Question about Frigidaire AEQ7000ES Dryer
Power I need help with my frigidaire affinity dryer model AEQ7000ES1 I had a 4 prong power cord and I needed to put a 3 prong on and I accidently hooked up the wrong colors and when I plugged the dryer in I heard a loud pop sound......Is there a fuse protecting my dryer? If so help me
    Problem Solver:
  • 5 Answers
Depending on what type of circuit protection you have on the dryer[ circuit breaker or the older screw in fuse ] is probably what you heard blowing . If the noise you heard came from the dryer , then it's time to check the connections in the dryer[after unplugging the power source to it] to see what has happened ,if you feel you are experienced enough to handle this type of operation. If you have any doubts about you ability to do this ,then don't!! Call an electrician and/or appliance repairman to do the inspection
Posted on May 24, 2010
Are all dryer power cords the same except for being either 3 or 4 prong?
They are universal. Just hook the new up the same way the old one was, assuming it was wired correctly.
Feb 02, 2016 | Samsung Dryers
Replacing the power cord on a Frigdaire model FDE546RES1
if your new power cord had three prongs then you will hook up the white wire to the machine's white wire, red to red and black to black. if you have 4 prongs you will have extra green wire this will hook up to a ground screw
hope this helps
Jul 03, 2012 | Frigidaire Electric Dryer
I have a Frigidaire Affinity front load dryer that will not come on at all. The lights won't even come on. We had to change the cord out to a 4 prong and when we plugged it in it surged. What could...
Hi, Sounds like you hooked the cord up wrong... tripped the breaker...fix the cord and reset the breaker...
Here is a tip that will help you with changing your dryer plug. Dryer Cord and Wiring Dryer 3 Wire or 4 Wire
heatman101
Jul 10, 2011 | Dryers
Need to install a 4 prong to a Frigidaire electrict dryer model FER211AS2
The following link explains how to correctly install a 4-prong power cord on your dryer:
http://www.fixya.com/support/r793520-3_prong_4_prong_power_cord_conversion
If you have any questions about this repair, please let me know. I hope this helps you.
Nov 02, 2009 | Frigidaire Electric Dryer
I moved to a house with a three prong outlet for my Frigidare electric dryer, model number FER341AC0, that has a four prong cord. I bought a new three prong cord but there is no color coding on the dryer...
The three wire goes on the electrical block on the back of your dryer just like the cord is made. If you look at the cord, it's made flat (Most 3 wire cord are made flat, Some are not) The wire in the middle goes in the middle of the block. The two wires to the outside go to the outside of the block. It makes do difference which wire goes on which side as long as the outside wires go to the outside.
Please rate solution
Sep 06, 2009 | Frigidaire GLER642A Electric Dryer
CHANGING DRYER CORD
All you need to do is, attach the middle connection from the cord to the middle post on the dryer. The 2 outside connections on the cord will attach to the outside posts on the dryer. It does not matter on the outside connectors as far as which side they go.
Make sure they are fastened down tight. If the connections are loose at all, they will go bad.
Please let me know if this has helped you at all or if I can assist you further.
Thanks
Vic
Jul 23, 2009 | Frigidaire GLEQ2152ES Electric Dryer
Frigidaire GLEQ2152ES Dryer Won't Power UP
IF you find that you have only a 3 wire feed for this dryer (and the reason for the 3 prong receptacle)...then you can not properly install a 4 prong dryer cord to it. You now have 2 choices....either rewire (assuming that it is a 3 wire supply) the entire run from the dryer breaker to the outlet location with 4 wire (typically a run of 8/3 with ground having a black, red, white and bare ground)and install a 4 prong dryer receptacle to match the configuration of the new dryers cord.....OR - you can remove the 4 wire cord and replace it with a 3 wire cord....re-using the ground strap - IF it is still in place.
Jul 11, 2009 | Frigidaire Dryers
Wire 3 prong cord
Electric Dryer How To Hook Up Cord pixel_trans.gifFor Three Prong Cords
the Center cord wire goes on the center terminal,
the left on the left ,
and the right on the right.
Note: There should be a ground strap or wire that runs from the center terminal to the dryer case.
For Four Prong Cords
the White cord wire goes in the center,
the Red on the Right,
the Black on the Left.
The green cord wire goes to the case or the external ground screw.
Note: Be sure to disconnect the ground wire or strap that runs from the center terminal to the case. In this Photo (A Whirlpool Dryer) I have ran the wire that runs from the center terminal, the Light Green wire, back to itself rather than cutting it off, just incase I need to put a 3 prong cord back on it some day. The whole purpose of this 3 prong / 4 prong thing is it separates the neutral from the ground. pixel_trans.gif pixel_trans.gif3 Prong Cord Whirlpool Dryer Example terminalblock.jpg 4 Prong Cord Whirlpool Dryer Example 4prongcord_small.jpg
Jul 02, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Changing cord from 3 prong to 4 prong on frigidaire dryer
The following link explains how to convert your appliance from a 3-prong to a 4-prong power cord:
I hope this helps you. Let me know if you still have questions.
Nov 11, 2008 | Frigidaire GLER331A Electric Dryer
Dryers Logo
134 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
