WATCHING TV IS FINE , THEN SCREEN WILL GO BLACK FOR A SECOND AND THEN RETURNS
I unpluggedthe digital box !!
Posted on Nov 04, 2008
Tv doesn't turn on
power pack probably has blown capacitors on it. need replacement of those and the tv should be fine.
Apr 03, 2009 | Akai LCT2715 27 in. LCD Television
Screen goes black randomly during use and tv shuts off
check your capacitors cp150 114 120 if any of them is puffed up on top it is bad replace all 3 cap. 2200uf 1`6v and two 220uf 35v. also resolder FBT pinns.
Feb 02, 2009 | RCA HD52W59 HDTV Projection Television
Big black box in the middle of the screen
The black box is there because your closed captioning is on and set to text mode. Some channels send the signal even when there is no actual text to display. You can get rid of it by either turning off closed captioning or changing it to CC1 or CC2 mode instead of text. If you can't find those settings, then restore factory settings as directed in your user manual.
Jun 04, 2008 | JVC AV-32230 32" TV
Screen goes black, hit the input button and it changes....then black again
Thanks 42PULGADAS to party and its cost of shipment to Bogota Colombia could please provide to me to the cost in dollars of the screen of TV MAXEMT MODEL P4202YDOS thanks Attention(or attn). CARLOS EMILIO MONTOYA
EMAIL
ecografo@gmail.com
Mar 30, 2008 | Maxent MX-27X1 27 in. HD-Ready LCD...
Hitachi 51F510
The loud "pop" sounds like high voltage arcing coming from one of the CRT's.....you may have to pull each CRT out and put silicon sealant on the anode connectors to prevent the arcing.(one of the CRT's may be arcing internally also and the only cure is to replace that CRT) If you let the arcing continue,it will short out the horizontal output transistor sooner or later.......
Mar 28, 2008 | Hitachi 51F510 51" Rear Projection...
Hitachi 51F510
Same problem but mine goes black for long periods. Menu prompts still available and volume "meter" on screen is still visible. Have rerouted cable, changed outlets, all to no avail.
Blue screen for a second after power on and then black screen again
Check where your plug go's in to your powersupply if it is well fitted. ////sometimes it dosnt make well connection then you will struggle to get it on.
Oct 13, 2007 | Westinghouse LTV-27w6 27 in. LCD HDTV
Televison & Video Logo
14 people viewed this question
Top Televison & Video Experts
Electro Med Services...
