fine on the left
I think the 105 has an adjustment on the printhead. There are left and right hand adjusters just above the printhead. It sounds as if the right hand one does not have enough pressure on it, try increasing the RH one and see the effect on the print.
Jan 06, 2010 | Zebra 105Se Thermal Printer
More specifics on adjusting the Left Position on Zebra 105Se.
I have a Zebra 140X and we would hit setup then hit the left or right button until you get to Left Position option. on mine it looks like its the 28th option going right.
Let me know if that helps.
Sep 22, 2009 | Zebra 105Se Thermal Printer
Zebra 105SE label material will not retract in prep for next Lab
The platen is the driving force for the label. the main drive belt runs all functions in the printer.
Is the back feed turn on in the printer? Check the setup.
Also if the print driver is set(doc/properties settings on print depending on software) to use pirnter settings, and the back feed is turned off in the printer, it will not backfeed.
Feb 24, 2009 | Zebra 105Se Thermal Printer
Zebra 105 se label length is wrong
But physically measuring the label 1252? You can also disable the calibration options and then use the command ^XA^LL1252^XZ.
Jan 27, 2009 | Zebra 105Se Thermal Printer
ZEBRA 105SE
The label sensor is not detecting the gap between the labels.
Make sure the labels are loaded all the way to the left (as viewed fron the front) and make sure the label guide (near the back of the printer) is set to keep the labels from wandering away fromt he sensor.
There is a pair of infrared emiter and detector located above and below the label path. As label pass between, these measure the leading and trailing edges of each label.
If you haven't already done so, calibrate the printer, by using the "Online", "Calibrate", "Online" buttons. If the "Feed" button doesn't feed just one label, you'll need to adjust the label gap sensors. This can be a bit trick if your labels are very narrow.
There should be a small pcb on a shaft under the label path. Note its current location, then slide it left or right to get a better signal, and try the feed button again. On my Zebras, the sensor is not in the middle of the PCB. Look for a small metal "can" on the PCB and center that.
The upper sensor is more difficult to adjust, but if you manage to spot a very small PCB above the labels, it will be easier to line these up.
If the labels are extemely
Sep 04, 2008 | Zebra 105Se Thermal Printer
No response from 105Se
if the data light comes on and nothing prints chances are that the serial settings are set improperly. all of my printers are 25 pin serial, not parallel. i don't have one in front of me but i believe the settings are 19200, 8, 1, none. hope this helps.
Mar 19, 2008 | Zebra 105Se Thermal Printer
How to access the settings to change the top of form or tear off position
Press the front panel MODEswitch until the POSITION LED is on, then press the UP or DOWN arrow until the label perf is positioned at the tear bar's edge. Press the MODE switch again until the printer reboots.
Feb 03, 2008 | Zebra 105Se Thermal Printer
Zebra 105Se Thermal Printer Logo
1,053 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
