Question about Mitsubishi WD-52525 52" Rear Projection HDTV
Static turn on ,no picture, only static sound.   Press Menu and Device and get 3-4 code then lamp light turns red.  The code 34 indicates Lamp Abnormalities but the lamp itself is in fine condition.  The previous lamp that blew was all  broken within as with a regular bulb.  I would like to know if someone has an idea as to what is wrong and approx, $ to repair.  (As far as I am concerned, it is a piece of JUNK.  Paid big $$$$ four yrs. ago.   jhaze@yahoo.com
  • 1 more comment
  • kokopelliina Nov 05, 2008
    Same problem.Replaced lamp,set worked for two weeks then died.NOT happy about the quality of the TV. Mitsu should fix them all for free seeming as it is a manufacturing and quality isssue. Also have a 1 2 code meaning I probly have bad caps too. Piece of junk never will I buy another mitsu again.
  • inspire5mynd Nov 08, 2008
    the red light is on is set to turn off, tv does not go
  • kokopelliina May 11, 2010
    No live in Anchorage Ak. Whyy do you ask?
    Sergeant:
    Champion:
  • 227 Answers
Where do you live? are you in maryland?
Posted on Nov 05, 2008
No picture no sound will turn on but not off, red light comes on
When the red light is lit press both the menu and device buttons in on the front of the set in together and hold for 5 seconds then record the two digit blink code that will repeat. I am assuming you will receive a 34 error or a 41Error. But let me know what blink code you get and I will assist you.
Jul 20, 2010 | Mitsubishi WD-62525 62" Rear Projection...
No picture or sound mitsubishi 62525
Capacitor failure is the most likely scenario the FMT ans Signal PWB would cause the picture interference and the power pwb would cause the lamp light to turn red and give a 34 code when the device/ input and menu buttons are pressed in together and held for five seconds. That chassis has issues with every board in the chassis having failed capacitors you can get repair kits for the V26 chassis at the follwing link that come with instructions. Your model is the V26 chassis. Heres the link.
http://servicemanuals.vstore.ca/
Jan 25, 2009 | Mitsubishi WD-62525 62" Rear Projection...
WD-52525 Red lamp Indicator
usually with that model when you get a 34 eror code for lamp abnormality, its directly related to the capacitors on the Power Pwb. You can get the V26 Power PWB repair kit at the following link which repairs that issue. It contains the replacement High temp capacitors with the board location numbers and PWB identification as well as the service manual on CD. Heres the link its under their repair kit ctegory.
Sep 04, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Had blue screen, now no picture and red light
Press the menu and the device/input buttond on the det both in together and hold in for 5 seconds to see if the led will blink a two digit code such as 3 blinks slight pause then 4 blinks. I would almost bet that you have a 34 code come up. But respond to this same post and let me know which two digit blink code came up, and I will assist you with whats wrong with your DLP.
Aug 08, 2008 | Mitsubishi WD-52525 52" Rear Projection...
I have a problem with my WD 52525
Here's something that might also be useful. After you turn on the set, and get the regular red blinky lights, hold down the Device and Menu buttons together for about 5 seconds.
The Power light will start to flash in a two digit sequence.
For example, 3 flashes, then 7 flashes = 37.
Here are the error codes, and the corresponding problem:
12 = No error detected, check power supply.
32 = Lamp Cover is open.
33 = Air filter cover is open.
34 = Lamp abnormality
36 = Light Engine (DMD or Lamp Fan stopped)
37 = Exhaust or Lamp Ballast Fan stopped
38 = Lamp Temperature High
39 = DMD Temperature High
41 = Short is detected
44 = DVI cable between FMT and Engine disconnected
Feb 17, 2008 | Mitsubishi WD-52525 52" Rear Projection...
72'' mitsubishi model#73732
Feb 11, 2008 | Mitsubishi WD-62525 62" Rear Projection...
Mitsubishi WD52525 DLP Projection TV
Mitsubishi TV troubleshooting
Jan 29, 2008 | Mitsubishi WD62628 62" Projection HDTV
Wd 52525 error code 34 lamp abnomality
the capictor problem is mostly for WS models
you can locate the dm model from this link
http://www.fixya.com/howto/h159332-mitsubishi_dm_board_repair
Jan 18, 2008 | Mitsubishi WD-52525 52" Rear Projection...
WD-52525-Code 34-Sound OK-No picture!
I had another problem kinda the same and emailed ctechnicians.com and they gave the fix.
Nov 02, 2007 | Mitsubishi WD-52525 52" Rear Projection...
Tv keeps turning off?
cutta, you will most often hear a click on boot then the fans start up and lamp will then fire. The picture will start to show up....at what point does it shut off? and do you hear a click when the tv is turning off? Is it the complete tv shutting down, fans and everything that turns off? Do you see any lights on the the front panel "POWER", "STATUS" or "LAMP", what are they doing? If you see a Power, Status or Lamp light after it shuts off the below are what they mean if there is an issue. POWER - STATUS - LAMP - CONDITION/ISSUE: Off - Yellow - Off - Temp. high/dirty filter/excess room temp Off - Off - Yellow - 4000 hrs. Lamp usage warning Off - Off - Blink Yellow - Lamp Cover open Off - Blink Yellow - Off - Air Filter Cover open Off - Off - Red - Lamp failure (failed to turn On or broken) Off - Blink Red - Off - Fan Has Stopped Off - Red - Off - Circuit failure (short) or DVI cable disconnected If you want to check for the last "Error Code", after you first turn the TV on, by pressing the front panel ?DEVICE? and ?MENU? buttons at the same time and holding them for 5 seconds, it activates the Error Code Mode. The ?Power LED Light? blinks/flashes (1/2 sec delay) and then flashes again denoting a two digit Error Code indicating no problem or an error has occured since the last Initalization. i.e. "Power light" blinks 3 times (1/2 second delay) and then blinks 4 times then 1 sec delay and repeats a few times. This would mean "Error 34 - Lamp abnormality". See below for error codes..... Error Code - Description or issue 12 - No Error detected, check Power Supply 32 - Lamp Cover is open 33 - Air Filter Cover is open 34 - Lamp abnormality 36 - Light Engine (DMD or LAMP Fan stopped) 37 - Exhaust or Lamp Ballast Fan stopped 38 - Lamp temperature high 39 - DMD temperature high 41 - Short is detected 44 - DVI cable between FMT & Engine disconnected. Sorry for the long answer but it was an open ended question.
Jul 11, 2007 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
81 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
